Part Number: SN65HVD233-Q1
Other Parts Discussed in Thread: TCAN1042-Q1
Hello TI,
We want to do simulation of this part ., so need your help. also suggest below points.
1. required tools
2. procedure
Hello TI,
1. required tools
2. procedure
Yes, I have downloaded IBS model and installed pSpice for TI .
I want to simulate CAN communication using this part.
IBIS models are not the same as Spice models, so they will not work with a PSpice simulator. There is a Spice model for the TCAN1042-Q1, a more modern CAN transceiver from TI, that will work for PSpice for TI, which may be a better path forward. If you still want to use the IBIS model, some simulation tools you can use are Mentor Graphics Hyperlynx, Cadence SigXplorer, or Agilent ADS.
Eric Hackett
