SN75LVDT1422 LVTTL Jitter
Other Parts Discussed in Thread: SN75LVDT1422
Is there a jitter spec on the "CLK OUT" pin (pin 61) of the SN75LVDT1422?
Thank you
  • We don't have a CLK OUT jitter spec for this device.  The output clock is intended to be used a data strobe, so instead we specify set-up and hold times with respect to the RA/RB output data.  This information can be found in the Receiver Switching Characteristics section of the datasheet.
    Max Robertson
    Analog Applications Engineer
    Texas Instruments
    m-robertson@ti.com
