DS90UB960-Q1: Rx Buffer error when two cameras are streamed simultaneously
Part Number: DS90UB960-Q1
        2 lane @ 800Mbps/lane
                     2 lane @ 1.6Gbps/lane              |<-------> DS90UB953 ------ Camera 1
Nvidia tegra orin <------>  DS90UB960 <----->|
        |<-------> DS90UB953 ------ Camera 2
        2 lane @ 800 Mbps/lane
both are the same type of cameras 1280*800 resolution 10-bit raw pixel max 120 fps
We face an Rx buffer error on both Rx ports of the deserializer when streaming both cameras together at 60fps. which should be working as I have cross-checked the input and output bandwidth, output bandwidth is enough to accommodate both cameras.
Can someone please give me a hint regarding the issue here? I am attaching the register dump of ds90ub960.
0 -> 7a
1 -> 0
2 -> 1e
3 -> 40
4 -> d0
5 -> 1
6 -> 0
7 -> fe
8 -> 1c
9 -> 10
a -> 7a
b -> 7a
c -> 3
d -> b9
e -> 0
f -> ff
10 -> 0
11 -> 0
12 -> 0
13 -> 0
14 -> 0
15 -> 0
16 -> 0
17 -> 0
18 -> 0
19 -> 0
1a -> 0
1b -> 0
1c -> 0
1d -> 0
1e -> 4
1f -> 0
20 -> c3
21 -> 3
22 -> 0
23 -> 0
24 -> 3
25 -> 0
26 -> 0
27 -> 0
28 -> 0
29 -> 0
2a -> 0
2b -> 0
2c -> 0
2d -> 0
2e -> 0
2f -> 0
30 -> 0
31 -> 0
32 -> 1
33 -> 0
34 -> 0
35 -> 0
36 -> 0
37 -> 0
38 -> 0
39 -> 0
3a -> 0
3b -> 0
3c -> 0
3d -> 0
3e -> 0
3f -> 0
40 -> 0
41 -> a9
42 -> 71
43 -> 1
44 -> 0
45 -> 0
46 -> 20
47 -> 0
48 -> 0
49 -> 0
4a -> 0
4b -> 12
4c -> 12
4d -> 43
4e -> 14
4f -> 64
50 -> 0
51 -> 0
52 -> 0
53 -> 3
54 -> 0
55 -> 0
56 -> 0
57 -> 0
58 -> 5e
59 -> 0
5a -> 0
5b -> 30
5c -> 8a
5d -> c0
5e -> 20
5f -> 0
60 -> 0
61 -> 0
62 -> 0
63 -> 0
64 -> 0
65 -> 96
66 -> 9a
67 -> 0
68 -> 0
69 -> 0
6a -> 0
6b -> 0
6c -> 0
6d -> 78
6e -> 88
6f -> 88
70 -> 6b
71 -> 6c
72 -> 55
73 -> 3
74 -> 20
75 -> 6
76 -> 40
77 -> c5
78 -> 0
79 -> 1
7a -> 0
7b -> 0
7c -> 20
7d -> 0
7e -> 0
7f -> 0
80 -> 0
81 -> 0
82 -> 0
83 -> 0
84 -> 0
85 -> 0
86 -> 0
87 -> 0
88 -> 0
89 -> 0
8a -> 0
8b -> 0
8c -> 0
8d -> 0
8e -> 0
8f -> 0
90 -> 0
91 -> 0
92 -> 0
93 -> 0
94 -> 0
95 -> 0
96 -> 0
97 -> 0
98 -> 2
99 -> cb
9a -> 1
9b -> 15
9c -> ff
9d -> ff
9e -> 0
9f -> c1
a0 -> 0
a1 -> 0
a2 -> 0
a3 -> 0
a4 -> 0
a5 -> 1c
a6 -> 0
a7 -> 0
a8 -> 0
a9 -> 0
aa -> 0
ab -> 0
ac -> 0
ad -> 0
ae -> 0
af -> 0
b0 -> 8
b1 -> 9
b2 -> 8
b3 -> 8
b4 -> 25
b5 -> 0
b6 -> 18
b7 -> 0
b8 -> f8
b9 -> 33
ba -> 83
bb -> 74
bc -> 80
bd -> 0
be -> 0
bf -> 0
c0 -> 0
c1 -> 0
c2 -> 0
c3 -> 0
c4 -> 0
c5 -> 0
c6 -> 0
c7 -> 0
c8 -> 0
c9 -> 0
ca -> 0
cb -> 0
cc -> 0
cd -> 0
ce -> 0
cf -> 0
d0 -> 0
d1 -> 43
d2 -> 94
d3 -> 0
d4 -> 60
d5 -> e0
d6 -> 0
d7 -> 2
d8 -> 7
d9 -> 7f
da -> 0
db -> 0
dc -> 0
dd -> 0
de -> 0
df -> 0
e0 -> 0
e1 -> 0
e2 -> 0
e3 -> 0
e4 -> 0
e5 -> 0
e6 -> 0
e7 -> 0
e8 -> 0
e9 -> 0
ea -> 0
eb -> 0
ec -> 0
ed -> 0
ee -> 0
ef -> 0
f0 -> 5f
f1 -> 55
f2 -> 42
f3 -> 39
f4 -> 36
f5 -> 30
f6 -> 0
f7 -> 0
f8 -> 0
f9 -> 0
fa -> 0
fb -> 0
fc -> 0
fd -> 0
fe -> 0
Kayas Ahmed
  • Hello Kayas,
    can you please confirm the frame rate is 60 or 120 fps?
    Do you see the same issue at every start of the system, or are there times where the system works without reporting these errors?
    Can you provide register dump from the cameras as well?
  • Hello Hamzeh,
    The camera supports 120fps, but for streaming two cameras we use 60fps. For your information, we could stream a single camera with 120fps without any issues.
    I am using Gstreaming for streaming cameras. Out of 10 tries, 1 try starts without any error, but after some time it also fails with the same error.
    For the camera register dump, I am using the ov9281 camera, please find the dump.
    ov9281_regs_dump.txt
    Thanks & Regards,
    Kayas Ahmed
  • Hi Kayas,
    thanks for the details.
    Let me review these and get back to you by tomorrow
  • Hi Kayas,
    I have checked the DES register dump and here are my findings:
    0x33 = 0x00 -- CSI output ports are not enabled. You need to enable the CSI TX port (0x33[0])
    0xA5 = 0x1C -- indicates higher REFCLK than it should (28MHz). Please make sure you have a REFCLK within the specified range 23 - 26MHz only.
    I checked the other provided dump and find that this is from the Image sensor! Sorry If I was not clear but I am looking for the dump from our device, i.e. the SER.
  • Hello Hamzeh,
    Sorry, by mistake, I resolved it, can you please undo it,
    I have better register dumps as I had enabled TX port 1 instead of 0
    [12664.139309] ds90ub960 9-003d: 0 -> 7a
    [12664.139509] ds90ub960 9-003d: 1 -> 0
    [12664.139707] ds90ub960 9-003d: 2 -> 1e
    [12664.139900] ds90ub960 9-003d: 3 -> 40
    [12664.140084] ds90ub960 9-003d: 4 -> d0
    [12664.140265] ds90ub960 9-003d: 5 -> 1
    [12664.140439] ds90ub960 9-003d: 6 -> 0
    [12664.140614] ds90ub960 9-003d: 7 -> fe
    [12664.140789] ds90ub960 9-003d: 8 -> 1c
    [12664.140960] ds90ub960 9-003d: 9 -> 10
    [12664.141131] ds90ub960 9-003d: a -> 7a
    [12664.141322] ds90ub960 9-003d: b -> 7a
    [12664.141508] ds90ub960 9-003d: c -> 3
    [12664.141691] ds90ub960 9-003d: d -> b9
    [12664.142365] ds90ub960 9-003d: e -> 0
    [12664.142567] ds90ub960 9-003d: f -> ff
    [12664.142766] ds90ub960 9-003d: 10 -> 0
    [12664.142953] ds90ub960 9-003d: 11 -> 0
    [12664.143157] ds90ub960 9-003d: 12 -> 0
    [12664.143352] ds90ub960 9-003d: 13 -> 0
    [12664.143553] ds90ub960 9-003d: 14 -> 0
    [12664.143728] ds90ub960 9-003d: 15 -> 0
    [12664.143901] ds90ub960 9-003d: 16 -> 0
    [12664.144201] ds90ub960 9-003d: 17 -> 0
    [12664.144377] ds90ub960 9-003d: 18 -> 0
    [12664.144553] ds90ub960 9-003d: 19 -> 0
    [12664.144731] ds90ub960 9-003d: 1a -> 0
    [12664.144910] ds90ub960 9-003d: 1b -> 0
    [12664.145085] ds90ub960 9-003d: 1c -> 0
    [12664.145262] ds90ub960 9-003d: 1d -> 0
    [12664.145438] ds90ub960 9-003d: 1e -> 4
    [12664.145614] ds90ub960 9-003d: 1f -> 0
    [12664.145791] ds90ub960 9-003d: 20 -> c3
    [12664.146361] ds90ub960 9-003d: 21 -> 3
    [12664.146557] ds90ub960 9-003d: 22 -> 0
    [12664.146837] ds90ub960 9-003d: 23 -> 0
    [12664.147023] ds90ub960 9-003d: 24 -> 3
    [12664.147204] ds90ub960 9-003d: 25 -> 0
    [12664.147385] ds90ub960 9-003d: 26 -> 0
    [12664.147563] ds90ub960 9-003d: 27 -> 0
    [12664.147742] ds90ub960 9-003d: 28 -> 0
    [12664.147925] ds90ub960 9-003d: 29 -> 0
    [12664.148102] ds90ub960 9-003d: 2a -> 0
    [12664.148284] ds90ub960 9-003d: 2b -> 0
    [12664.148466] ds90ub960 9-003d: 2c -> 0
    [12664.148648] ds90ub960 9-003d: 2d -> 0
    [12664.148831] ds90ub960 9-003d: 2e -> 0
    [12664.149011] ds90ub960 9-003d: 2f -> 0
    [12664.149194] ds90ub960 9-003d: 30 -> 0
    [12664.149377] ds90ub960 9-003d: 31 -> 0
    [12664.149558] ds90ub960 9-003d: 32 -> 12
    [12664.149758] ds90ub960 9-003d: 33 -> 63
    [12664.150244] ds90ub960 9-003d: 34 -> 31
    [12664.150441] ds90ub960 9-003d: 35 -> 11
    [12664.150623] ds90ub960 9-003d: 36 -> 0
    [12664.150947] ds90ub960 9-003d: 37 -> 13
    [12664.151146] ds90ub960 9-003d: 38 -> 0
    [12664.151375] ds90ub960 9-003d: 39 -> 0
    [12664.151561] ds90ub960 9-003d: 3a -> 0
    [12664.151943] ds90ub960 9-003d: 3b -> 0
    [12664.152279] ds90ub960 9-003d: 3c -> 0
    [12664.152474] ds90ub960 9-003d: 3d -> 0
    [12664.152662] ds90ub960 9-003d: 3e -> 0
    [12664.152847] ds90ub960 9-003d: 3f -> 0
    [12664.153032] ds90ub960 9-003d: 40 -> 0
    [12664.153217] ds90ub960 9-003d: 41 -> a9
    [12664.153405] ds90ub960 9-003d: 42 -> 71
    [12664.153600] ds90ub960 9-003d: 43 -> 1
    [12664.153789] ds90ub960 9-003d: 44 -> 0
    [12664.154352] ds90ub960 9-003d: 45 -> 0
    [12664.154550] ds90ub960 9-003d: 46 -> 20
    [12664.154737] ds90ub960 9-003d: 47 -> 0
    [12664.154921] ds90ub960 9-003d: 48 -> 0
    [12664.155103] ds90ub960 9-003d: 49 -> 0
    [12664.155286] ds90ub960 9-003d: 4a -> 0
    [12664.155469] ds90ub960 9-003d: 4b -> 12
    [12664.155651] ds90ub960 9-003d: 4c -> 12
    [12664.155833] ds90ub960 9-003d: 4d -> 43
    [12664.156011] ds90ub960 9-003d: 4e -> 14
    [12664.156190] ds90ub960 9-003d: 4f -> 64
    [12664.156367] ds90ub960 9-003d: 50 -> 0
    [12664.156547] ds90ub960 9-003d: 51 -> 0
    [12664.156728] ds90ub960 9-003d: 52 -> 0
    [12664.156912] ds90ub960 9-003d: 53 -> 3
    [12664.157091] ds90ub960 9-003d: 54 -> 0
    [12664.157273] ds90ub960 9-003d: 55 -> 0
    [12664.157466] ds90ub960 9-003d: 56 -> 0
    [12664.157644] ds90ub960 9-003d: 57 -> 0
    [12664.158210] ds90ub960 9-003d: 58 -> 5e
    [12664.158420] ds90ub960 9-003d: 59 -> 0
    [12664.158605] ds90ub960 9-003d: 5a -> 0
    [12664.158790] ds90ub960 9-003d: 5b -> 30
    [12664.158968] ds90ub960 9-003d: 5c -> 8a
    [12664.159148] ds90ub960 9-003d: 5d -> c0
    [12664.159328] ds90ub960 9-003d: 5e -> 20
    [12664.159513] ds90ub960 9-003d: 5f -> 0
    [12664.159701] ds90ub960 9-003d: 60 -> 0
    [12664.159888] ds90ub960 9-003d: 61 -> 0
    [12664.160075] ds90ub960 9-003d: 62 -> 0
    [12664.160262] ds90ub960 9-003d: 63 -> 0
    [12664.160458] ds90ub960 9-003d: 64 -> 0
    [12664.160643] ds90ub960 9-003d: 65 -> 96
    [12664.160846] ds90ub960 9-003d: 66 -> 9a
    [12664.161043] ds90ub960 9-003d: 67 -> 0
    [12664.161247] ds90ub960 9-003d: 68 -> 0
    [12664.161464] ds90ub960 9-003d: 69 -> 0
    [12664.161670] ds90ub960 9-003d: 6a -> 0
    [12664.162258] ds90ub960 9-003d: 6b -> 0
    [12664.162454] ds90ub960 9-003d: 6c -> 0
    [12664.162687] ds90ub960 9-003d: 6d -> 78
    [12664.162881] ds90ub960 9-003d: 6e -> 88
    [12664.163066] ds90ub960 9-003d: 6f -> 88
    [12664.163246] ds90ub960 9-003d: 70 -> 6b
    [12664.163639] ds90ub960 9-003d: 71 -> 6c
    [12664.163834] ds90ub960 9-003d: 72 -> 55
    [12664.164021] ds90ub960 9-003d: 73 -> 3
    [12664.164213] ds90ub960 9-003d: 74 -> 20
    [12664.164405] ds90ub960 9-003d: 75 -> 6
    [12664.164588] ds90ub960 9-003d: 76 -> 40
    [12664.164777] ds90ub960 9-003d: 77 -> c5
    [12664.165117] ds90ub960 9-003d: 78 -> 0
    [12664.165303] ds90ub960 9-003d: 79 -> 1
    [12664.165490] ds90ub960 9-003d: 7a -> 0
    [12664.165678] ds90ub960 9-003d: 7b -> 0
    [12664.166209] ds90ub960 9-003d: 7c -> 20
    [12664.166621] ds90ub960 9-003d: 7d -> 0
    [12664.166898] ds90ub960 9-003d: 7e -> 0
    [12664.167090] ds90ub960 9-003d: 7f -> 0
    [12664.167289] ds90ub960 9-003d: 80 -> 0
    [12664.167496] ds90ub960 9-003d: 81 -> 0
    [12664.167688] ds90ub960 9-003d: 82 -> 0
    [12664.168038] ds90ub960 9-003d: 83 -> 0
    [12664.168234] ds90ub960 9-003d: 84 -> 0
    [12664.168414] ds90ub960 9-003d: 85 -> 0
    [12664.168595] ds90ub960 9-003d: 86 -> 0
    [12664.168794] ds90ub960 9-003d: 87 -> 0
    [12664.168978] ds90ub960 9-003d: 88 -> 0
    [12664.169156] ds90ub960 9-003d: 89 -> 0
    [12664.169576] ds90ub960 9-003d: 8a -> 0
    [12664.169760] ds90ub960 9-003d: 8b -> 0
    [12664.170260] ds90ub960 9-003d: 8c -> 0
    [12664.170522] ds90ub960 9-003d: 8d -> 0
    [12664.170709] ds90ub960 9-003d: 8e -> 0
    [12664.170892] ds90ub960 9-003d: 8f -> 0
    [12664.171073] ds90ub960 9-003d: 90 -> 0
    [12664.171263] ds90ub960 9-003d: 91 -> 0
    [12664.171467] ds90ub960 9-003d: 92 -> 0
    [12664.171669] ds90ub960 9-003d: 93 -> 0
    [12664.171867] ds90ub960 9-003d: 94 -> 0
    [12664.172072] ds90ub960 9-003d: 95 -> 0
    [12664.172262] ds90ub960 9-003d: 96 -> 0
    [12664.172448] ds90ub960 9-003d: 97 -> 0
    [12664.172632] ds90ub960 9-003d: 98 -> 39
    [12664.172815] ds90ub960 9-003d: 99 -> cc
    [12664.173002] ds90ub960 9-003d: 9a -> 19
    [12664.173193] ds90ub960 9-003d: 9b -> 7a
    [12664.173378] ds90ub960 9-003d: 9c -> ff
    [12664.173563] ds90ub960 9-003d: 9d -> ff
    [12664.173748] ds90ub960 9-003d: 9e -> 12
    [12664.174283] ds90ub960 9-003d: 9f -> 5b
    [12664.174530] ds90ub960 9-003d: a0 -> 0
    [12664.174773] ds90ub960 9-003d: a1 -> 0
    [12664.174969] ds90ub960 9-003d: a2 -> 0
    [12664.175159] ds90ub960 9-003d: a3 -> 0
    [12664.175533] ds90ub960 9-003d: a4 -> 0
    [12664.175715] ds90ub960 9-003d: a5 -> 1c
    [12664.175894] ds90ub960 9-003d: a6 -> 0
    [12664.176092] ds90ub960 9-003d: a7 -> 0
    [12664.176268] ds90ub960 9-003d: a8 -> 0
