Part Number: DS100BR410
Good morning,
Is it acceptable to leave the SDA, SDC, and CS pins on the DS100BR410 device not connected when I have the component set to pin control mode? On the datasheet it has a note that says external pull-up resistor is required for the SDA pin, but I'm assuming that is only necessary when you utilize the SMBus interface.
Thanks in advance!
