Part Number: SN65DPHY440SS
Hi team,
Customer get following question about SN65DPHY440SS: could you help check comments?
The retimer spec says the highest EQ level is for channel insertion loss of 4dB@500MHz,is it means when the total insertion loss is below 4dB@500MHz(1Gbps signal rate),the retimer can receive the correct data by EQ level 3.
It seems the capability of retime is much stronger than the requirement of MIPI standard(-2dB@ Nyquist frequency), am I right?
Thanks and Best regards,
Will