    [12664.176450] ds90ub960 9-003d: a9 -> 0
    [12664.176643] ds90ub960 9-003d: aa -> 0
    [12664.177285] ds90ub960 9-003d: ab -> 0
    [12664.177485] ds90ub960 9-003d: ac -> 0
    [12664.177681] ds90ub960 9-003d: ad -> 0
    [12664.178145] ds90ub960 9-003d: ae -> 0
    [12664.178544] ds90ub960 9-003d: af -> 0
    [12664.178736] ds90ub960 9-003d: b0 -> 8
    [12664.178922] ds90ub960 9-003d: b1 -> 9
    [12664.179189] ds90ub960 9-003d: b2 -> 8
    [12664.179377] ds90ub960 9-003d: b3 -> 8
    [12664.179567] ds90ub960 9-003d: b4 -> 25
    [12664.179970] ds90ub960 9-003d: b5 -> 0
    [12664.180150] ds90ub960 9-003d: b6 -> 18
    [12664.180332] ds90ub960 9-003d: b7 -> 0
    [12664.180519] ds90ub960 9-003d: b8 -> f8
    [12664.180737] ds90ub960 9-003d: b9 -> 33
    [12664.180932] ds90ub960 9-003d: ba -> 83
    [12664.181119] ds90ub960 9-003d: bb -> 74
    [12664.181427] ds90ub960 9-003d: bc -> 80
    [12664.181611] ds90ub960 9-003d: bd -> 0
    [12664.181789] ds90ub960 9-003d: be -> 0
    [12664.182264] ds90ub960 9-003d: bf -> 0
    [12664.182571] ds90ub960 9-003d: c0 -> 0
    [12664.182783] ds90ub960 9-003d: c1 -> 0
    [12664.182972] ds90ub960 9-003d: c2 -> 0
    [12664.183169] ds90ub960 9-003d: c3 -> 0
    [12664.183356] ds90ub960 9-003d: c4 -> 0
    [12664.183971] ds90ub960 9-003d: c5 -> 0
    [12664.184184] ds90ub960 9-003d: c6 -> 0
    [12664.184380] ds90ub960 9-003d: c7 -> 0
    [12664.184580] ds90ub960 9-003d: c8 -> 0
    [12664.184885] ds90ub960 9-003d: c9 -> 0
    [12664.185085] ds90ub960 9-003d: ca -> 0
    [12664.185282] ds90ub960 9-003d: cb -> 0
    [12664.185480] ds90ub960 9-003d: cc -> 0
    [12664.185683] ds90ub960 9-003d: cd -> 0
    [12664.186222] ds90ub960 9-003d: ce -> 0
    [12664.186441] ds90ub960 9-003d: cf -> 0
    [12664.186632] ds90ub960 9-003d: d0 -> 0
    [12664.186814] ds90ub960 9-003d: d1 -> 43
    [12664.187000] ds90ub960 9-003d: d2 -> 94
    [12664.187194] ds90ub960 9-003d: d3 -> 0
    [12664.187467] ds90ub960 9-003d: d4 -> 60
    [12664.187645] ds90ub960 9-003d: d5 -> e0
    [12664.187829] ds90ub960 9-003d: d6 -> 0
    [12664.188009] ds90ub960 9-003d: d7 -> 2
    [12664.188190] ds90ub960 9-003d: d8 -> 7
    [12664.188373] ds90ub960 9-003d: d9 -> 7f
    [12664.188555] ds90ub960 9-003d: da -> 0
    [12664.188735] ds90ub960 9-003d: db -> 0
    [12664.188918] ds90ub960 9-003d: dc -> 0
    [12664.189100] ds90ub960 9-003d: dd -> 0
    [12664.189281] ds90ub960 9-003d: de -> 0
    [12664.189597] ds90ub960 9-003d: df -> 0
    [12664.189785] ds90ub960 9-003d: e0 -> 0
    [12664.190384] ds90ub960 9-003d: e1 -> 0
    [12664.190594] ds90ub960 9-003d: e2 -> 0
    [12664.190788] ds90ub960 9-003d: e3 -> 0
    [12664.190972] ds90ub960 9-003d: e4 -> 0
    [12664.191157] ds90ub960 9-003d: e5 -> 0
    [12664.191335] ds90ub960 9-003d: e6 -> 0
    [12664.191520] ds90ub960 9-003d: e7 -> 0
    [12664.191703] ds90ub960 9-003d: e8 -> 0
    [12664.191921] ds90ub960 9-003d: e9 -> 0
    [12664.192095] ds90ub960 9-003d: ea -> 0
    [12664.192275] ds90ub960 9-003d: eb -> 0
    [12664.192457] ds90ub960 9-003d: ec -> 0
    [12664.192675] ds90ub960 9-003d: ed -> 0
    [12664.192865] ds90ub960 9-003d: ee -> 0
    [12664.193055] ds90ub960 9-003d: ef -> 0
    [12664.193382] ds90ub960 9-003d: f0 -> 5f
    [12664.193598] ds90ub960 9-003d: f1 -> 55
    [12664.193772] ds90ub960 9-003d: f2 -> 42
    [12664.194298] ds90ub960 9-003d: f3 -> 39
    [12664.194500] ds90ub960 9-003d: f4 -> 36
    [12664.194686] ds90ub960 9-003d: f5 -> 30
    [12664.194871] ds90ub960 9-003d: f6 -> 0
    [12664.195055] ds90ub960 9-003d: f7 -> 0
    [12664.195240] ds90ub960 9-003d: f8 -> 0
    [12664.195430] ds90ub960 9-003d: f9 -> 0
    [12664.195611] ds90ub960 9-003d: fa -> 0
    [12664.195795] ds90ub960 9-003d: fb -> 0
    [12664.195981] ds90ub960 9-003d: fc -> 0
    [12664.196323] ds90ub960 9-003d: fd -> 0
    [12664.196509] ds90ub960 9-003d: fe -> 0
    [12664.196690] ds90ub960 9-003d: ff -> 0
    [12664.196873] ds90ub960 9-003d: 100 -> 7a
    [12664.197060] ds90ub960 9-003d: 101 -> 0
    [12664.197247] ds90ub960 9-003d: 102 -> 1e
    [12664.197431] ds90ub960 9-003d: 103 -> 40
    [12664.197623] ds90ub960 9-003d: 104 -> d0
    [12664.198250] ds90ub960 9-003d: 105 -> 1
    [12664.198462] ds90ub960 9-003d: 106 -> 0
    [12664.198681] ds90ub960 9-003d: 107 -> fe
    [12664.198907] ds90ub960 9-003d: 108 -> 1c
    [12664.199113] ds90ub960 9-003d: 109 -> 10
    [12664.199724] ds90ub960 9-003d: 10a -> 7a
    [12664.199921] ds90ub960 9-003d: 10b -> 7a
    [12664.200111] ds90ub960 9-003d: 10c -> 3
    [12664.200307] ds90ub960 9-003d: 10d -> b9
    [12664.200508] ds90ub960 9-003d: 10e -> 0
    [12664.200983] ds90ub960 9-003d: 10f -> ff
    [12664.201185] ds90ub960 9-003d: 110 -> 0
    [12664.201378] ds90ub960 9-003d: 111 -> 0
    [12664.201575] ds90ub960 9-003d: 112 -> 0
    [12664.201756] ds90ub960 9-003d: 113 -> 0
    [12664.202222] ds90ub960 9-003d: 114 -> 0
    [12664.202434] ds90ub960 9-003d: 115 -> 0
    [12664.202621] ds90ub960 9-003d: 116 -> 0
    [12664.202808] ds90ub960 9-003d: 117 -> 0
    [12664.202992] ds90ub960 9-003d: 118 -> 0
    [12664.203177] ds90ub960 9-003d: 119 -> 0
    [12664.203381] ds90ub960 9-003d: 11a -> 0
    [12664.203578] ds90ub960 9-003d: 11b -> 0
    [12664.203934] ds90ub960 9-003d: 11c -> 0
    [12664.204111] ds90ub960 9-003d: 11d -> 0
    [12664.204294] ds90ub960 9-003d: 11e -> 4
    [12664.204471] ds90ub960 9-003d: 11f -> 0
    [12664.204652] ds90ub960 9-003d: 120 -> c3
    [12664.204832] ds90ub960 9-003d: 121 -> 3
    [12664.205014] ds90ub960 9-003d: 122 -> 0
    [12664.205370] ds90ub960 9-003d: 123 -> 0
    [12664.205551] ds90ub960 9-003d: 124 -> 1
    [12664.205734] ds90ub960 9-003d: 125 -> 0
    [12664.206243] ds90ub960 9-003d: 126 -> 0
    [12664.206445] ds90ub960 9-003d: 127 -> 0
    [12664.206837] ds90ub960 9-003d: 128 -> 0
    [12664.207016] ds90ub960 9-003d: 129 -> 0
    [12664.207441] ds90ub960 9-003d: 12a -> 0
    [12664.207643] ds90ub960 9-003d: 12b -> 0
    [12664.207834] ds90ub960 9-003d: 12c -> 0
    [12664.208018] ds90ub960 9-003d: 12d -> 0
    [12664.208557] ds90ub960 9-003d: 12e -> 0
    [12664.208769] ds90ub960 9-003d: 12f -> 0
    [12664.208955] ds90ub960 9-003d: 130 -> 0
    [12664.209134] ds90ub960 9-003d: 131 -> 0
    [12664.209313] ds90ub960 9-003d: 132 -> 12
    [12664.209491] ds90ub960 9-003d: 133 -> 63
    [12664.210154] ds90ub960 9-003d: 134 -> 31
    [12664.210379] ds90ub960 9-003d: 135 -> 11
    [12664.210565] ds90ub960 9-003d: 136 -> 0
    [12664.210759] ds90ub960 9-003d: 137 -> 10
    [12664.210969] ds90ub960 9-003d: 138 -> 0
    [12664.211618] ds90ub960 9-003d: 139 -> 0
    [12664.211828] ds90ub960 9-003d: 13a -> 0
    [12664.212025] ds90ub960 9-003d: 13b -> 0
    [12664.212225] ds90ub960 9-003d: 13c -> 0
    [12664.212423] ds90ub960 9-003d: 13d -> 0
    [12664.212626] ds90ub960 9-003d: 13e -> 0
    [12664.212827] ds90ub960 9-003d: 13f -> 0
    [12664.213025] ds90ub960 9-003d: 140 -> 0
    [12664.213214] ds90ub960 9-003d: 141 -> a9
    [12664.213406] ds90ub960 9-003d: 142 -> 71
    [12664.213595] ds90ub960 9-003d: 143 -> 1
    [12664.213778] ds90ub960 9-003d: 144 -> 0
    [12664.214334] ds90ub960 9-003d: 145 -> 0
    [12664.214534] ds90ub960 9-003d: 146 -> 20
    [12664.214742] ds90ub960 9-003d: INTERRUPT_STS 1
    [12664.214929] ds90ub960 9-003d: 147 -> 0
    [12664.215106] ds90ub960 9-003d: 148 -> 0
    [12664.215323] ds90ub960 9-003d: FWD_STS 0x0
    [12664.215518] ds90ub960 9-003d: 149 -> 0
    [12664.215828] ds90ub960 9-003d: 14a -> 0
    [12664.216499] ds90ub960 9-003d: 14b -> 12
    [12664.216686] ds90ub960 9-003d: 14c -> 1
    [12664.217242] ds90ub960 9-003d: 14d -> 3
    [12664.217437] ds90ub960 9-003d: 14e -> 4
    [12664.217645] ds90ub960 9-003d: rx0 buffer error
    [12664.218149] ds90ub960 9-003d: 14f -> 64
    [12664.218361] ds90ub960 9-003d: 150 -> 0
    [12664.219052] ds90ub960 9-003d: 151 -> 0
    [12664.219260] ds90ub960 9-003d: 152 -> 0
    [12664.219456] ds90ub960 9-003d: 153 -> 2
    [12664.219639] ds90ub960 9-003d: 154 -> 0
    [12664.219820] ds90ub960 9-003d: 155 -> 0
    [12664.220008] ds90ub960 9-003d: 156 -> 0
    [12664.220323] ds90ub960 9-003d: 157 -> 0
    [12664.220504] ds90ub960 9-003d: 158 -> 5e
    [12664.220684] ds90ub960 9-003d: 159 -> 0
    [12664.220869] ds90ub960 9-003d: 15a -> 0
    [12664.221055] ds90ub960 9-003d: 15b -> 30
    [12664.221258] ds90ub960 9-003d: 15c -> 88
    [12664.221441] ds90ub960 9-003d: 15d -> c0
    [12664.222122] ds90ub960 9-003d: 15e -> 20
    [12664.222413] ds90ub960 9-003d: 15f -> 0
    [12664.222602] ds90ub960 9-003d: 160 -> 0
    [12664.222787] ds90ub960 9-003d: 161 -> 0
    [12664.222964] ds90ub960 9-003d: 162 -> 0
    [12664.223306] ds90ub960 9-003d: 163 -> 0
    [12664.223495] ds90ub960 9-003d: 164 -> 0
    [12664.223842] ds90ub960 9-003d: 165 -> 94
    [12664.224035] ds90ub960 9-003d: 166 -> 98
    [12664.224217] ds90ub960 9-003d: 167 -> 0
    [12664.224397] ds90ub960 9-003d: 168 -> 0
    [12664.224772] ds90ub960 9-003d: 169 -> 0
    [12664.224964] ds90ub960 9-003d: 16a -> 0
    [12664.225146] ds90ub960 9-003d: 16b -> 0
    [12664.225327] ds90ub960 9-003d: 16c -> 0
    [12664.225517] ds90ub960 9-003d: 16d -> 78
    [12664.225711] ds90ub960 9-003d: 16e -> 88
    [12664.226245] ds90ub960 9-003d: 16f -> 88
    [12664.226436] ds90ub960 9-003d: 170 -> 2b
    [12664.226619] ds90ub960 9-003d: 171 -> 2c
    [12664.226796] ds90ub960 9-003d: 172 -> 0
    [12664.227004] ds90ub960 9-003d: 173 -> 3
    [12664.227187] ds90ub960 9-003d: 174 -> 20
    [12664.227365] ds90ub960 9-003d: 175 -> 6
    [12664.227703] ds90ub960 9-003d: 176 -> 40
    [12664.227896] ds90ub960 9-003d: 177 -> c5
    [12664.228078] ds90ub960 9-003d: 178 -> 0
    [12664.228272] ds90ub960 9-003d: 179 -> 1
    [12664.228452] ds90ub960 9-003d: 17a -> 0
    [12664.228629] ds90ub960 9-003d: 17b -> 0
    [12664.228809] ds90ub960 9-003d: 17c -> 20
    [12664.229215] ds90ub960 9-003d: 17d -> 0
    [12664.229405] ds90ub960 9-003d: 17e -> 0
    [12664.229586] ds90ub960 9-003d: 17f -> 0
    [12664.229771] ds90ub960 9-003d: 180 -> 0
    [12664.230243] ds90ub960 9-003d: 181 -> 0
    [12664.230513] ds90ub960 9-003d: 182 -> 0
    [12664.230861] ds90ub960 9-003d: 183 -> 0
    [12664.231050] ds90ub960 9-003d: 184 -> 0
    [12664.231236] ds90ub960 9-003d: 185 -> 0
    [12664.231436] ds90ub960 9-003d: 186 -> 0
    [12664.231617] ds90ub960 9-003d: 187 -> 0
    [12664.231798] ds90ub960 9-003d: 188 -> 0
    [12664.232508] ds90ub960 9-003d: 189 -> 0
    [12664.232706] ds90ub960 9-003d: 18a -> 0
    [12664.232904] ds90ub960 9-003d: 18b -> 0
    [12664.233098] ds90ub960 9-003d: 18c -> 0
    [12664.233306] ds90ub960 9-003d: 18d -> 0
    [12664.233633] ds90ub960 9-003d: 18e -> 0
    [12664.234100] ds90ub960 9-003d: 18f -> 0
    [12664.234300] ds90ub960 9-003d: 190 -> 0
    [12664.234485] ds90ub960 9-003d: 191 -> 0
    [12664.234668] ds90ub960 9-003d: 192 -> 0
    [12664.234849] ds90ub960 9-003d: 193 -> 0
    [12664.235031] ds90ub960 9-003d: 194 -> 0
    [12664.235217] ds90ub960 9-003d: 195 -> 0
    [12664.235400] ds90ub960 9-003d: 196 -> 0
    [12664.235583] ds90ub960 9-003d: 197 -> 0
    [12664.235764] ds90ub960 9-003d: 198 -> 0
    [12664.235945] ds90ub960 9-003d: 199 -> 8
    [12664.236136] ds90ub960 9-003d: 19a -> 0
    [12664.236324] ds90ub960 9-003d: 19b -> 8
    [12664.237031] ds90ub960 9-003d: 19c -> 19
    [12664.237278] ds90ub960 9-003d: 19d -> 0
    [12664.237463] ds90ub960 9-003d: 19e -> 0
    [12664.237648] ds90ub960 9-003d: 19f -> 4
    [12664.238174] ds90ub960 9-003d: 1a0 -> 0
    [12664.238372] ds90ub960 9-003d: 1a1 -> 0
    [12664.238659] ds90ub960 9-003d: 1a2 -> 0
    [12664.238846] ds90ub960 9-003d: 1a3 -> 0
    [12664.239039] ds90ub960 9-003d: 1a4 -> 0
    [12664.239233] ds90ub960 9-003d: 1a5 -> 1c
    [12664.239428] ds90ub960 9-003d: 1a6 -> 0
    [12664.239769] ds90ub960 9-003d: 1a7 -> 0
    [12664.239955] ds90ub960 9-003d: 1a8 -> 0
    [12664.240287] ds90ub960 9-003d: 1a9 -> 0
    [12664.240506] ds90ub960 9-003d: 1aa -> 0
