Part Number: TLIN1028-Q1
Other Parts Discussed in Thread: MSPM0L1306-Q1,
Hello
I have a question regarding your LIN transceiver TLIN1028-Q1 in combination with a MCU (MSPM0L1306-Q1).
As recommended in the transceiver data sheet, the ‘EN’ and ‘TXD’ lines are connected directly to the MCU.
We have now found that when the MCU is reset, the TXD signal drops faster than the EN signal and is therefore interpreted by the LIN transceiver as a sleep pattern. The LIN transceiver goes into sleep mode (nRST low, LDO off) and the MCU no longer has any supply voltage:
Thus, resetting the MCU leads to a transition to sleep mode, where an external LIN (wake-up) signal is required so that the MCU wakes up again and responds to LIN communication. In addition, the information about the reason for the reset is lost because there is no supply voltage in sleep mode.
Is it an intended behavior of the MCU-transceiver application that an MCU reset leads to a sleep state?
Bettina
