Part Number: I2C-DESIGNER
Other Parts Discussed in Thread: TS5A23157
Hi all, I am trying to design an I2C device that can be plugged with a 4-pin connector in 2 different positions one the reverse of the other. Let me explain further. This device must have a 4 pin connector (pin1 VCC, pin2 SCL, pin3 SDA, pin4 GND) the device must also be inserted by rotating it 180 degrees, in this case the pins will change their orientation ( pin1 GND, pin2 SDA, pin3 SCL, pin4 VCC). To have two such configurations with a 4-pin connector I don't think I have problems for power supply (diode bridge doesn't change the power supply with the orientation of the connector) but I have problems to reverse the SCL,SDA lines. Do you think doing this with a mux might be possible? What could be the component of choice?