    [12664.240705] ds90ub960 9-003d: 1ab -> 0
    [12664.240897] ds90ub960 9-003d: 1ac -> 0
    [12664.241086] ds90ub960 9-003d: 1ad -> 0
    [12664.241271] ds90ub960 9-003d: 1ae -> 0
    [12664.241452] ds90ub960 9-003d: 1af -> 0
    [12664.241660] ds90ub960 9-003d: 1b0 -> 8
    [12664.242220] ds90ub960 9-003d: 1b1 -> 9
    [12664.242422] ds90ub960 9-003d: 1b2 -> 8
    [12664.242613] ds90ub960 9-003d: 1b3 -> 8
    [12664.242791] ds90ub960 9-003d: 1b4 -> 25
    [12664.242978] ds90ub960 9-003d: 1b5 -> 0
    [12664.243162] ds90ub960 9-003d: 1b6 -> 18
    [12664.243346] ds90ub960 9-003d: 1b7 -> 0
    [12664.243529] ds90ub960 9-003d: 1b8 -> f8
    [12664.243715] ds90ub960 9-003d: 1b9 -> 33
    [12664.243895] ds90ub960 9-003d: 1ba -> 83
    [12664.244074] ds90ub960 9-003d: 1bb -> 74
    [12664.244259] ds90ub960 9-003d: 1bc -> 80
    [12664.244444] ds90ub960 9-003d: 1bd -> 0
    [12664.244697] ds90ub960 9-003d: 1be -> 0
    [12664.244876] ds90ub960 9-003d: 1bf -> 0
    [12664.245055] ds90ub960 9-003d: 1c0 -> 0
    [12664.245235] ds90ub960 9-003d: 1c1 -> 0
    [12664.245419] ds90ub960 9-003d: 1c2 -> 0
    [12664.245605] ds90ub960 9-003d: 1c3 -> 0
    [12664.245786] ds90ub960 9-003d: 1c4 -> 0
    [12664.246309] ds90ub960 9-003d: 1c5 -> 0
    [12664.246548] ds90ub960 9-003d: 1c6 -> 0
    [12664.246744] ds90ub960 9-003d: 1c7 -> 0
    [12664.246924] ds90ub960 9-003d: 1c8 -> 0
    [12664.247104] ds90ub960 9-003d: 1c9 -> 0
    [12664.247287] ds90ub960 9-003d: 1ca -> 0
    [12664.247468] ds90ub960 9-003d: 1cb -> 0
    [12664.247654] ds90ub960 9-003d: 1cc -> 0
    [12664.247836] ds90ub960 9-003d: 1cd -> 0
    [12664.248019] ds90ub960 9-003d: 1ce -> 0
    [12664.248218] ds90ub960 9-003d: 1cf -> 0
    [12664.248406] ds90ub960 9-003d: 1d0 -> 0
    [12664.248606] ds90ub960 9-003d: 1d1 -> 43
    [12664.248814] ds90ub960 9-003d: 1d2 -> 94
    [12664.249004] ds90ub960 9-003d: 1d3 -> 0
    [12664.249199] ds90ub960 9-003d: 1d4 -> 60
    [12664.249388] ds90ub960 9-003d: 1d5 -> e0
    [12664.249588] ds90ub960 9-003d: 1d6 -> 0
    [12664.249792] ds90ub960 9-003d: 1d7 -> 2
    [12664.250363] ds90ub960 9-003d: 1d8 -> 7
    [12664.250606] ds90ub960 9-003d: 1d9 -> 7f
    [12664.250786] ds90ub960 9-003d: 1da -> 0
    [12664.250966] ds90ub960 9-003d: 1db -> 10
    [12664.251146] ds90ub960 9-003d: 1dc -> 0
    [12664.251328] ds90ub960 9-003d: 1dd -> 0
    [12664.251510] ds90ub960 9-003d: 1de -> 0
    [12664.251696] ds90ub960 9-003d: 1df -> 0
    [12664.251880] ds90ub960 9-003d: 1e0 -> 0
    [12664.252093] ds90ub960 9-003d: 1e1 -> 0
    [12664.252277] ds90ub960 9-003d: 1e2 -> 0
    [12664.252462] ds90ub960 9-003d: 1e3 -> 0
    [12664.252644] ds90ub960 9-003d: 1e4 -> 0
    [12664.252826] ds90ub960 9-003d: 1e5 -> 0
    [12664.253006] ds90ub960 9-003d: 1e6 -> 0
    [12664.253190] ds90ub960 9-003d: 1e7 -> 0
    [12664.253369] ds90ub960 9-003d: 1e8 -> 0
    [12664.253549] ds90ub960 9-003d: 1e9 -> 0
    [12664.253730] ds90ub960 9-003d: 1ea -> 0
    [12664.254224] ds90ub960 9-003d: 1eb -> 0
    [12664.254431] ds90ub960 9-003d: 1ec -> 0
    [12664.254625] ds90ub960 9-003d: 1ed -> 0
    [12664.254821] ds90ub960 9-003d: 1ee -> 0
    [12664.255044] ds90ub960 9-003d: 1ef -> 0
    [12664.255234] ds90ub960 9-003d: 1f0 -> 5f
    [12664.255420] ds90ub960 9-003d: 1f1 -> 55
    [12664.255602] ds90ub960 9-003d: 1f2 -> 42
    [12664.255793] ds90ub960 9-003d: 1f3 -> 39
    [12664.255996] ds90ub960 9-003d: 1f4 -> 36
    [12664.256203] ds90ub960 9-003d: 1f5 -> 30
    [12664.256396] ds90ub960 9-003d: 1f6 -> 0
    [12664.256847] ds90ub960 9-003d: 1f7 -> 0
    [12664.257051] ds90ub960 9-003d: 1f8 -> 0
    [12664.257241] ds90ub960 9-003d: 1f9 -> 0
    [12664.257606] ds90ub960 9-003d: 1fa -> 0
    [12664.257797] ds90ub960 9-003d: 1fb -> 0
    [12664.258338] ds90ub960 9-003d: 1fc -> 0
    [12664.258613] ds90ub960 9-003d: 1fd -> 0
    [12664.258800] ds90ub960 9-003d: 1fe -> 0
    [12664.259146] ds90ub960 9-003d: 1ff -> 0
    [12664.259332] ds90ub960 9-003d: 200 -> 7a
    [12664.259516] ds90ub960 9-003d: 201 -> 0
    [12664.259692] ds90ub960 9-003d: 202 -> 1e
    [12664.259875] ds90ub960 9-003d: 203 -> 40
    [12664.260057] ds90ub960 9-003d: 204 -> d0
    [12664.260240] ds90ub960 9-003d: 205 -> 1
    [12664.260422] ds90ub960 9-003d: 206 -> 0
    [12664.260600] ds90ub960 9-003d: 207 -> fe
    [12664.260786] ds90ub960 9-003d: 208 -> 1c
    [12664.260972] ds90ub960 9-003d: 209 -> 10
    [12664.261153] ds90ub960 9-003d: 20a -> 7a
    [12664.261334] ds90ub960 9-003d: 20b -> 7a
    [12664.261531] ds90ub960 9-003d: 20c -> 3
    [12664.261721] ds90ub960 9-003d: 20d -> b9
    [12664.262550] ds90ub960 9-003d: 20e -> 0
    [12664.262756] ds90ub960 9-003d: 20f -> ff
    [12664.262955] ds90ub960 9-003d: 210 -> 0
    [12664.263146] ds90ub960 9-003d: 211 -> 0
    [12664.263329] ds90ub960 9-003d: 212 -> 0
    [12664.263553] ds90ub960 9-003d: 213 -> 0
    [12664.263740] ds90ub960 9-003d: 214 -> 0
    [12664.263922] ds90ub960 9-003d: 215 -> 0
    [12664.264102] ds90ub960 9-003d: 216 -> 0
    [12664.264284] ds90ub960 9-003d: 217 -> 0
    [12664.264467] ds90ub960 9-003d: 218 -> 0
    [12664.264650] ds90ub960 9-003d: 219 -> 0
    [12664.264832] ds90ub960 9-003d: 21a -> 0
    [12664.265014] ds90ub960 9-003d: 21b -> 0
    [12664.265195] ds90ub960 9-003d: 21c -> 0
    [12664.265377] ds90ub960 9-003d: 21d -> 0
    [12664.265559] ds90ub960 9-003d: 21e -> 4
    [12664.265750] ds90ub960 9-003d: 21f -> 0
    [12664.266179] ds90ub960 9-003d: 220 -> c3
    [12664.266565] ds90ub960 9-003d: 221 -> 3
    [12664.266795] ds90ub960 9-003d: 222 -> 0
    [12664.266981] ds90ub960 9-003d: 223 -> 0
    [12664.267167] ds90ub960 9-003d: 224 -> 1
    [12664.267361] ds90ub960 9-003d: 225 -> 0
    [12664.267541] ds90ub960 9-003d: 226 -> 0
    [12664.267718] ds90ub960 9-003d: 227 -> 0
    [12664.268061] ds90ub960 9-003d: 228 -> 0
    [12664.268249] ds90ub960 9-003d: 229 -> 0
    [12664.268432] ds90ub960 9-003d: 22a -> 0
    [12664.268619] ds90ub960 9-003d: 22b -> 0
    [12664.268802] ds90ub960 9-003d: 22c -> 0
    [12664.268988] ds90ub960 9-003d: 22d -> 0
    [12664.269192] ds90ub960 9-003d: 22e -> 0
    [12664.269529] ds90ub960 9-003d: 22f -> 0
    [12664.269710] ds90ub960 9-003d: 230 -> 0
    [12664.270230] ds90ub960 9-003d: 231 -> 0
    [12664.270479] ds90ub960 9-003d: 232 -> 12
    [12664.270663] ds90ub960 9-003d: 233 -> 63
    [12664.270849] ds90ub960 9-003d: 234 -> 31
    [12664.271183] ds90ub960 9-003d: 235 -> 11
    [12664.271383] ds90ub960 9-003d: 236 -> 0
    [12664.271586] ds90ub960 9-003d: 237 -> 10
    [12664.271765] ds90ub960 9-003d: 238 -> 0
    [12664.271945] ds90ub960 9-003d: 239 -> 0
    [12664.272124] ds90ub960 9-003d: 23a -> 0
    [12664.272485] ds90ub960 9-003d: 23b -> 0
    [12664.272666] ds90ub960 9-003d: 23c -> 0
    [12664.272850] ds90ub960 9-003d: 23d -> 0
    [12664.273029] ds90ub960 9-003d: 23e -> 0
    [12664.273219] ds90ub960 9-003d: 23f -> 0
    [12664.273400] ds90ub960 9-003d: 240 -> 0
    [12664.273581] ds90ub960 9-003d: 241 -> a9
    [12664.273765] ds90ub960 9-003d: 242 -> 71
    [12664.274285] ds90ub960 9-003d: 243 -> 1
    [12664.274659] ds90ub960 9-003d: 244 -> 0
    [12664.274843] ds90ub960 9-003d: 245 -> 0
    [12664.275022] ds90ub960 9-003d: 246 -> 20
    [12664.275201] ds90ub960 9-003d: 247 -> 0
    [12664.275547] ds90ub960 9-003d: 248 -> 0
    [12664.275737] ds90ub960 9-003d: 249 -> 0
    [12664.275921] ds90ub960 9-003d: 24a -> 0
    [12664.276099] ds90ub960 9-003d: 24b -> 12
    [12664.276285] ds90ub960 9-003d: 24c -> 1
    [12664.276476] ds90ub960 9-003d: 24d -> 3
    [12664.276656] ds90ub960 9-003d: 24e -> 14
    [12664.276973] ds90ub960 9-003d: 24f -> 64
    [12664.277180] ds90ub960 9-003d: 250 -> 0
    [12664.277368] ds90ub960 9-003d: 251 -> 0
    [12664.277553] ds90ub960 9-003d: 252 -> 0
    [12664.277729] ds90ub960 9-003d: 253 -> 2
    [12664.278207] ds90ub960 9-003d: 254 -> 0
    [12664.278212] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    [12664.278215] ds90ub960 9-003d: Rx port0 specific reg
    [12664.278768] ds90ub960 9-003d: 46 -> 20
    [12664.278982] ds90ub960 9-003d: 47 -> 0
    [12664.279162] ds90ub960 9-003d: 48 -> 0
    [12664.279364] ds90ub960 9-003d: 49 -> 0
    [12664.279551] ds90ub960 9-003d: 4a -> 0
    [12664.279753] ds90ub960 9-003d: 4b -> 12
    [12664.280071] ds90ub960 9-003d: 4c -> 1
    [12664.280254] ds90ub960 9-003d: 4d -> 3
    [12664.280438] ds90ub960 9-003d: 4e -> 14
    [12664.280625] ds90ub960 9-003d: 4f -> 64
    [12664.280810] ds90ub960 9-003d: 50 -> 0
    [12664.280997] ds90ub960 9-003d: 51 -> 0
    [12664.281186] ds90ub960 9-003d: 52 -> 0
    [12664.281486] ds90ub960 9-003d: 53 -> 2
    [12664.281675] ds90ub960 9-003d: 54 -> 0
    [12664.282267] ds90ub960 9-003d: 55 -> 0
    [12664.282470] ds90ub960 9-003d: 56 -> 0
    [12664.282657] ds90ub960 9-003d: 57 -> 0
    [12664.282841] ds90ub960 9-003d: 58 -> 5e
    [12664.283024] ds90ub960 9-003d: 59 -> 0
    [12664.283206] ds90ub960 9-003d: 5a -> 0
    [12664.283437] ds90ub960 9-003d: 5b -> 30
    [12664.283624] ds90ub960 9-003d: 5c -> 88
    [12664.283804] ds90ub960 9-003d: 5d -> c0
    [12664.283986] ds90ub960 9-003d: 5e -> 20
    [12664.284167] ds90ub960 9-003d: 5f -> 0
    [12664.284515] ds90ub960 9-003d: 60 -> 0
    [12664.284700] ds90ub960 9-003d: 61 -> 0
    [12664.284921] ds90ub960 9-003d: 62 -> 0
    [12664.285114] ds90ub960 9-003d: 63 -> 0
    [12664.285307] ds90ub960 9-003d: 64 -> 0
    [12664.285492] ds90ub960 9-003d: 65 -> 94
    [12664.285683] ds90ub960 9-003d: 66 -> 98
    [12664.286331] ds90ub960 9-003d: 67 -> 0
    [12664.286575] ds90ub960 9-003d: 68 -> 0
    [12664.286759] ds90ub960 9-003d: 69 -> 0
    [12664.286942] ds90ub960 9-003d: 6a -> 0
    [12664.287122] ds90ub960 9-003d: 6b -> 0
    [12664.287502] ds90ub960 9-003d: 6c -> 0
    [12664.287683] ds90ub960 9-003d: 6d -> 78
    [12664.287877] ds90ub960 9-003d: 6e -> 88
    [12664.288056] ds90ub960 9-003d: 6f -> 88
    [12664.288231] ds90ub960 9-003d: 70 -> 2b
    [12664.288417] ds90ub960 9-003d: 71 -> 2c
    [12664.288599] ds90ub960 9-003d: 72 -> 0
    [12664.288951] ds90ub960 9-003d: 73 -> 3
    [12664.289129] ds90ub960 9-003d: 74 -> 20
    [12664.289315] ds90ub960 9-003d: 75 -> 6
    [12664.289500] ds90ub960 9-003d: 76 -> 40
    [12664.289684] ds90ub960 9-003d: 77 -> c5
    [12664.290182] ds90ub960 9-003d: 78 -> 0
    [12664.290588] ds90ub960 9-003d: 79 -> 1
    [12664.290771] ds90ub960 9-003d: 7a -> 0
    [12664.290954] ds90ub960 9-003d: 7b -> 0
    [12664.291143] ds90ub960 9-003d: 7c -> 20
    [12664.291327] ds90ub960 9-003d: 7d -> 0
    [12664.291506] ds90ub960 9-003d: 7e -> 0
    [12664.291508] ds90ub960 9-003d: Rx port0 specific debug reg
    [12664.291700] ds90ub960 9-003d: d0 -> 0
    [12664.292031] ds90ub960 9-003d: d1 -> 43
    [12664.292213] ds90ub960 9-003d: d2 -> 94
    [12664.292397] ds90ub960 9-003d: d3 -> 0
    [12664.292574] ds90ub960 9-003d: d4 -> 60
    [12664.292749] ds90ub960 9-003d: d5 -> e0
    [12664.292926] ds90ub960 9-003d: d6 -> 0
    [12664.293103] ds90ub960 9-003d: d7 -> 2
    [12664.293502] ds90ub960 9-003d: d8 -> 7
    [12664.293680] ds90ub960 9-003d: d9 -> 7f
    [12664.294211] ds90ub960 9-003d: da -> 0
    [12664.294414] ds90ub960 9-003d: db -> 0
    [12664.294642] ds90ub960 9-003d: dc -> 0
    [12664.295012] ds90ub960 9-003d: dd -> 0
    [12664.295197] ds90ub960 9-003d: de -> 0
    [12664.295200] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    [12664.295202] ds90ub960 9-003d: Rx port1 specific reg
    [12664.295513] ds90ub960 9-003d: 46 -> 20
    [12664.295714] ds90ub960 9-003d: 47 -> 0
    [12664.296073] ds90ub960 9-003d: 48 -> 0
    [12664.296461] ds90ub960 9-003d: 49 -> 0
    [12664.296660] ds90ub960 9-003d: 4a -> 0
    [12664.296855] ds90ub960 9-003d: 4b -> 12
    [12664.297058] ds90ub960 9-003d: 4c -> 12
    [12664.297242] ds90ub960 9-003d: 4d -> 43
    [12664.297426] ds90ub960 9-003d: 4e -> 4
    [12664.297606] ds90ub960 9-003d: 4f -> 64
    [12664.298257] ds90ub960 9-003d: 50 -> 0
    [12664.298455] ds90ub960 9-003d: 51 -> 0
    [12664.298644] ds90ub960 9-003d: 52 -> 0
