Part Number: SN65HVD1785
Other Parts Discussed in Thread: AM26C31, , THVD2410V, THVD2410
Hi everybody,
I'm recreating my TTL to RS-422 signal splitter. The first one was created using AM26C31 and works fine. I wanted to make my design more robust, so I chose SN65HVD1785.
Unfortunately it doesn't work as I wanted.
When there is no signal, the input A oscillates instead of being high.
When there's data incoming:
And closer look:
I pulled RE and DE pins to high, so that it can only work in one way - I don't want to get any data, only "broadcast" to another devices for further distances.
Same circuit but with AM26C31 gives me ideal differential output, but doesn't protect my circuit against bus shorts (that's what I really need to have).
Signal that goes to driver pin is 0-5V logic.
What can be wrong about this design? Is there any other possiblity to replace AM26C31 with IC that protects circuit against bus shorts?
Thank you in advance for your answer,
Jakub
