I am using this re-driver between a FPGA & SFP-ER as per below mentioned block diagram, with maximum of 10Gbps data rate system. BER for some lane is so much high using IBERT (xilinx tool). By generating the eye diagram in the IBERT tool, BER 0E0 & error causing channels looks the same. Is there any option to monitor signal quality parameters.
And in that re-drive 2 types of physical mode given, Pin No 21. 10G-BASE-KR & 10G-Mode, clarity required for 10G-Mode.