    [12664.298829] ds90ub960 9-003d: 53 -> 3
    [12664.299010] ds90ub960 9-003d: 54 -> 0
    [12664.299190] ds90ub960 9-003d: 55 -> 0
    [12664.299369] ds90ub960 9-003d: 56 -> 0
    [12664.299548] ds90ub960 9-003d: 57 -> 0
    [12664.299732] ds90ub960 9-003d: 58 -> 5e
    [12664.299914] ds90ub960 9-003d: 59 -> 0
    [12664.300099] ds90ub960 9-003d: 5a -> 0
    [12664.300283] ds90ub960 9-003d: 5b -> 30
    [12664.300463] ds90ub960 9-003d: 5c -> 8a
    [12664.300648] ds90ub960 9-003d: 5d -> c0
    [12664.300832] ds90ub960 9-003d: 5e -> 20
    [12664.301016] ds90ub960 9-003d: 5f -> 0
    [12664.301199] ds90ub960 9-003d: 60 -> 0
    [12664.301384] ds90ub960 9-003d: 61 -> 0
    [12664.301571] ds90ub960 9-003d: 62 -> 0
    [12664.301756] ds90ub960 9-003d: 63 -> 0
    [12664.302261] ds90ub960 9-003d: 64 -> 0
    [12664.302461] ds90ub960 9-003d: 65 -> 96
    [12664.302675] ds90ub960 9-003d: 66 -> 9a
    [12664.302860] ds90ub960 9-003d: 67 -> 0
    [12664.303044] ds90ub960 9-003d: 68 -> 0
    [12664.303227] ds90ub960 9-003d: 69 -> 0
    [12664.303404] ds90ub960 9-003d: 6a -> 0
    [12664.303581] ds90ub960 9-003d: 6b -> 0
    [12664.303761] ds90ub960 9-003d: 6c -> 0
    [12664.303942] ds90ub960 9-003d: 6d -> 78
    [12664.304119] ds90ub960 9-003d: 6e -> 88
    [12664.304298] ds90ub960 9-003d: 6f -> 88
    [12664.304484] ds90ub960 9-003d: 70 -> 6b
    [12664.304664] ds90ub960 9-003d: 71 -> 6c
    [12664.304842] ds90ub960 9-003d: 72 -> 55
    [12664.305021] ds90ub960 9-003d: 73 -> 3
    [12664.305201] ds90ub960 9-003d: 74 -> 20
    [12664.305380] ds90ub960 9-003d: 75 -> 6
    [12664.305556] ds90ub960 9-003d: 76 -> 40
    [12664.305736] ds90ub960 9-003d: 77 -> c5
    [12664.306295] ds90ub960 9-003d: 78 -> 0
    [12664.306493] ds90ub960 9-003d: 79 -> 1
    [12664.306674] ds90ub960 9-003d: 7a -> 0
    [12664.306856] ds90ub960 9-003d: 7b -> 0
    [12664.307038] ds90ub960 9-003d: 7c -> 20
    [12664.307223] ds90ub960 9-003d: 7d -> 0
    [12664.307408] ds90ub960 9-003d: 7e -> 0
    [12664.307411] ds90ub960 9-003d: Rx port1 specific debug reg
    [12664.307591] ds90ub960 9-003d: d0 -> 0
    [12664.307770] ds90ub960 9-003d: d1 -> 43
    [12664.307951] ds90ub960 9-003d: d2 -> 94
    [12664.308134] ds90ub960 9-003d: d3 -> 0
    [12664.308316] ds90ub960 9-003d: d4 -> 60
    [12664.308498] ds90ub960 9-003d: d5 -> e0
    [12664.308677] ds90ub960 9-003d: d6 -> 0
    [12664.308860] ds90ub960 9-003d: d7 -> 2
    [12664.309044] ds90ub960 9-003d: d8 -> 7
    [12664.309224] ds90ub960 9-003d: d9 -> 7f
    [12664.309404] ds90ub960 9-003d: da -> 0
    [12664.309584] ds90ub960 9-003d: db -> 0
    [12664.309764] ds90ub960 9-003d: dc -> 0
    [12664.310279] ds90ub960 9-003d: dd -> 0
    [12664.310473] ds90ub960 9-003d: de -> 0
    [12664.310477] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    [12664.310479] ds90ub960 9-003d: Tx port1 specific reg
    [12664.310669] ds90ub960 9-003d: 33 -> 63
    [12664.310864] ds90ub960 9-003d: 34 -> 31
    [12664.311059] ds90ub960 9-003d: 35 -> 11
    [12664.311255] ds90ub960 9-003d: 36 -> 0
    [12664.311450] ds90ub960 9-003d: 37 -> 10
    [12664.311641] ds90ub960 9-003d: 38 -> 0
    [12664.311833] ds90ub960 9-003d: 39 -> 0
    [12664.311836] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    I will send serialiser dump soon
    thanks,
    Kayas
  • Hello Hamzeh,
    Attaching both the reg dump when the issue was happening
    For ds90ub953
    [  152.646537] ds90ub953 9-0044: 0 -> 30
    [  152.649449] ds90ub953 9-0044: 1 -> 0
    [  152.650232] ds90ub953 9-0044: 2 -> 52
    [  152.651425] ds90ub953 9-0044: 3 -> 48
    [  152.651637] ds90ub953 9-0044: 4 -> 0
    [  152.651831] ds90ub953 9-0044: 5 -> 3
    [  152.652015] ds90ub953 9-0044: 6 -> 41
    [  152.652206] ds90ub953 9-0044: 7 -> ff
    [  152.652501] ds90ub953 9-0044: 8 -> fe
    [  152.652708] ds90ub953 9-0044: 9 -> 1e
    [  152.652914] ds90ub953 9-0044: a -> 10
    [  152.653620] ds90ub953 9-0044: b -> 13
    [  152.653899] ds90ub953 9-0044: c -> 26
    [  152.654240] ds90ub953 9-0044: d -> 0
    [  152.654438] ds90ub953 9-0044: e -> f
    [  152.654647] ds90ub953 9-0044: f -> 0
    [  152.654836] ds90ub953 9-0044: 10 -> 0
    [  152.655211] ds90ub953 9-0044: 11 -> 0
    [  152.655579] ds90ub953 9-0044: 12 -> 0
    [  152.656179] ds90ub953 9-0044: 13 -> 0
    [  152.656387] ds90ub953 9-0044: 14 -> 0
    [  152.656586] ds90ub953 9-0044: 15 -> 20
    [  152.656786] ds90ub953 9-0044: 16 -> 18
    [  152.657003] ds90ub953 9-0044: 17 -> 3c
    [  152.657503] ds90ub953 9-0044: 18 -> 80
    [  152.658018] ds90ub953 9-0044: 19 -> 62
    [  152.658241] ds90ub953 9-0044: 1a -> 62
    [  152.658440] ds90ub953 9-0044: 1b -> 62
    [  152.658630] ds90ub953 9-0044: 1c -> 0
    [  152.658813] ds90ub953 9-0044: 1d -> 0
    [  152.659005] ds90ub953 9-0044: 1e -> 0
    [  152.659206] ds90ub953 9-0044: 1f -> 0
    [  152.659392] ds90ub953 9-0044: 20 -> 0
    [  152.659586] ds90ub953 9-0044: 21 -> 0
    [  152.659778] ds90ub953 9-0044: 22 -> 0
    [  152.660114] ds90ub953 9-0044: 23 -> 0
    [  152.660316] ds90ub953 9-0044: 24 -> 0
    [  152.660518] ds90ub953 9-0044: 25 -> 2
    [  152.660711] ds90ub953 9-0044: 26 -> 0
    [  152.660899] ds90ub953 9-0044: 27 -> 0
    [  152.661620] ds90ub953 9-0044: 28 -> 67
    [  152.661897] ds90ub953 9-0044: 29 -> 33
    [  152.662088] ds90ub953 9-0044: 2a -> 1
    [  152.662275] ds90ub953 9-0044: 2b -> 0
    [  152.662467] ds90ub953 9-0044: 2c -> 0
    [  152.662657] ds90ub953 9-0044: 2d -> 0
    [  152.663225] ds90ub953 9-0044: 2e -> 0
    [  152.663427] ds90ub953 9-0044: 2f -> 0
    [  152.663612] ds90ub953 9-0044: 30 -> 0
    [  152.663813] ds90ub953 9-0044: 31 -> 20
    [  152.664000] ds90ub953 9-0044: 32 -> 9
    [  152.664198] ds90ub953 9-0044: 33 -> 4
    [  152.664912] ds90ub953 9-0044: 34 -> 0
    [  152.665531] ds90ub953 9-0044: 35 -> 10
    [  152.665765] ds90ub953 9-0044: 36 -> 0
    [  152.666063] ds90ub953 9-0044: 37 -> 7a
    [  152.666259] ds90ub953 9-0044: 38 -> 0
    [  152.666449] ds90ub953 9-0044: 39 -> 0
    [  152.666646] ds90ub953 9-0044: 3a -> 0
    [  152.666850] ds90ub953 9-0044: 3b -> 0
    [  152.667066] ds90ub953 9-0044: 3c -> 0
    [  152.667269] ds90ub953 9-0044: 3d -> 0
    [  152.667515] ds90ub953 9-0044: 3e -> 0
    [  152.667701] ds90ub953 9-0044: 3f -> 0
    [  152.668062] ds90ub953 9-0044: 40 -> 0
    [  152.668245] ds90ub953 9-0044: 41 -> 0
    [  152.668436] ds90ub953 9-0044: 42 -> 0
    [  152.668628] ds90ub953 9-0044: 43 -> 0
    [  152.669004] ds90ub953 9-0044: 44 -> 0
    [  152.669579] ds90ub953 9-0044: 45 -> 0
    [  152.669826] ds90ub953 9-0044: 46 -> 0
    [  152.670164] ds90ub953 9-0044: 47 -> 0
    [  152.670363] ds90ub953 9-0044: 48 -> 0
    [  152.670769] ds90ub953 9-0044: 49 -> 0
    [  152.670973] ds90ub953 9-0044: 4a -> 0
    [  152.671161] ds90ub953 9-0044: 4b -> 0
    [  152.671499] ds90ub953 9-0044: 4c -> 0
    [  152.671868] ds90ub953 9-0044: 4d -> 0
    [  152.672069] ds90ub953 9-0044: 4e -> 0
    [  152.672265] ds90ub953 9-0044: 4f -> 0
    [  152.672619] ds90ub953 9-0044: 50 -> 20
    [  152.672997] ds90ub953 9-0044: 51 -> c0
    [  152.673528] ds90ub953 9-0044: 52 -> 47
    [  152.673754] ds90ub953 9-0044: 53 -> 0
    [  152.673952] ds90ub953 9-0044: 54 -> 0
    [  152.674286] ds90ub953 9-0044: 55 -> 3
    [  152.674495] ds90ub953 9-0044: 56 -> 0
    [  152.674695] ds90ub953 9-0044: 57 -> 0
    [  152.674891] ds90ub953 9-0044: 58 -> 7
    [  152.675088] ds90ub953 9-0044: 59 -> 7
    [  152.675295] ds90ub953 9-0044: 5a -> 7
    [  152.675485] ds90ub953 9-0044: 5b -> 0
    [  152.675682] ds90ub953 9-0044: 5c -> 0
    [  152.675889] ds90ub953 9-0044: 5d -> 0
    [  152.676085] ds90ub953 9-0044: 5e -> 0
    [  152.676499] ds90ub953 9-0044: 5f -> 0
    [  152.676733] ds90ub953 9-0044: 60 -> 0
    [  152.676968] ds90ub953 9-0044: 61 -> 2b
    [  152.677582] ds90ub953 9-0044: 62 -> 40
    [  152.677944] ds90ub953 9-0044: 63 -> 6
    [  152.678174] ds90ub953 9-0044: 64 -> 3b
    [  152.678363] ds90ub953 9-0044: 65 -> c8
    [  152.678558] ds90ub953 9-0044: 66 -> 0
    [  152.678752] ds90ub953 9-0044: 67 -> 0
    [  152.678945] ds90ub953 9-0044: 68 -> 0
    [  152.679146] ds90ub953 9-0044: 69 -> 0
    [  152.679537] ds90ub953 9-0044: 6a -> 0
    [  152.679738] ds90ub953 9-0044: 6b -> 0
    [  152.679930] ds90ub953 9-0044: 6c -> 0
    [  152.680121] ds90ub953 9-0044: 6d -> 0
    [  152.680387] ds90ub953 9-0044: 6e -> 0
    [  152.680576] ds90ub953 9-0044: 6f -> 0
    [  152.680768] ds90ub953 9-0044: 70 -> 0
    [  152.681559] ds90ub953 9-0044: 71 -> 0
    [  152.681757] ds90ub953 9-0044: 72 -> 25
    [  152.681962] ds90ub953 9-0044: 73 -> 0
    [  152.682166] ds90ub953 9-0044: 74 -> 0
    [  152.682491] ds90ub953 9-0044: 75 -> 0
    [  152.682675] ds90ub953 9-0044: 76 -> 0
    [  152.682872] ds90ub953 9-0044: 77 -> 0
    [  152.683069] ds90ub953 9-0044: 78 -> 0
    [  152.683272] ds90ub953 9-0044: 79 -> 0
    [  152.683461] ds90ub953 9-0044: 7a -> e4
    [  152.683645] ds90ub953 9-0044: 7b -> 0
    [  152.684023] ds90ub953 9-0044: 7c -> 0
    [  152.684206] ds90ub953 9-0044: 7d -> 0
    [  152.684394] ds90ub953 9-0044: 7e -> 0
    [  152.684584] ds90ub953 9-0044: 7f -> 0
    [  152.684769] ds90ub953 9-0044: 80 -> 0
    [  152.684955] ds90ub953 9-0044: 81 -> 0
    [  152.685554] ds90ub953 9-0044: 82 -> 0
    [  152.685755] ds90ub953 9-0044: 83 -> 0
    [  152.685947] ds90ub953 9-0044: 84 -> 0
    [  152.686141] ds90ub953 9-0044: 85 -> 0
    [  152.686332] ds90ub953 9-0044: 86 -> 90
    [  152.686524] ds90ub953 9-0044: 87 -> 0
    [  152.686917] ds90ub953 9-0044: 88 -> 0
    [  152.687115] ds90ub953 9-0044: 89 -> 0
    [  152.687307] ds90ub953 9-0044: 8a -> 0
    [  152.687505] ds90ub953 9-0044: 8b -> 0
    [  152.687701] ds90ub953 9-0044: 8c -> 5
    [  152.687888] ds90ub953 9-0044: 8d -> 0
    [  152.688080] ds90ub953 9-0044: 8e -> 0
    [  152.688272] ds90ub953 9-0044: 8f -> 0
    [  152.688465] ds90ub953 9-0044: 90 -> 32
    [  152.688656] ds90ub953 9-0044: 91 -> e3
    [  152.688840] ds90ub953 9-0044: 92 -> 64
    [  152.689028] ds90ub953 9-0044: 93 -> 1
    [  152.689645] ds90ub953 9-0044: 94 -> 0
    [  152.689845] ds90ub953 9-0044: 95 -> 0
    [  152.690032] ds90ub953 9-0044: 96 -> 0
    [  152.690219] ds90ub953 9-0044: 97 -> 0
    [  152.690448] ds90ub953 9-0044: 98 -> 0
    [  152.690806] ds90ub953 9-0044: 99 -> 0
    [  152.691006] ds90ub953 9-0044: 9a -> 28
    [  152.691200] ds90ub953 9-0044: 9b -> 23
    [  152.691395] ds90ub953 9-0044: 9c -> 2
    [  152.691583] ds90ub953 9-0044: 9d -> 7
    [  152.691775] ds90ub953 9-0044: 9e -> 1
    [  152.691961] ds90ub953 9-0044: 9f -> d
    [  152.692148] ds90ub953 9-0044: a0 -> 0
    [  152.692338] ds90ub953 9-0044: a1 -> d
    [  152.692533] ds90ub953 9-0044: a2 -> c
    [  152.692727] ds90ub953 9-0044: a3 -> d
    [  152.692913] ds90ub953 9-0044: a4 -> b
    [  152.693331] ds90ub953 9-0044: a5 -> 10
    [  152.693579] ds90ub953 9-0044: a6 -> 42
    [  152.693799] ds90ub953 9-0044: a7 -> 10
    [  152.693986] ds90ub953 9-0044: a8 -> 10
    [  152.694170] ds90ub953 9-0044: a9 -> 10
    [  152.694351] ds90ub953 9-0044: aa -> 3
    [  152.694557] ds90ub953 9-0044: ab -> 1
    [  152.695235] ds90ub953 9-0044: ac -> 0
    [  152.695448] ds90ub953 9-0044: ad -> 0
    [  152.695648] ds90ub953 9-0044: ae -> 0
    [  152.696128] ds90ub953 9-0044: af -> 0
    [  152.696558] ds90ub953 9-0044: b0 -> 4
    [  152.696752] ds90ub953 9-0044: b1 -> 4a
    [  152.696943] ds90ub953 9-0044: b2 -> 3f
    [  152.697427] ds90ub953 9-0044: b3 -> 0
    [  152.697633] ds90ub953 9-0044: b4 -> 0
    [  152.697824] ds90ub953 9-0044: b5 -> 0
    [  152.698073] ds90ub953 9-0044: b6 -> 0
    [  152.698270] ds90ub953 9-0044: b7 -> 0
    [  152.698461] ds90ub953 9-0044: b8 -> 0
    [  152.698825] ds90ub953 9-0044: b9 -> 0
    [  152.699020] ds90ub953 9-0044: ba -> 0
    [  152.699434] ds90ub953 9-0044: bb -> 0
    [  152.699628] ds90ub953 9-0044: bc -> 0
    [  152.700005] ds90ub953 9-0044: bd -> 0
