Part Number: DS280BR820
Other Parts Discussed in Thread: DS280DF810, DS280MB810,
Hi Team,
Is there any solution that complies with IEE802.3bj/100Gb/s(28Gb/s*4pair=112G) Re-timer/Re-driver specifications?
Hi Team,
Hi Kevin,
The DS280DF810 is a retimer supporting 28 Gbps signaling, as used in IEEE802.3bj.
The DS280BR820 and DS280MB810 are redrivers supporting 28 Gbps signaling.
Would this be a front port application? If considering DS280BR820/DS280MB810, please perform simulation using the IBIS-AMI model and the channel models.
Drew
Hi Drew,
Application is as follows,
Need to comply with IEE802.3bj/100Gb/s (28Gb/s*4pair=112G) specification, NRZ signal format
Hi Kevin,
Do you have an estimate for channel insertion losses in this system?
Drew
Hi Kevin
I will go ahead and close this E2E thread for no activity, you can either respond back to this thread or create a new thread if you need any additional support.
David
