Part Number: TCA9548A
Hi team,
Table 7.3 on page 6 of the data sheet describes the electrical characteristics of SCL/SDA.
Where are the electrical characteristics of SC*/SD* listed?
Hi team,
Thank you for answering,Clemens & Alex
When the VCC power is ON and the pull up power on the SC*/SD* side is OFF,
is it possible for the current on the SCL/SDA side to flow to the SC*/SD* side?
What happens when the VCC power supply is OFF?
Hi Kakeru,
Are you asking if the SC*/SD* pins are pulled to 0V what will the current flow be? If so, there is no current flow.
When the device/supply is powered off, then the pass FET is off, and no current can flow through it.
Alex
Thank you for answering, Alex
This occurs when SC*/SD* pins become HiZ.
When the device/power supply is turned on, even if either the SC*/SD* side or the SCL/SDA side becomes HiZ, will no current flow to the HiZ side?
Hi Kakeru,
If you have a high impedance input, then Ohm's law would show us that the current through the switch would effectively be zero.
Alex