    [  152.700211] ds90ub953 9-0044: be -> 0
    [  152.700400] ds90ub953 9-0044: bf -> 0
    [  152.700590] ds90ub953 9-0044: c0 -> 0
    [  152.700782] ds90ub953 9-0044: c1 -> 0
    [  152.700972] ds90ub953 9-0044: c2 -> 0
    [  152.701604] ds90ub953 9-0044: c3 -> 0
    [  152.701815] ds90ub953 9-0044: c4 -> 0
    [  152.702007] ds90ub953 9-0044: c5 -> 0
    [  152.702202] ds90ub953 9-0044: c6 -> 0
    [  152.702401] ds90ub953 9-0044: c7 -> 0
    [  152.702602] ds90ub953 9-0044: c8 -> 0
    [  152.702798] ds90ub953 9-0044: c9 -> 0
    [  152.702991] ds90ub953 9-0044: ca -> 0
    [  152.703193] ds90ub953 9-0044: cb -> 0
    [  152.703407] ds90ub953 9-0044: cc -> 0
    [  152.703606] ds90ub953 9-0044: cd -> 0
    [  152.703797] ds90ub953 9-0044: ce -> 0
    [  152.704116] ds90ub953 9-0044: cf -> 0
    [  152.704310] ds90ub953 9-0044: d0 -> 0
    [  152.704494] ds90ub953 9-0044: d1 -> 0
    [  152.705010] ds90ub953 9-0044: d2 -> 0
    [  152.705626] ds90ub953 9-0044: d3 -> 0
    [  152.705876] ds90ub953 9-0044: d4 -> 0
    [  152.706077] ds90ub953 9-0044: d5 -> 0
    [  152.706276] ds90ub953 9-0044: d6 -> 0
    [  152.706467] ds90ub953 9-0044: d7 -> 0
    [  152.706669] ds90ub953 9-0044: d8 -> 0
    [  152.706867] ds90ub953 9-0044: d9 -> 0
    [  152.707074] ds90ub953 9-0044: da -> 0
    [  152.707297] ds90ub953 9-0044: db -> 0
    [  152.707494] ds90ub953 9-0044: dc -> 0
    [  152.707986] ds90ub953 9-0044: dd -> 0
    [  152.708187] ds90ub953 9-0044: de -> 0
    [  152.708389] ds90ub953 9-0044: df -> 0
    [  152.708581] ds90ub953 9-0044: e0 -> 0
    [  152.708773] ds90ub953 9-0044: e1 -> 0
    [  152.708970] ds90ub953 9-0044: e2 -> 0
    [  152.709539] ds90ub953 9-0044: e3 -> 0
    [  152.709768] ds90ub953 9-0044: e4 -> 0
    [  152.709971] ds90ub953 9-0044: e5 -> 0
    [  152.710178] ds90ub953 9-0044: e6 -> 0
    [  152.710370] ds90ub953 9-0044: e7 -> 0
    [  152.710555] ds90ub953 9-0044: e8 -> 0
    [  152.710884] ds90ub953 9-0044: e9 -> 0
    [  152.711100] ds90ub953 9-0044: ea -> 0
    [  152.711287] ds90ub953 9-0044: eb -> 0
    [  152.711500] ds90ub953 9-0044: ec -> 0
    [  152.711695] ds90ub953 9-0044: ed -> 0
    [  152.711896] ds90ub953 9-0044: ee -> 0
    [  152.712105] ds90ub953 9-0044: ef -> 0
    [  152.712403] ds90ub953 9-0044: f0 -> 5f
    [  152.712616] ds90ub953 9-0044: f1 -> 55
    [  152.712818] ds90ub953 9-0044: f2 -> 42
    [  152.713023] ds90ub953 9-0044: f3 -> 39
    [  152.713561] ds90ub953 9-0044: f4 -> 35
    [  152.714121] ds90ub953 9-0044: f5 -> 33
    [  152.714312] ds90ub953 9-0044: f6 -> 0
    [  152.714506] ds90ub953 9-0044: f7 -> 0
    [  152.714715] ds90ub953 9-0044: f8 -> 0
    [  152.714913] ds90ub953 9-0044: f9 -> 0
    [  152.715264] ds90ub953 9-0044: fa -> 0
    [  152.715467] ds90ub953 9-0044: fb -> 0
    [  152.715960] ds90ub953 9-0044: fc -> 0
    [  152.716152] ds90ub953 9-0044: fd -> 0
    [  152.716363] ds90ub953 9-0044: fe -> 0
    [  152.716584] ds90ub953 9-0044: ff -> 0
    [  152.716949] ds90ub953 9-0044: 100 -> 30
    [  152.717432] ds90ub953 9-0044: 101 -> 0
    [  152.717678] ds90ub953 9-0044: 102 -> 52
    [  152.718083] ds90ub953 9-0044: 103 -> 48
    [  152.718464] ds90ub953 9-0044: 104 -> 0
    [  152.718748] ds90ub953 9-0044: 105 -> 3
    [  152.718948] ds90ub953 9-0044: 106 -> 41
    [  152.719148] ds90ub953 9-0044: 107 -> ff
    [  152.719353] ds90ub953 9-0044: 108 -> fe
    [  152.719546] ds90ub953 9-0044: 109 -> 1e
    [  152.719733] ds90ub953 9-0044: 10a -> 10
    [  152.719918] ds90ub953 9-0044: 10b -> 13
    [  152.720103] ds90ub953 9-0044: 10c -> 26
    [  152.720290] ds90ub953 9-0044: 10d -> 0
    [  152.720481] ds90ub953 9-0044: 10e -> f
    [  152.720676] ds90ub953 9-0044: 10f -> 0
    [  152.720872] ds90ub953 9-0044: 110 -> 0
    [  152.721424] ds90ub953 9-0044: 111 -> 0
    [  152.721643] ds90ub953 9-0044: 112 -> 0
    [  152.721915] ds90ub953 9-0044: 113 -> 0
    [  152.722103] ds90ub953 9-0044: 114 -> 0
    [  152.722312] ds90ub953 9-0044: 115 -> 20
    [  152.722540] ds90ub953 9-0044: 116 -> 18
    [  152.722838] ds90ub953 9-0044: 117 -> 3c
    [  152.723036] ds90ub953 9-0044: 118 -> 80
    [  152.723234] ds90ub953 9-0044: 119 -> 62
    [  152.723429] ds90ub953 9-0044: 11a -> 62
    [  152.723623] ds90ub953 9-0044: 11b -> 62
    [  152.723851] ds90ub953 9-0044: 11c -> 0
    [  152.724319] ds90ub953 9-0044: 11d -> 0
    [  152.724540] ds90ub953 9-0044: 11e -> 0
    [  152.724730] ds90ub953 9-0044: 11f -> 0
    [  152.725483] ds90ub953 9-0044: 120 -> 0
    [  152.725694] ds90ub953 9-0044: 121 -> 0
    [  152.725899] ds90ub953 9-0044: 122 -> 0
    [  152.726095] ds90ub953 9-0044: 123 -> 0
    [  152.726283] ds90ub953 9-0044: 124 -> 0
    [  152.726486] ds90ub953 9-0044: 125 -> 2
    [  152.726677] ds90ub953 9-0044: 126 -> 0
    [  152.726866] ds90ub953 9-0044: 127 -> 0
    [  152.727056] ds90ub953 9-0044: 128 -> 67
    [  152.727255] ds90ub953 9-0044: 129 -> 33
    [  152.727449] ds90ub953 9-0044: 12a -> 1
    [  152.727644] ds90ub953 9-0044: 12b -> 0
    [  152.727835] ds90ub953 9-0044: 12c -> 0
    [  152.728118] ds90ub953 9-0044: 12d -> 0
    [  152.728317] ds90ub953 9-0044: 12e -> 0
    [  152.728539] ds90ub953 9-0044: 12f -> 0
    [  152.728730] ds90ub953 9-0044: 130 -> 0
    [  152.728924] ds90ub953 9-0044: 131 -> 20
    [  152.729492] ds90ub953 9-0044: 132 -> 9
    [  152.729904] ds90ub953 9-0044: 133 -> 4
    [  152.730090] ds90ub953 9-0044: 134 -> 0
    [  152.730269] ds90ub953 9-0044: 135 -> 10
    [  152.730448] ds90ub953 9-0044: 136 -> 0
    [  152.730632] ds90ub953 9-0044: 137 -> 7a
    [  152.731046] ds90ub953 9-0044: 138 -> 0
    [  152.731222] ds90ub953 9-0044: 139 -> 0
    [  152.731410] ds90ub953 9-0044: 13a -> 0
    [  152.731601] ds90ub953 9-0044: 13b -> 0
    [  152.731792] ds90ub953 9-0044: 13c -> 0
    [  152.732341] ds90ub953 9-0044: 13d -> 0
    [  152.732720] ds90ub953 9-0044: 13e -> 0
    [  152.733036] ds90ub953 9-0044: 13f -> 0
    [  152.733518] ds90ub953 9-0044: 140 -> 0
    [  152.733892] ds90ub953 9-0044: 141 -> 0
    [  152.734293] ds90ub953 9-0044: 142 -> 0
    [  152.734661] ds90ub953 9-0044: 143 -> 0
    [  152.735024] ds90ub953 9-0044: 144 -> 0
    [  152.735230] ds90ub953 9-0044: 145 -> 0
    [  152.735427] ds90ub953 9-0044: 146 -> 0
    [  152.735624] ds90ub953 9-0044: 147 -> 0
    [  152.735956] ds90ub953 9-0044: 148 -> 0
    [  152.736474] ds90ub953 9-0044: 149 -> 0
    [  152.736676] ds90ub953 9-0044: 14a -> 0
    [  152.736872] ds90ub953 9-0044: 14b -> 0
    [  152.737432] ds90ub953 9-0044: 14c -> 0
    [  152.737636] ds90ub953 9-0044: 14d -> 0
    [  152.737831] ds90ub953 9-0044: 14e -> 0
    [  152.738033] ds90ub953 9-0044: 14f -> 0
    [  152.738268] ds90ub953 9-0044: 150 -> 20
    [  152.738472] ds90ub953 9-0044: 151 -> c0
    [  152.738668] ds90ub953 9-0044: 152 -> 47
    [  152.738888] ds90ub953 9-0044: 153 -> 0
    [  152.739081] ds90ub953 9-0044: 154 -> 0
    [  152.739283] ds90ub953 9-0044: 155 -> 3
    [  152.739480] ds90ub953 9-0044: 156 -> 0
    [  152.739885] ds90ub953 9-0044: 157 -> 0
    [  152.740080] ds90ub953 9-0044: 158 -> 7
    [  152.740269] ds90ub953 9-0044: 159 -> 7
    [  152.740470] ds90ub953 9-0044: 15a -> 7
    [  152.740666] ds90ub953 9-0044: 15b -> 0
    [  152.741565] ds90ub953 9-0044: 15c -> 0
    [  152.741768] ds90ub953 9-0044: 15d -> 0
    [  152.742031] ds90ub953 9-0044: 15e -> 0
    [  152.742347] ds90ub953 9-0044: 15f -> 0
    [  152.742554] ds90ub953 9-0044: 160 -> 0
    [  152.742754] ds90ub953 9-0044: 161 -> 2b
    [  152.742949] ds90ub953 9-0044: 162 -> 40
    [  152.743157] ds90ub953 9-0044: 163 -> 6
    [  152.743351] ds90ub953 9-0044: 164 -> 3b
    [  152.743726] ds90ub953 9-0044: 165 -> c8
    [  152.743925] ds90ub953 9-0044: 166 -> 0
    [  152.744108] ds90ub953 9-0044: 167 -> 0
    [  152.744299] ds90ub953 9-0044: 168 -> 0
    [  152.744511] ds90ub953 9-0044: 169 -> 0
    [  152.744705] ds90ub953 9-0044: 16a -> 0
    [  152.744912] ds90ub953 9-0044: 16b -> 0
    [  152.745539] ds90ub953 9-0044: 16c -> 0
    [  152.745750] ds90ub953 9-0044: 16d -> 0
    [  152.745939] ds90ub953 9-0044: 16e -> 0
    [  152.746128] ds90ub953 9-0044: 16f -> 0
    [  152.746312] ds90ub953 9-0044: 170 -> 0
    [  152.746505] ds90ub953 9-0044: 171 -> 0
    [  152.746693] ds90ub953 9-0044: 172 -> 25
    [  152.746884] ds90ub953 9-0044: 173 -> 0
    [  152.747074] ds90ub953 9-0044: 174 -> 0
    [  152.747266] ds90ub953 9-0044: 175 -> 0
    [  152.747453] ds90ub953 9-0044: 176 -> 0
    [  152.747906] ds90ub953 9-0044: 177 -> 0
    [  152.748311] ds90ub953 9-0044: 178 -> 0
    [  152.748655] ds90ub953 9-0044: 179 -> 0
    [  152.748859] ds90ub953 9-0044: 17a -> e4
    [  152.749473] ds90ub953 9-0044: 17b -> 0
    [  152.749803] ds90ub953 9-0044: 17c -> 0
    [  152.750006] ds90ub953 9-0044: 17d -> 0
    [  152.750369] ds90ub953 9-0044: 17e -> 0
    [  152.750733] ds90ub953 9-0044: 17f -> 0
    [  152.750928] ds90ub953 9-0044: 180 -> 0
    [  152.751124] ds90ub953 9-0044: 181 -> 0
    [  152.751313] ds90ub953 9-0044: 182 -> 0
    [  152.751509] ds90ub953 9-0044: 183 -> 0
    [  152.752041] ds90ub953 9-0044: 184 -> 0
    [  152.752462] ds90ub953 9-0044: 185 -> 0
    [  152.752730] ds90ub953 9-0044: 186 -> 90
    [  152.752928] ds90ub953 9-0044: 187 -> 0
    [  152.753479] ds90ub953 9-0044: 188 -> 0
    [  152.753690] ds90ub953 9-0044: 189 -> 0
    [  152.753898] ds90ub953 9-0044: 18a -> 0
    [  152.754121] ds90ub953 9-0044: 18b -> 0
    [  152.754321] ds90ub953 9-0044: 18c -> 5
    [  152.754520] ds90ub953 9-0044: 18d -> 0
    [  152.754711] ds90ub953 9-0044: 18e -> 0
    [  152.754908] ds90ub953 9-0044: 18f -> 0
    [  152.755093] ds90ub953 9-0044: 190 -> 32
    [  152.755298] ds90ub953 9-0044: 191 -> e3
    [  152.755666] ds90ub953 9-0044: 192 -> 64
    [  152.755863] ds90ub953 9-0044: 193 -> 1
    [  152.756057] ds90ub953 9-0044: 194 -> 0
    [  152.756246] ds90ub953 9-0044: 195 -> 0
    [  152.756442] ds90ub953 9-0044: 196 -> 0
    [  152.756633] ds90ub953 9-0044: 197 -> 0
    [  152.756829] ds90ub953 9-0044: 198 -> 0
    [  152.757647] ds90ub953 9-0044: 199 -> 0
    [  152.757921] ds90ub953 9-0044: 19a -> 28
    [  152.758282] ds90ub953 9-0044: 19b -> 23
    [  152.758485] ds90ub953 9-0044: 19c -> 2
    [  152.758677] ds90ub953 9-0044: 19d -> 7
    [  152.758884] ds90ub953 9-0044: 19e -> 1
    [  152.759082] ds90ub953 9-0044: 19f -> d
    [  152.759281] ds90ub953 9-0044: 1a0 -> 0
    [  152.759489] ds90ub953 9-0044: 1a1 -> d
    [  152.759685] ds90ub953 9-0044: 1a2 -> c
    [  152.759884] ds90ub953 9-0044: 1a3 -> d
    [  152.760080] ds90ub953 9-0044: 1a4 -> b
    [  152.760280] ds90ub953 9-0044: 1a5 -> 10
    [  152.760478] ds90ub953 9-0044: 1a6 -> 42
    [  152.760680] ds90ub953 9-0044: 1a7 -> 10
    [  152.760879] ds90ub953 9-0044: 1a8 -> 10
    [  152.761600] ds90ub953 9-0044: 1a9 -> 10
    [  152.761918] ds90ub953 9-0044: 1aa -> 3
    [  152.762138] ds90ub953 9-0044: 1ab -> 1
    [  152.762323] ds90ub953 9-0044: 1ac -> 0
    [  152.762515] ds90ub953 9-0044: 1ad -> 0
    [  152.762717] ds90ub953 9-0044: 1ae -> 0
    [  152.763065] ds90ub953 9-0044: 1af -> 0
    [  152.763469] ds90ub953 9-0044: 1b0 -> 4
    [  152.763839] ds90ub953 9-0044: 1b1 -> 4a
    [  152.764044] ds90ub953 9-0044: 1b2 -> 3f
    [  152.764441] ds90ub953 9-0044: 1b3 -> 0
    [  152.764754] ds90ub953 9-0044: 1b4 -> 0
    [  152.765277] ds90ub953 9-0044: 1b5 -> 0
    [  152.765745] ds90ub953 9-0044: 1b6 -> 0
    [  152.766144] ds90ub953 9-0044: 1b7 -> 0
    [  152.766679] ds90ub953 9-0044: 1b8 -> 0
    [  152.767536] ds90ub953 9-0044: 1b9 -> 0
    [  152.767950] ds90ub953 9-0044: 1ba -> 0
    [  152.768339] ds90ub953 9-0044: 1bb -> 0
    [  152.768786] ds90ub953 9-0044: 1bc -> 0
    [  152.769516] ds90ub953 9-0044: 1bd -> 0
    [  152.769917] ds90ub953 9-0044: 1be -> 0
    [  152.770312] ds90ub953 9-0044: 1bf -> 0
    [  152.770842] ds90ub953 9-0044: 1c0 -> 0
    [  152.771239] ds90ub953 9-0044: 1c1 -> 0
    [  152.771619] ds90ub953 9-0044: 1c2 -> 0
    [  152.772163] ds90ub953 9-0044: 1c3 -> 0
