[FAQ] RS232 and RS485 Protection
Back to Interface Home Page
Highlights:
  • RS-485 – Industry standard protocol for data transfer from sensors, etc.
  • Drive capability of minimum 32 unit loads (UL, 12kΩ)
  • Uses two signal lines A & B which must be balanced and differential
  • Runs on an I/O common-mode range: -7V to +12V, this requires the minimum breakdown voltage to be > 13.3V
  • Load capacitance requirements as per RS 485 standards <30pF
  • RS-485 lines being heavily used in outdoor signaling also require a surge protection.
TI Products Recommendations
Working Voltage (V)
IEC 61000-4-2 ESD Rating (kV) (Contact)
Capacitance (pF)
Channel
count
Package Size (mm)
Package
Recommended for
ESDS552
±12
30
9.5
2
2.92 x 1.3
SOT-23
Differential signal pairs with surge protection
ESD562
±12
22
1.5
2
2.92 x 1.3
SOT-23
Low-cost differential signal pairs
ESD752
±24
30
3
2
2.92 x 1.3
SOT-23
Systems with higher voltage clamping
< Related Threads>
TPD4E001 for RS-232?
ESD or Surge Protection for RS-232/485?
RS-232 Protection Device Naming Convention
