Part Number: DS90UB953-Q1
Other Parts Discussed in Thread: ALP
Team,
In order to do some system level testing between 953 -> cable -> 954 how can the BIST capability (mentioned in DS section 7.3.4.4 Built-In Self Test) be used?
Do you have a script example (I2C command and sequence) in in order to perform BIST?
or code example you can share?
Does the BIST work together with the pattern generator (ie section 7.6) ?
Can the 953 BIST and pattern generator be controlled over the 954 I2C back channel?
https://www.ti.com/lit/pdf/snla131
Thanks in advance!
Anthony