    [  152.772347] ds90ub953 9-0044: 1c4 -> 0
    [  152.772544] ds90ub953 9-0044: 1c5 -> 0
    [  152.772735] ds90ub953 9-0044: 1c6 -> 0
    [  152.772935] ds90ub953 9-0044: 1c7 -> 0
    [  152.773489] ds90ub953 9-0044: 1c8 -> 0
    [  152.773723] ds90ub953 9-0044: 1c9 -> 0
    [  152.773959] ds90ub953 9-0044: 1ca -> 0
    [  152.774206] ds90ub953 9-0044: 1cb -> 0
    [  152.774543] ds90ub953 9-0044: 1cc -> 0
    [  152.774749] ds90ub953 9-0044: 1cd -> 0
    [  152.775101] ds90ub953 9-0044: 1ce -> 0
    [  152.775299] ds90ub953 9-0044: 1cf -> 0
    [  152.775488] ds90ub953 9-0044: 1d0 -> 0
    [  152.775684] ds90ub953 9-0044: 1d1 -> 0
    [  152.775886] ds90ub953 9-0044: 1d2 -> 0
    [  152.776089] ds90ub953 9-0044: 1d3 -> 0
    [  152.776298] ds90ub953 9-0044: 1d4 -> 0
    [  152.776626] ds90ub953 9-0044: 1d5 -> 0
    [  152.776825] ds90ub953 9-0044: 1d6 -> 0
    [  152.777011] ds90ub953 9-0044: 1d7 -> 0
    [  152.777559] ds90ub953 9-0044: 1d8 -> 0
    [  152.777771] ds90ub953 9-0044: 1d9 -> 0
    [  152.778220] ds90ub953 9-0044: 1da -> 0
    [  152.778413] ds90ub953 9-0044: 1db -> 0
    [  152.778600] ds90ub953 9-0044: 1dc -> 0
    [  152.778950] ds90ub953 9-0044: 1dd -> 0
    [  152.779145] ds90ub953 9-0044: 1de -> 0
    [  152.779345] ds90ub953 9-0044: 1df -> 0
    [  152.779690] ds90ub953 9-0044: 1e0 -> 0
    [  152.779889] ds90ub953 9-0044: 1e1 -> 0
    [  152.780084] ds90ub953 9-0044: 1e2 -> 0
    [  152.780408] ds90ub953 9-0044: 1e3 -> 0
    [  152.780601] ds90ub953 9-0044: 1e4 -> 0
    [  152.780959] ds90ub953 9-0044: 1e5 -> 0
    [  152.781482] ds90ub953 9-0044: 1e6 -> 0
    [  152.781773] ds90ub953 9-0044: 1e7 -> 0
    [  152.782135] ds90ub953 9-0044: 1e8 -> 0
    [  152.782349] ds90ub953 9-0044: 1e9 -> 0
    [  152.782550] ds90ub953 9-0044: 1ea -> 0
    [  152.783105] ds90ub953 9-0044: 1eb -> 0
    [  152.783408] ds90ub953 9-0044: 1ec -> 0
    [  152.783608] ds90ub953 9-0044: 1ed -> 0
    [  152.783812] ds90ub953 9-0044: 1ee -> 0
    [  152.784006] ds90ub953 9-0044: 1ef -> 0
    [  152.784208] ds90ub953 9-0044: 1f0 -> 5f
    [  152.784406] ds90ub953 9-0044: 1f1 -> 55
    [  152.784597] ds90ub953 9-0044: 1f2 -> 42
    [  152.784788] ds90ub953 9-0044: 1f3 -> 39
    [  152.784981] ds90ub953 9-0044: 1f4 -> 35
    [  152.785743] ds90ub953 9-0044: 1f5 -> 33
    [  152.785955] ds90ub953 9-0044: 1f6 -> 0
    [  152.786183] ds90ub953 9-0044: 1f7 -> 0
    [  152.786391] ds90ub953 9-0044: 1f8 -> 0
    [  152.786594] ds90ub953 9-0044: 1f9 -> 0
    [  152.786811] ds90ub953 9-0044: 1fa -> 0
    [  152.787109] ds90ub953 9-0044: 1fb -> 0
    [  152.787303] ds90ub953 9-0044: 1fc -> 0
    [  152.787666] ds90ub953 9-0044: 1fd -> 0
    [  152.787866] ds90ub953 9-0044: 1fe -> 0
    [  152.788073] ds90ub953 9-0044: 1ff -> 0
    [  152.788265] ds90ub953 9-0044: 200 -> 30
    [  152.788465] ds90ub953 9-0044: 201 -> 0
    [  152.788667] ds90ub953 9-0044: 202 -> 52
    [  152.788861] ds90ub953 9-0044: 203 -> 48
    [  152.789479] ds90ub953 9-0044: 204 -> 0
    [  152.789703] ds90ub953 9-0044: 205 -> 3
    [  152.789909] ds90ub953 9-0044: 206 -> 41
    [  152.790113] ds90ub953 9-0044: 207 -> ff
    [  152.790319] ds90ub953 9-0044: 208 -> fe
    [  152.790514] ds90ub953 9-0044: 209 -> 1e
    [  152.790769] ds90ub953 9-0044: 20a -> 10
    [  152.791113] ds90ub953 9-0044: 20b -> 13
    [  152.791319] ds90ub953 9-0044: 20c -> 26
    [  152.791519] ds90ub953 9-0044: 20d -> 0
    [  152.791731] ds90ub953 9-0044: 20e -> f
    [  152.791927] ds90ub953 9-0044: 20f -> 0
    [  152.792117] ds90ub953 9-0044: 210 -> 0
    [  152.792312] ds90ub953 9-0044: 211 -> 0
    [  152.792499] ds90ub953 9-0044: 212 -> 0
    [  152.792691] ds90ub953 9-0044: 213 -> 0
    [  152.792883] ds90ub953 9-0044: 214 -> 0
    [  152.793340] ds90ub953 9-0044: 215 -> 20
    [  152.793530] ds90ub953 9-0044: 216 -> 18
    [  152.793724] ds90ub953 9-0044: 217 -> 3c
    [  152.794167] ds90ub953 9-0044: 218 -> 80
    [  152.794366] ds90ub953 9-0044: 219 -> 62
    [  152.794744] ds90ub953 9-0044: 21a -> 62
    [  152.794946] ds90ub953 9-0044: 21b -> 62
    [  152.795132] ds90ub953 9-0044: 21c -> 0
    [  152.795328] ds90ub953 9-0044: 21d -> 0
    [  152.795521] ds90ub953 9-0044: 21e -> 0
    [  152.795714] ds90ub953 9-0044: 21f -> 0
    [  152.795909] ds90ub953 9-0044: 220 -> 0
    [  152.796294] ds90ub953 9-0044: 221 -> 0
    [  152.796763] ds90ub953 9-0044: 222 -> 0
    [  152.797465] ds90ub953 9-0044: 223 -> 0
    [  152.797894] ds90ub953 9-0044: 224 -> 0
    [  152.798277] ds90ub953 9-0044: 225 -> 2
    [  152.798474] ds90ub953 9-0044: 226 -> 0
    [  152.798671] ds90ub953 9-0044: 227 -> 0
    [  152.798889] ds90ub953 9-0044: 228 -> 67
    [  152.799086] ds90ub953 9-0044: 229 -> 33
    [  152.799287] ds90ub953 9-0044: 22a -> 1
    [  152.799777] ds90ub953 9-0044: 22b -> 0
    [  152.799983] ds90ub953 9-0044: 22c -> 0
    [  152.800367] ds90ub953 9-0044: 22d -> 0
    [  152.800679] ds90ub953 9-0044: 22e -> 0
    [  152.800871] ds90ub953 9-0044: 22f -> 0
    [  152.801603] ds90ub953 9-0044: 230 -> 0
    [  152.801811] ds90ub953 9-0044: 231 -> 20
    [  152.802004] ds90ub953 9-0044: 232 -> 9
    [  152.802318] ds90ub953 9-0044: 233 -> 4
    [  152.802511] ds90ub953 9-0044: 234 -> 0
    [  152.802808] ds90ub953 9-0044: 235 -> 10
    [  152.803166] ds90ub953 9-0044: 236 -> 0
    [  152.803640] ds90ub953 9-0044: 237 -> 7a
    [  152.803843] ds90ub953 9-0044: 238 -> 0
    [  152.804057] ds90ub953 9-0044: 239 -> 0
    [  152.804292] ds90ub953 9-0044: 23a -> 0
    [  152.804485] ds90ub953 9-0044: 23b -> 0
    [  152.804681] ds90ub953 9-0044: 23c -> 0
    [  152.804970] ds90ub953 9-0044: 23d -> 0
    [  152.805321] ds90ub953 9-0044: 23e -> 0
    [  152.805715] ds90ub953 9-0044: 23f -> 0
    [  152.805926] ds90ub953 9-0044: 240 -> 0
    [  152.806111] ds90ub953 9-0044: 241 -> 0
    [  152.806507] ds90ub953 9-0044: 242 -> 0
    [  152.806704] ds90ub953 9-0044: 243 -> 0
    [  152.806899] ds90ub953 9-0044: 244 -> 0
    [  152.807091] ds90ub953 9-0044: 245 -> 0
    [  152.807314] ds90ub953 9-0044: 246 -> 0
    [  152.807531] ds90ub953 9-0044: 247 -> 0
    [  152.807919] ds90ub953 9-0044: 248 -> 0
    [  152.808115] ds90ub953 9-0044: 249 -> 0
    [  152.808308] ds90ub953 9-0044: 24a -> 0
    [  152.808509] ds90ub953 9-0044: 24b -> 0
    [  152.808731] ds90ub953 9-0044: 24c -> 0
    [  152.808928] ds90ub953 9-0044: 24d -> 0
    [  152.809487] ds90ub953 9-0044: 24e -> 0
    [  152.809747] ds90ub953 9-0044: 24f -> 0
    [  152.809984] ds90ub953 9-0044: 250 -> 20
    [  152.810177] ds90ub953 9-0044: 251 -> c0
    [  152.810370] ds90ub953 9-0044: 252 -> 47
    [  152.810561] ds90ub953 9-0044: 253 -> 0
    [  152.810748] ds90ub953 9-0044: 254 -> 0
    [  152.810753] ds90ub953 9-0044: -----------------------------------------------------------------------------------------
    For ds90ub960
    [  350.725443] ds90ub960 9-003d: 0 -> 7a
    [  350.726154] ds90ub960 9-003d: 1 -> 0
    [  350.727377] ds90ub960 9-003d: 2 -> 1e
    [  350.728327] ds90ub960 9-003d: 3 -> 40
    [  350.728520] ds90ub960 9-003d: 4 -> d0
    [  350.728729] ds90ub960 9-003d: 5 -> 1
    [  350.728925] ds90ub960 9-003d: 6 -> 0
    [  350.729263] ds90ub960 9-003d: 7 -> fe
    [  350.729459] ds90ub960 9-003d: 8 -> 1c
    [  350.729980] ds90ub960 9-003d: 9 -> 10
    [  350.733181] ds90ub960 9-003d: a -> 7a
    [  350.733388] ds90ub960 9-003d: b -> 7a
    [  350.733840] ds90ub960 9-003d: c -> 3
    [  350.734115] ds90ub960 9-003d: d -> b9
    [  350.734358] ds90ub960 9-003d: e -> 0
    [  350.734550] ds90ub960 9-003d: f -> ff
    [  350.734960] ds90ub960 9-003d: 10 -> 0
    [  350.735408] ds90ub960 9-003d: 11 -> 0
    [  350.735639] ds90ub960 9-003d: 12 -> 0
    [  350.735945] ds90ub960 9-003d: 13 -> 0
    [  350.736178] ds90ub960 9-003d: 14 -> 0
    [  350.736442] ds90ub960 9-003d: 15 -> 0
    [  350.736871] ds90ub960 9-003d: 16 -> 0
    [  350.737080] ds90ub960 9-003d: 17 -> 0
    [  350.738352] ds90ub960 9-003d: 18 -> 0
    [  350.738674] ds90ub960 9-003d: 19 -> 0
    [  350.744666] ds90ub960 9-003d: 1a -> 0
    [  350.744880] ds90ub960 9-003d: 1b -> 0
    [  350.745081] ds90ub960 9-003d: 1c -> 0
    [  350.745272] ds90ub960 9-003d: 1d -> 0
    [  350.745458] ds90ub960 9-003d: 1e -> 4
    [  350.745648] ds90ub960 9-003d: 1f -> 0
    [  350.745840] ds90ub960 9-003d: 20 -> c3
    [  350.747487] ds90ub960 9-003d: 21 -> 3
    [  350.747683] ds90ub960 9-003d: 22 -> 0
    [  350.748053] ds90ub960 9-003d: 23 -> 0
    [  350.748501] ds90ub960 9-003d: 24 -> 3
    [  350.749189] ds90ub960 9-003d: 25 -> 0
    [  350.749384] ds90ub960 9-003d: 26 -> 0
    [  350.749689] ds90ub960 9-003d: 27 -> 0
    [  350.750335] ds90ub960 9-003d: 28 -> 0
    [  350.751700] ds90ub960 9-003d: 29 -> 0
    [  350.751920] ds90ub960 9-003d: 2a -> 0
    [  350.752129] ds90ub960 9-003d: 2b -> 0
    [  350.752458] ds90ub960 9-003d: 2c -> 0
    [  350.766146] ds90ub960 9-003d: 2d -> 0
    [  350.770578] ds90ub960 9-003d: 2e -> 0
    [  350.773464] ds90ub960 9-003d: 2f -> 0
    [  350.774944] ds90ub960 9-003d: 30 -> 0
    [  350.776878] ds90ub960 9-003d: 31 -> 0
    [  350.778438] ds90ub960 9-003d: 32 -> 12
    [  350.778668] ds90ub960 9-003d: 33 -> 63
    [  350.778862] ds90ub960 9-003d: 34 -> 31
    [  350.779042] ds90ub960 9-003d: 35 -> 11
    [  350.779223] ds90ub960 9-003d: 36 -> 0
    [  350.779406] ds90ub960 9-003d: 37 -> 13
    [  350.779628] ds90ub960 9-003d: 38 -> 0
    [  350.779836] ds90ub960 9-003d: 39 -> 0
    [  350.780314] ds90ub960 9-003d: 3a -> 0
    [  350.780800] ds90ub960 9-003d: 3b -> 0
    [  350.781804] ds90ub960 9-003d: 3c -> 0
    [  350.782000] ds90ub960 9-003d: 3d -> 0
    [  350.782409] ds90ub960 9-003d: 3e -> 0
    [  350.782595] ds90ub960 9-003d: 3f -> 0
    [  350.783183] ds90ub960 9-003d: 40 -> 0
    [  350.783383] ds90ub960 9-003d: 41 -> a9
    [  350.783571] ds90ub960 9-003d: 42 -> 71
    [  350.784007] ds90ub960 9-003d: 43 -> 1
    [  350.784209] ds90ub960 9-003d: 44 -> 0
    [  350.784401] ds90ub960 9-003d: 45 -> 0
    [  350.784589] ds90ub960 9-003d: 46 -> 20
    [  350.784788] ds90ub960 9-003d: 47 -> 0
    [  350.784988] ds90ub960 9-003d: 48 -> 0
    [  350.785409] ds90ub960 9-003d: 49 -> 0
    [  350.785600] ds90ub960 9-003d: 4a -> 0
    [  350.785800] ds90ub960 9-003d: 4b -> 12
    [  350.786476] ds90ub960 9-003d: 4c -> 12
    [  350.786684] ds90ub960 9-003d: 4d -> 43
    [  350.787837] ds90ub960 9-003d: 4e -> 14
    [  350.788046] ds90ub960 9-003d: 4f -> 64
    [  350.788243] ds90ub960 9-003d: 50 -> 0
    [  350.788435] ds90ub960 9-003d: 51 -> 0
    [  350.788637] ds90ub960 9-003d: 52 -> 0
    [  350.788839] ds90ub960 9-003d: 53 -> 3
    [  350.789035] ds90ub960 9-003d: 54 -> 0
    [  350.789227] ds90ub960 9-003d: 55 -> 0
    [  350.789418] ds90ub960 9-003d: 56 -> 0
    [  350.789619] ds90ub960 9-003d: 57 -> 0
    [  350.789828] ds90ub960 9-003d: 58 -> 5e
    [  350.790028] ds90ub960 9-003d: 59 -> 0
    [  350.791018] ds90ub960 9-003d: 5a -> 0
    [  350.791211] ds90ub960 9-003d: 5b -> 30
    [  350.791397] ds90ub960 9-003d: 5c -> 8a
    [  350.791584] ds90ub960 9-003d: 5d -> c0
    [  350.791793] ds90ub960 9-003d: 5e -> 20
    [  350.791987] ds90ub960 9-003d: 5f -> 0
    [  350.792183] ds90ub960 9-003d: 60 -> 0
    [  350.792369] ds90ub960 9-003d: 61 -> 0
    [  350.792756] ds90ub960 9-003d: 62 -> 0
    [  350.792958] ds90ub960 9-003d: 63 -> 0
    [  350.793154] ds90ub960 9-003d: 64 -> 0
    [  350.793345] ds90ub960 9-003d: 65 -> 96
    [  350.793540] ds90ub960 9-003d: 66 -> 9a
    [  350.793746] ds90ub960 9-003d: 67 -> 0
    [  350.793943] ds90ub960 9-003d: 68 -> 0
    [  350.795119] ds90ub960 9-003d: 69 -> 0
    [  350.795444] ds90ub960 9-003d: 6a -> 0
    [  350.795649] ds90ub960 9-003d: 6b -> 0
    [  350.795862] ds90ub960 9-003d: 6c -> 0
    [  350.796055] ds90ub960 9-003d: 6d -> 78
    [  350.796270] ds90ub960 9-003d: 6e -> 88
    [  350.796840] ds90ub960 9-003d: 6f -> 88
    [  350.797192] ds90ub960 9-003d: 70 -> 6b
    [  350.797836] ds90ub960 9-003d: 71 -> 6c
