TUSB211A: 原理图和PCB设计是否正确
Part Number: TUSB211A
问题:
这种信号放大器一般布置在哪里合适,比如我的控制器需要连到TBOX的USB接口,把TBOX当网卡用,
这个信号放大器目前布置在我的控制器端,这样是否合适?
帮忙审核一下原理图设计是否适当:
PCB layout设计是否适当:
    Please send over the layout file, so we can look into this in more detail.
    As for the schematic, we recommend removing the Common mode choke, as this can have a negative effect on the USB2 signal.
    Additionally, this is more of a nitpick, please separate the ground being used for GND and VCC into two separate grounds.
    Ryan
    I will go ahead and close this E2E thread for no activity, you can either respond back to this thread or create a new thread if you need any additional support.
    David
