Part Number: DP83TC811-Q1
Other Parts Discussed in Thread: DP83TC811
The system needs to implement the Wake on LAN function. Currently, the RMII_REFCLK 50MHz is generated by the system, but the RMII_REFCLK is turned off when the system enters sleep mode.
Is there a way to configure the registers to enable the DP83TC811 Wake on LAN function without the 50MHz clock?
Or is the 50MHz clock necessary for the Wake on LAN function?