    [  350.798533] ds90ub960 9-003d: 72 -> 55
    [  350.798763] ds90ub960 9-003d: 73 -> 3
    [  350.799004] ds90ub960 9-003d: 74 -> 20
    [  350.799199] ds90ub960 9-003d: 75 -> 6
    [  350.799508] ds90ub960 9-003d: 76 -> 40
    [  350.799715] ds90ub960 9-003d: 77 -> c5
    [  350.799903] ds90ub960 9-003d: 78 -> 0
    [  350.800090] ds90ub960 9-003d: 79 -> 1
    [  350.800277] ds90ub960 9-003d: 7a -> 0
    [  350.800477] ds90ub960 9-003d: 7b -> 0
    [  350.800665] ds90ub960 9-003d: 7c -> 20
    [  350.801053] ds90ub960 9-003d: 7d -> 0
    [  350.801236] ds90ub960 9-003d: 7e -> 0
    [  350.801433] ds90ub960 9-003d: 7f -> 0
    [  350.801621] ds90ub960 9-003d: 80 -> 0
    [  350.801808] ds90ub960 9-003d: 81 -> 0
    [  350.801986] ds90ub960 9-003d: 82 -> 0
    [  350.802595] ds90ub960 9-003d: 83 -> 0
    [  350.802787] ds90ub960 9-003d: 84 -> 0
    [  350.802987] ds90ub960 9-003d: 85 -> 0
    [  350.803171] ds90ub960 9-003d: 86 -> 0
    [  350.803378] ds90ub960 9-003d: 87 -> 0
    [  350.803564] ds90ub960 9-003d: 88 -> 0
    [  350.803747] ds90ub960 9-003d: 89 -> 0
    [  350.804069] ds90ub960 9-003d: 8a -> 0
    [  350.804266] ds90ub960 9-003d: 8b -> 0
    [  350.804457] ds90ub960 9-003d: 8c -> 0
    [  350.804648] ds90ub960 9-003d: 8d -> 0
    [  350.804844] ds90ub960 9-003d: 8e -> 0
    [  350.805039] ds90ub960 9-003d: 8f -> 0
    [  350.805238] ds90ub960 9-003d: 90 -> 0
    [  350.805566] ds90ub960 9-003d: 91 -> 0
    [  350.805774] ds90ub960 9-003d: 92 -> 0
    [  350.805975] ds90ub960 9-003d: 93 -> 0
    [  350.806510] ds90ub960 9-003d: 94 -> 0
    [  350.806818] ds90ub960 9-003d: 95 -> 0
    [  350.807130] ds90ub960 9-003d: 96 -> 0
    [  350.807323] ds90ub960 9-003d: 97 -> 0
    [  350.807501] ds90ub960 9-003d: 98 -> 2c
    [  350.807688] ds90ub960 9-003d: 99 -> 6
    [  350.807911] ds90ub960 9-003d: 9a -> 1c
    [  350.808127] ds90ub960 9-003d: 9b -> 1c
    [  350.808837] ds90ub960 9-003d: 9c -> ff
    [  350.809036] ds90ub960 9-003d: 9d -> ff
    [  350.809241] ds90ub960 9-003d: 9e -> e
    [  350.809818] ds90ub960 9-003d: 9f -> 7f
    [  350.810020] ds90ub960 9-003d: a0 -> 0
    [  350.810708] ds90ub960 9-003d: a1 -> 0
    [  350.812459] ds90ub960 9-003d: a2 -> 0
    [  350.812661] ds90ub960 9-003d: a3 -> 0
    [  350.812845] ds90ub960 9-003d: a4 -> 0
    [  350.813068] ds90ub960 9-003d: a5 -> 1d
    [  350.813257] ds90ub960 9-003d: a6 -> 0
    [  350.813454] ds90ub960 9-003d: a7 -> 0
    [  350.813647] ds90ub960 9-003d: a8 -> 0
    [  350.813852] ds90ub960 9-003d: a9 -> 0
    [  350.814192] ds90ub960 9-003d: aa -> 0
    [  350.814740] ds90ub960 9-003d: ab -> 0
    [  350.814936] ds90ub960 9-003d: ac -> 0
    [  350.815131] ds90ub960 9-003d: ad -> 0
    [  350.815492] ds90ub960 9-003d: ae -> 0
    [  350.815847] ds90ub960 9-003d: af -> 0
    [  350.816317] ds90ub960 9-003d: b0 -> 8
    [  350.816527] ds90ub960 9-003d: b1 -> 9
    [  350.816707] ds90ub960 9-003d: b2 -> 8
    [  350.816897] ds90ub960 9-003d: b3 -> 8
    [  350.817080] ds90ub960 9-003d: b4 -> 25
    [  350.817614] ds90ub960 9-003d: b5 -> 0
    [  350.817797] ds90ub960 9-003d: b6 -> 18
    [  350.817990] ds90ub960 9-003d: b7 -> 0
    [  350.818353] ds90ub960 9-003d: b8 -> f8
    [  350.818543] ds90ub960 9-003d: b9 -> 33
    [  350.818973] ds90ub960 9-003d: ba -> 83
    [  350.819157] ds90ub960 9-003d: bb -> 74
    [  350.819334] ds90ub960 9-003d: bc -> 80
    [  350.819519] ds90ub960 9-003d: bd -> 0
    [  350.819851] ds90ub960 9-003d: be -> 0
    [  350.820056] ds90ub960 9-003d: bf -> 0
    [  350.820391] ds90ub960 9-003d: c0 -> 0
    [  350.820577] ds90ub960 9-003d: c1 -> 0
    [  350.820783] ds90ub960 9-003d: c2 -> 0
    [  350.820985] ds90ub960 9-003d: c3 -> 0
    [  350.821174] ds90ub960 9-003d: c4 -> 0
    [  350.821371] ds90ub960 9-003d: c5 -> 0
    [  350.821563] ds90ub960 9-003d: c6 -> 0
    [  350.821873] ds90ub960 9-003d: c7 -> 0
    [  350.822380] ds90ub960 9-003d: c8 -> 0
    [  350.822578] ds90ub960 9-003d: c9 -> 0
    [  350.822898] ds90ub960 9-003d: ca -> 0
    [  350.823095] ds90ub960 9-003d: cb -> 0
    [  350.823646] ds90ub960 9-003d: cc -> 0
    [  350.823861] ds90ub960 9-003d: cd -> 0
    [  350.824145] ds90ub960 9-003d: ce -> 0
    [  350.824351] ds90ub960 9-003d: cf -> 0
    [  350.824565] ds90ub960 9-003d: d0 -> 0
    [  350.824952] ds90ub960 9-003d: d1 -> 43
    [  350.825206] ds90ub960 9-003d: d2 -> 94
    [  350.825435] ds90ub960 9-003d: d3 -> 0
    [  350.825637] ds90ub960 9-003d: d4 -> 60
    [  350.825841] ds90ub960 9-003d: d5 -> e0
    [  350.826319] ds90ub960 9-003d: d6 -> 0
    [  350.827012] ds90ub960 9-003d: d7 -> 2
    [  350.827218] ds90ub960 9-003d: d8 -> 7
    [  350.827416] ds90ub960 9-003d: d9 -> 7f
    [  350.827611] ds90ub960 9-003d: da -> 0
    [  350.827825] ds90ub960 9-003d: db -> 0
    [  350.828027] ds90ub960 9-003d: dc -> 0
    [  350.828233] ds90ub960 9-003d: dd -> 0
    [  350.828459] ds90ub960 9-003d: de -> 0
    [  350.828654] ds90ub960 9-003d: df -> 0
    [  350.828852] ds90ub960 9-003d: e0 -> 0
    [  350.829055] ds90ub960 9-003d: e1 -> 0
    [  350.829416] ds90ub960 9-003d: e2 -> 0
    [  350.829622] ds90ub960 9-003d: e3 -> 0
    [  350.829862] ds90ub960 9-003d: e4 -> 0
    [  350.830570] ds90ub960 9-003d: e5 -> 0
    [  350.830991] ds90ub960 9-003d: e6 -> 0
    [  350.831192] ds90ub960 9-003d: e7 -> 0
    [  350.831392] ds90ub960 9-003d: e8 -> 0
    [  350.831588] ds90ub960 9-003d: e9 -> 0
    [  350.831786] ds90ub960 9-003d: ea -> 0
    [  350.831982] ds90ub960 9-003d: eb -> 0
    [  350.832183] ds90ub960 9-003d: ec -> 0
    [  350.832501] ds90ub960 9-003d: ed -> 0
    [  350.832698] ds90ub960 9-003d: ee -> 0
    [  350.832890] ds90ub960 9-003d: ef -> 0
    [  350.833077] ds90ub960 9-003d: f0 -> 5f
    [  350.833256] ds90ub960 9-003d: f1 -> 55
    [  350.833444] ds90ub960 9-003d: f2 -> 42
    [  350.833644] ds90ub960 9-003d: f3 -> 39
    [  350.834598] ds90ub960 9-003d: f4 -> 36
    [  350.834880] ds90ub960 9-003d: f5 -> 30
    [  350.835241] ds90ub960 9-003d: f6 -> 0
    [  350.835433] ds90ub960 9-003d: f7 -> 0
    [  350.835627] ds90ub960 9-003d: f8 -> 0
    [  350.835859] ds90ub960 9-003d: f9 -> 0
    [  350.836059] ds90ub960 9-003d: fa -> 0
    [  350.836244] ds90ub960 9-003d: fb -> 0
    [  350.836438] ds90ub960 9-003d: fc -> 0
    [  350.836780] ds90ub960 9-003d: fd -> 0
    [  350.836961] ds90ub960 9-003d: fe -> 0
    [  350.837152] ds90ub960 9-003d: ff -> 0
    [  350.837337] ds90ub960 9-003d: 100 -> 7a
    [  350.837523] ds90ub960 9-003d: 101 -> 0
    [  350.837706] ds90ub960 9-003d: 102 -> 1e
    [  350.837888] ds90ub960 9-003d: 103 -> 40
    [  350.838521] ds90ub960 9-003d: 104 -> d0
    [  350.838721] ds90ub960 9-003d: 105 -> 1
    [  350.838910] ds90ub960 9-003d: 106 -> 0
    [  350.839102] ds90ub960 9-003d: 107 -> fe
    [  350.839302] ds90ub960 9-003d: 108 -> 1c
    [  350.839500] ds90ub960 9-003d: 109 -> 10
    [  350.839998] ds90ub960 9-003d: 10a -> 7a
    [  350.840202] ds90ub960 9-003d: 10b -> 7a
    [  350.840458] ds90ub960 9-003d: 10c -> 3
    [  350.840654] ds90ub960 9-003d: 10d -> b9
    [  350.840848] ds90ub960 9-003d: 10e -> 0
    [  350.841039] ds90ub960 9-003d: 10f -> ff
    [  350.841499] ds90ub960 9-003d: 110 -> 0
    [  350.841716] ds90ub960 9-003d: 111 -> 0
    [  350.841906] ds90ub960 9-003d: 112 -> 0
    [  350.842463] ds90ub960 9-003d: 113 -> 0
    [  350.843036] ds90ub960 9-003d: 114 -> 0
    [  350.843344] ds90ub960 9-003d: 115 -> 0
    [  350.843559] ds90ub960 9-003d: 116 -> 0
    [  350.844565] ds90ub960 9-003d: 117 -> 0
    [  350.844761] ds90ub960 9-003d: 118 -> 0
    [  350.844966] ds90ub960 9-003d: 119 -> 0
    [  350.845155] ds90ub960 9-003d: 11a -> 0
    [  350.846733] ds90ub960 9-003d: 11b -> 0
    [  350.850396] ds90ub960 9-003d: 11c -> 0
    [  350.850602] ds90ub960 9-003d: 11d -> 0
    [  350.850798] ds90ub960 9-003d: 11e -> 4
    [  350.851026] ds90ub960 9-003d: 11f -> 0
    [  350.851290] ds90ub960 9-003d: 120 -> c3
    [  350.851489] ds90ub960 9-003d: 121 -> 3
    [  350.851812] ds90ub960 9-003d: 122 -> 0
    [  350.852010] ds90ub960 9-003d: 123 -> 0
    [  350.852230] ds90ub960 9-003d: 124 -> 1
    [  350.852412] ds90ub960 9-003d: 125 -> 0
    [  350.852591] ds90ub960 9-003d: 126 -> 0
    [  350.852766] ds90ub960 9-003d: 127 -> 0
    [  350.852949] ds90ub960 9-003d: 128 -> 0
    [  350.853140] ds90ub960 9-003d: 129 -> 0
    [  350.853327] ds90ub960 9-003d: 12a -> 0
    [  350.853664] ds90ub960 9-003d: 12b -> 0
    [  350.853861] ds90ub960 9-003d: 12c -> 0
    [  350.854604] ds90ub960 9-003d: 12d -> 0
    [  350.854869] ds90ub960 9-003d: 12e -> 0
    [  350.855069] ds90ub960 9-003d: 12f -> 0
    [  350.855265] ds90ub960 9-003d: 130 -> 0
    [  350.855515] ds90ub960 9-003d: 131 -> 0
    [  350.857014] ds90ub960 9-003d: 132 -> 12
    [  350.857231] ds90ub960 9-003d: 133 -> 63
    [  350.857444] ds90ub960 9-003d: 134 -> 31
    [  350.858434] ds90ub960 9-003d: 135 -> 11
    [  350.862355] ds90ub960 9-003d: 136 -> 0
    [  350.862588] ds90ub960 9-003d: 137 -> 10
    [  350.862815] ds90ub960 9-003d: 138 -> 0
    [  350.862997] ds90ub960 9-003d: 139 -> 0
    [  350.863197] ds90ub960 9-003d: 13a -> 0
    [  350.863604] ds90ub960 9-003d: 13b -> 0
    [  350.863846] ds90ub960 9-003d: 13c -> 0
    [  350.864067] ds90ub960 9-003d: 13d -> 0
    [  350.864252] ds90ub960 9-003d: 13e -> 0
    [  350.864448] ds90ub960 9-003d: 13f -> 0
    [  350.864638] ds90ub960 9-003d: 140 -> 0
    [  350.864820] ds90ub960 9-003d: 141 -> a9
    [  350.865437] ds90ub960 9-003d: 142 -> 71
    [  350.865643] ds90ub960 9-003d: 143 -> 1
    [  350.865835] ds90ub960 9-003d: 144 -> 0
    [  350.866349] ds90ub960 9-003d: 145 -> 0
    [  350.866712] ds90ub960 9-003d: 146 -> 20
    [  350.866986] ds90ub960 9-003d: 147 -> 0
    [  350.867182] ds90ub960 9-003d: 148 -> 0
    [  350.867453] ds90ub960 9-003d: 149 -> 0
    [  350.867654] ds90ub960 9-003d: 14a -> 0
    [  350.867845] ds90ub960 9-003d: 14b -> 12
    [  350.868132] ds90ub960 9-003d: 14c -> 12
    [  350.868318] ds90ub960 9-003d: 14d -> 43
    [  350.868496] ds90ub960 9-003d: 14e -> 4
    [  350.868673] ds90ub960 9-003d: 14f -> 64
    [  350.868881] ds90ub960 9-003d: 150 -> 0
    [  350.869101] ds90ub960 9-003d: 151 -> 0
    [  350.869288] ds90ub960 9-003d: 152 -> 0
    [  350.869837] ds90ub960 9-003d: 153 -> 3
    [  350.870354] ds90ub960 9-003d: 154 -> 0
    [  350.870547] ds90ub960 9-003d: 155 -> 0
    [  350.870726] ds90ub960 9-003d: 156 -> 0
    [  350.870907] ds90ub960 9-003d: 157 -> 0
    [  350.871465] ds90ub960 9-003d: 158 -> 5e
    [  350.871644] ds90ub960 9-003d: 159 -> 0
    [  350.871836] ds90ub960 9-003d: 15a -> 0
    [  350.873263] ds90ub960 9-003d: 15b -> 30
    [  350.876008] ds90ub960 9-003d: 15c -> 8a
    [  350.876214] ds90ub960 9-003d: 15d -> c0
    [  350.876402] ds90ub960 9-003d: 15e -> 20
    [  350.876582] ds90ub960 9-003d: 15f -> 0
    [  350.876773] ds90ub960 9-003d: 160 -> 0
    [  350.877141] ds90ub960 9-003d: 161 -> 0
    [  350.877322] ds90ub960 9-003d: 162 -> 0
    [  350.877507] ds90ub960 9-003d: 163 -> 0
    [  350.878296] ds90ub960 9-003d: 164 -> 0
    [  350.882376] ds90ub960 9-003d: 165 -> 96
    [  350.882576] ds90ub960 9-003d: 166 -> 9a
    [  350.882757] ds90ub960 9-003d: 167 -> 0
    [  350.883663] ds90ub960 9-003d: 168 -> 0
    [  350.883948] ds90ub960 9-003d: 169 -> 0
    [  350.884151] ds90ub960 9-003d: 16a -> 0
    [  350.884346] ds90ub960 9-003d: 16b -> 0
    [  350.884534] ds90ub960 9-003d: 16c -> 0
    [  350.884729] ds90ub960 9-003d: 16d -> 78
    [  350.884915] ds90ub960 9-003d: 16e -> 88
    [  350.885100] ds90ub960 9-003d: 16f -> 88
    [  350.885289] ds90ub960 9-003d: 170 -> 6b
    [  350.885475] ds90ub960 9-003d: 171 -> 6c
    [  350.885679] ds90ub960 9-003d: 172 -> 55
    [  350.886302] ds90ub960 9-003d: 173 -> 3
    [  350.886509] ds90ub960 9-003d: 174 -> 20
    [  350.886721] ds90ub960 9-003d: 175 -> 6
    [  350.886898] ds90ub960 9-003d: 176 -> 40
    [  350.887073] ds90ub960 9-003d: 177 -> c5
    [  350.887249] ds90ub960 9-003d: 178 -> 0
