Part Number: DS280DF810
Hi Team,
The customer have 4 devices cascaded with consecutive I2Cs, no issues there but not sure what the following fields need to be set to in order to make sure that the device is properly set:
Common Channel Select (Which channel does this need to be set to?)
EEPROM Header: Common Channel Enabled? Does this need to be done?
Slot Update Details: Do I select this for all slots or a specific number of slots?
Is there a specific section of the datasheet that highlights exactly when to enable or disable these settings? Let me know whenever possible!
Thank you,
Filipe
