Part Number: LMH0397
Good morning,
I am currently working on a new design and I would like to use this component (LMH0397). We will be using a resistor-fixed configuration. Therefore, we have several pins that we will not be using.
Reviewing the chip datasheet, we have not found any specific note that says what to do with these pins (pullups/pulldowns?). Depending on the pin, we have observed that some have internal pull-up resistors, while others, depending on the configuration, are left floating.
I am attaching a screenshot where you can see the pins that we will not be using. Do you think it is correct to leave them floating?
Thank you very much in advance,
Diego
