Part Number: SN65HVS882
Two questions regarding the SN65HVS882:
- Do the DB0, DB1, SIP, LD#, CE# and CLK pins have internal pull-ups to the 5V supply or pull-downs to GND? If so, what would be their value?
- Is SOP tri-state or do you need an external buffer for that functionality if you want to operate other additional devices on the same SPI bus?
Thanks.
Louis
