Part Number: TSB12LV32
Other Parts Discussed in Thread: TSB41BA3A-EP,
The reliability estimator appears to provide FIT rates for ground applications.
Is there similar information for avionics environment?
John:
I will check if we have similar information for avionics environment.
Brian
Thank you.
The other device is the PHY, tsb41ba3a.
Also, do the devices contain Boron10?
Hi John:
What special report needed for avionics environment? I don't think anyone in our team knowing this.
Brian
The Avionics FADEC page (Full authority digital engine control (FADEC) design resources | TI.com) states:
The avionics environment at 40Kft, 45 degrees has a typical high energy neutron flux of 7500 N/cm/hr compared to NYC rate of 13 N/cm/hr. The high energy neutrons have energy levels in the range of 1 MeV to 20 Mev, as opposed the the 0.7 eV in the Reliability Estimator. Typically, the devices have a value either in FITs at NYC or cross-sectional area which are scalable to the flux at desired locations.
I found tsb41ba3a-ep.pdf and tsb12lv32-ep.pdf. Since these are EP, I expected they may have an enhanced reliability report for the Avionics environment.
Hi John:
Good to know, but unfortunately we never get request for such reliability report before and it may need some time if we need to get such report.
Brian
These two devices were developed over 20 years ago for Sony camcorder so I don't think we plan to market this device for Avionics and Space at that time.
Brian
We have test data from a previous program.
This ticket can beclosed.
Thank you,
John
