Part Number: DS280DF810
Other Parts Discussed in Thread: DS250DF230
Hi team,
Could DS280DF810 realize either point below?Customer want to check if retimer will influence syncE function
1) Recover the clock of the serial code stream at the receiving end and pass its output. In this case, the function is similar to sync-E
2) The code stream output by the TX end is consistent with the code stream rate received by the RX end, and the same serdes link maintains consistency. If possible, the frequency synchronization function can be implemented by the MAC