    [  350.887425] ds90ub960 9-003d: 179 -> 1
    [  350.887598] ds90ub960 9-003d: 17a -> 0
    [  350.887772] ds90ub960 9-003d: 17b -> 0
    [  350.887946] ds90ub960 9-003d: 17c -> 20
    [  350.888121] ds90ub960 9-003d: 17d -> 0
    [  350.888295] ds90ub960 9-003d: 17e -> 0
    [  350.888486] ds90ub960 9-003d: 17f -> 0
    [  350.888665] ds90ub960 9-003d: 180 -> 0
    [  350.889057] ds90ub960 9-003d: 181 -> 0
    [  350.889235] ds90ub960 9-003d: 182 -> 0
    [  350.890658] ds90ub960 9-003d: 183 -> 0
    [  350.891015] ds90ub960 9-003d: 184 -> 0
    [  350.891213] ds90ub960 9-003d: 185 -> 0
    [  350.891405] ds90ub960 9-003d: 186 -> 0
    [  350.891613] ds90ub960 9-003d: 187 -> 0
    [  350.891806] ds90ub960 9-003d: 188 -> 0
    [  350.892016] ds90ub960 9-003d: 189 -> 0
    [  350.892203] ds90ub960 9-003d: 18a -> 0
    [  350.892387] ds90ub960 9-003d: 18b -> 0
    [  350.892569] ds90ub960 9-003d: 18c -> 0
    [  350.892754] ds90ub960 9-003d: 18d -> 0
    [  350.892944] ds90ub960 9-003d: 18e -> 0
    [  350.893199] ds90ub960 9-003d: 18f -> 0
    [  350.893391] ds90ub960 9-003d: 190 -> 0
    [  350.893579] ds90ub960 9-003d: 191 -> 0
    [  350.893773] ds90ub960 9-003d: 192 -> 0
    [  350.893970] ds90ub960 9-003d: 193 -> 0
    [  350.894394] ds90ub960 9-003d: 194 -> 0
    [  350.894594] ds90ub960 9-003d: 195 -> 0
    [  350.894813] ds90ub960 9-003d: 196 -> 0
    [  350.895009] ds90ub960 9-003d: 197 -> 0
    [  350.895196] ds90ub960 9-003d: 198 -> 0
    [  350.895382] ds90ub960 9-003d: 199 -> a
    [  350.895565] ds90ub960 9-003d: 19a -> 0
    [  350.896590] ds90ub960 9-003d: 19b -> a
    [  350.897956] ds90ub960 9-003d: 19c -> 20
    [  350.898515] ds90ub960 9-003d: 19d -> e0
    [  350.898675] ds90ub960 9-003d: INTERRUPT_STS 1
    [  350.898847] ds90ub960 9-003d: FWD_STS 0x0
    [  350.899059] ds90ub960 9-003d: 19e -> 0
    [  350.899693] ds90ub960 9-003d: 19f -> 6
    [  350.900032] ds90ub960 9-003d: rx0 buffer error
    [  350.900242] ds90ub960 9-003d: 1a0 -> 0
    [  350.900427] ds90ub960 9-003d: 1a1 -> 0
    [  350.900631] ds90ub960 9-003d: 1a2 -> 0
    [  350.900823] ds90ub960 9-003d: 1a3 -> 0
    [  350.901183] ds90ub960 9-003d: 1a4 -> 0
    [  350.901376] ds90ub960 9-003d: 1a5 -> 1c
    [  350.901570] ds90ub960 9-003d: 1a6 -> 0
    [  350.901762] ds90ub960 9-003d: 1a7 -> 0
    [  350.901954] ds90ub960 9-003d: 1a8 -> 0
    [  350.902584] ds90ub960 9-003d: 1a9 -> 0
    [  350.902793] ds90ub960 9-003d: 1aa -> 0
    [  350.902983] ds90ub960 9-003d: 1ab -> 0
    [  350.903171] ds90ub960 9-003d: 1ac -> 0
    [  350.903373] ds90ub960 9-003d: 1ad -> 0
    [  350.903559] ds90ub960 9-003d: 1ae -> 0
    [  350.903739] ds90ub960 9-003d: 1af -> 0
    [  350.904540] ds90ub960 9-003d: 1b0 -> 8
    [  350.904735] ds90ub960 9-003d: 1b1 -> 9
    [  350.904914] ds90ub960 9-003d: 1b2 -> 8
    [  350.905089] ds90ub960 9-003d: 1b3 -> 8
    [  350.905268] ds90ub960 9-003d: 1b4 -> 25
    [  350.905443] ds90ub960 9-003d: 1b5 -> 0
    [  350.905619] ds90ub960 9-003d: 1b6 -> 18
    [  350.905794] ds90ub960 9-003d: 1b7 -> 0
    [  350.905968] ds90ub960 9-003d: 1b8 -> f8
    [  350.906332] ds90ub960 9-003d: 1b9 -> 33
    [  350.906522] ds90ub960 9-003d: 1ba -> 83
    [  350.906705] ds90ub960 9-003d: 1bb -> 74
    [  350.906992] ds90ub960 9-003d: 1bc -> 80
    [  350.907172] ds90ub960 9-003d: 1bd -> 0
    [  350.907351] ds90ub960 9-003d: 1be -> 0
    [  350.907526] ds90ub960 9-003d: 1bf -> 0
    [  350.907702] ds90ub960 9-003d: 1c0 -> 0
    [  350.907899] ds90ub960 9-003d: 1c1 -> 0
    [  350.908091] ds90ub960 9-003d: 1c2 -> 0
    [  350.908278] ds90ub960 9-003d: 1c3 -> 0
    [  350.908571] ds90ub960 9-003d: 1c4 -> 0
    [  350.908752] ds90ub960 9-003d: 1c5 -> 0
    [  350.908943] ds90ub960 9-003d: 1c6 -> 0
    [  350.909121] ds90ub960 9-003d: 1c7 -> 0
    [  350.909303] ds90ub960 9-003d: 1c8 -> 0
    [  350.909490] ds90ub960 9-003d: 1c9 -> 0
    [  350.909988] ds90ub960 9-003d: 1ca -> 0
    [  350.910896] ds90ub960 9-003d: 1cb -> 0
    [  350.911100] ds90ub960 9-003d: 1cc -> 0
    [  350.911322] ds90ub960 9-003d: 1cd -> 0
    [  350.911510] ds90ub960 9-003d: 1ce -> 0
    [  350.911711] ds90ub960 9-003d: 1cf -> 0
    [  350.911896] ds90ub960 9-003d: 1d0 -> 0
    [  350.912082] ds90ub960 9-003d: 1d1 -> 43
    [  350.912261] ds90ub960 9-003d: 1d2 -> 94
    [  350.912434] ds90ub960 9-003d: 1d3 -> 0
    [  350.912610] ds90ub960 9-003d: 1d4 -> 60
    [  350.912785] ds90ub960 9-003d: 1d5 -> e0
    [  350.912960] ds90ub960 9-003d: 1d6 -> 0
    [  350.913137] ds90ub960 9-003d: 1d7 -> 2
    [  350.913321] ds90ub960 9-003d: 1d8 -> 7
    [  350.913715] ds90ub960 9-003d: 1d9 -> 7f
    [  350.913935] ds90ub960 9-003d: 1da -> 0
    [  350.914610] ds90ub960 9-003d: 1db -> 0
    [  350.914801] ds90ub960 9-003d: 1dc -> 0
    [  350.914998] ds90ub960 9-003d: 1dd -> 0
    [  350.915192] ds90ub960 9-003d: 1de -> 0
    [  350.915388] ds90ub960 9-003d: 1df -> 0
    [  350.915573] ds90ub960 9-003d: 1e0 -> 0
    [  350.915918] ds90ub960 9-003d: 1e1 -> 0
    [  350.916120] ds90ub960 9-003d: 1e2 -> 0
    [  350.916306] ds90ub960 9-003d: 1e3 -> 0
    [  350.916495] ds90ub960 9-003d: 1e4 -> 0
    [  350.916687] ds90ub960 9-003d: 1e5 -> 0
    [  350.916876] ds90ub960 9-003d: 1e6 -> 0
    [  350.917062] ds90ub960 9-003d: 1e7 -> 0
    [  350.917252] ds90ub960 9-003d: 1e8 -> 0
    [  350.918159] ds90ub960 9-003d: 1e9 -> 0
    [  350.919067] ds90ub960 9-003d: 1ea -> 0
    [  350.919402] ds90ub960 9-003d: 1eb -> 0
    [  350.919599] ds90ub960 9-003d: 1ec -> 0
    [  350.919792] ds90ub960 9-003d: 1ed -> 0
    [  350.919996] ds90ub960 9-003d: 1ee -> 0
    [  350.920187] ds90ub960 9-003d: 1ef -> 0
    [  350.920374] ds90ub960 9-003d: 1f0 -> 5f
    [  350.920565] ds90ub960 9-003d: 1f1 -> 55
    [  350.920748] ds90ub960 9-003d: 1f2 -> 42
    [  350.920934] ds90ub960 9-003d: 1f3 -> 39
    [  350.921114] ds90ub960 9-003d: 1f4 -> 36
    [  350.921292] ds90ub960 9-003d: 1f5 -> 30
    [  350.921466] ds90ub960 9-003d: 1f6 -> 0
    [  350.921642] ds90ub960 9-003d: 1f7 -> 0
    [  350.921818] ds90ub960 9-003d: 1f8 -> 0
    [  350.921995] ds90ub960 9-003d: 1f9 -> 0
    [  350.922676] ds90ub960 9-003d: 1fa -> 0
    [  350.922867] ds90ub960 9-003d: 1fb -> 0
    [  350.923047] ds90ub960 9-003d: 1fc -> 0
    [  350.923223] ds90ub960 9-003d: 1fd -> 0
    [  350.923398] ds90ub960 9-003d: 1fe -> 0
    [  350.923574] ds90ub960 9-003d: 1ff -> 0
    [  350.923749] ds90ub960 9-003d: 200 -> 7a
    [  350.923925] ds90ub960 9-003d: 201 -> 0
    [  350.924099] ds90ub960 9-003d: 202 -> 1e
    [  350.924275] ds90ub960 9-003d: 203 -> 40
    [  350.924448] ds90ub960 9-003d: 204 -> d0
    [  350.924623] ds90ub960 9-003d: 205 -> 1
    [  350.924798] ds90ub960 9-003d: 206 -> 0
    [  350.924974] ds90ub960 9-003d: 207 -> fe
    [  350.925151] ds90ub960 9-003d: 208 -> 1c
    [  350.925326] ds90ub960 9-003d: 209 -> 10
    [  350.928888] ds90ub960 9-003d: 20a -> 7a
    [  350.929102] ds90ub960 9-003d: 20b -> 7a
    [  350.929286] ds90ub960 9-003d: 20c -> 3
    [  350.929471] ds90ub960 9-003d: 20d -> b9
    [  350.929973] ds90ub960 9-003d: 20e -> 0
    [  350.930255] ds90ub960 9-003d: 20f -> ff
    [  350.934198] ds90ub960 9-003d: 210 -> 0
    [  350.934413] ds90ub960 9-003d: 211 -> 0
    [  350.934597] ds90ub960 9-003d: 212 -> 0
    [  350.934771] ds90ub960 9-003d: 213 -> 0
    [  350.934947] ds90ub960 9-003d: 214 -> 0
    [  350.935125] ds90ub960 9-003d: 215 -> 0
    [  350.935314] ds90ub960 9-003d: 216 -> 0
    [  350.935502] ds90ub960 9-003d: 217 -> 0
    [  350.935714] ds90ub960 9-003d: 218 -> 0
    [  350.935906] ds90ub960 9-003d: 219 -> 0
    [  350.936082] ds90ub960 9-003d: 21a -> 0
    [  350.936257] ds90ub960 9-003d: 21b -> 0
    [  350.936431] ds90ub960 9-003d: 21c -> 0
    [  350.936605] ds90ub960 9-003d: 21d -> 0
    [  350.936779] ds90ub960 9-003d: 21e -> 4
    [  350.936962] ds90ub960 9-003d: 21f -> 0
    [  350.937148] ds90ub960 9-003d: 220 -> c3
    [  350.938233] ds90ub960 9-003d: 221 -> 3
    [  350.938469] ds90ub960 9-003d: 222 -> 0
    [  350.938658] ds90ub960 9-003d: 223 -> 0
    [  350.940541] ds90ub960 9-003d: 224 -> 1
    [  350.940759] ds90ub960 9-003d: 225 -> 0
    [  350.940946] ds90ub960 9-003d: 226 -> 0
    [  350.941136] ds90ub960 9-003d: 227 -> 0
    [  350.941314] ds90ub960 9-003d: 228 -> 0
    [  350.941497] ds90ub960 9-003d: 229 -> 0
    [  350.941673] ds90ub960 9-003d: 22a -> 0
    [  350.941862] ds90ub960 9-003d: 22b -> 0
    [  350.942436] ds90ub960 9-003d: 22c -> 0
    [  350.942715] ds90ub960 9-003d: 22d -> 0
    [  350.942915] ds90ub960 9-003d: 22e -> 0
    [  350.943108] ds90ub960 9-003d: 22f -> 0
    [  350.943300] ds90ub960 9-003d: 230 -> 0
    [  350.943487] ds90ub960 9-003d: 231 -> 0
    [  350.943679] ds90ub960 9-003d: 232 -> 12
    [  350.943863] ds90ub960 9-003d: 233 -> 63
    [  350.944065] ds90ub960 9-003d: 234 -> 31
    [  350.944245] ds90ub960 9-003d: 235 -> 11
    [  350.944434] ds90ub960 9-003d: 236 -> 0
    [  350.944627] ds90ub960 9-003d: 237 -> 10
    [  350.944812] ds90ub960 9-003d: 238 -> 0
    [  350.944999] ds90ub960 9-003d: 239 -> 0
    [  350.945278] ds90ub960 9-003d: 23a -> 0
    [  350.945463] ds90ub960 9-003d: 23b -> 0
    [  350.945649] ds90ub960 9-003d: 23c -> 0
    [  350.945828] ds90ub960 9-003d: 23d -> 0
    [  350.946021] ds90ub960 9-003d: 23e -> 0
    [  350.946533] ds90ub960 9-003d: 23f -> 0
    [  350.946740] ds90ub960 9-003d: 240 -> 0
    [  350.947009] ds90ub960 9-003d: 241 -> a9
    [  350.947215] ds90ub960 9-003d: 242 -> 71
    [  350.947406] ds90ub960 9-003d: 243 -> 1
    [  350.947744] ds90ub960 9-003d: 244 -> 0
    [  350.947946] ds90ub960 9-003d: 245 -> 0
    [  350.948131] ds90ub960 9-003d: 246 -> 20
    [  350.948308] ds90ub960 9-003d: 247 -> 0
    [  350.948492] ds90ub960 9-003d: 248 -> 0
    [  350.948677] ds90ub960 9-003d: 249 -> 0
    [  350.948860] ds90ub960 9-003d: 24a -> 0
    [  350.949043] ds90ub960 9-003d: 24b -> 12
    [  350.949228] ds90ub960 9-003d: 24c -> 1
    [  350.949418] ds90ub960 9-003d: 24d -> 3
    [  350.949605] ds90ub960 9-003d: 24e -> 14
    [  350.949790] ds90ub960 9-003d: 24f -> 64
    [  350.949967] ds90ub960 9-003d: 250 -> 0
    [  350.950413] ds90ub960 9-003d: 251 -> 0
    [  350.950618] ds90ub960 9-003d: 252 -> 0
    [  350.950802] ds90ub960 9-003d: 253 -> 2
    [  350.950977] ds90ub960 9-003d: 254 -> 0
    [  350.950980] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    [  350.950982] ds90ub960 9-003d: Rx port0 specific reg
    [  350.951156] ds90ub960 9-003d: 46 -> 20
    [  350.951333] ds90ub960 9-003d: 47 -> 0
    [  350.951522] ds90ub960 9-003d: 48 -> 0
    [  350.951713] ds90ub960 9-003d: 49 -> 0
    [  350.951901] ds90ub960 9-003d: 4a -> 0
    [  350.952081] ds90ub960 9-003d: 4b -> 12
    [  350.952266] ds90ub960 9-003d: 4c -> 1
    [  350.952475] ds90ub960 9-003d: 4d -> 3
    [  350.952662] ds90ub960 9-003d: 4e -> 4
    [  350.952850] ds90ub960 9-003d: 4f -> 64
    [  350.953039] ds90ub960 9-003d: 50 -> 0
    [  350.953224] ds90ub960 9-003d: 51 -> 0
    [  350.953411] ds90ub960 9-003d: 52 -> 0
    [  350.953596] ds90ub960 9-003d: 53 -> 2
    [  350.953782] ds90ub960 9-003d: 54 -> 0
    [  350.953969] ds90ub960 9-003d: 55 -> 0
    [  350.954423] ds90ub960 9-003d: 56 -> 0
    [  350.954659] ds90ub960 9-003d: 57 -> 0
    [  350.954904] ds90ub960 9-003d: 58 -> 5e
    [  350.955094] ds90ub960 9-003d: 59 -> 0
    [  350.955283] ds90ub960 9-003d: 5a -> 0
    [  350.955468] ds90ub960 9-003d: 5b -> 30
    [  350.955652] ds90ub960 9-003d: 5c -> 88
    [  350.955843] ds90ub960 9-003d: 5d -> c0
    [  350.956028] ds90ub960 9-003d: 5e -> 20
    [  350.956202] ds90ub960 9-003d: 5f -> 0
    [  350.956378] ds90ub960 9-003d: 60 -> 0
    [  350.956552] ds90ub960 9-003d: 61 -> 0
    [  350.956730] ds90ub960 9-003d: 62 -> 0
    [  350.956906] ds90ub960 9-003d: 63 -> 0
    [  350.957080] ds90ub960 9-003d: 64 -> 0
    [  350.957257] ds90ub960 9-003d: 65 -> 94
    [  350.957432] ds90ub960 9-003d: 66 -> 98
    [  350.957605] ds90ub960 9-003d: 67 -> 0
    [  350.957779] ds90ub960 9-003d: 68 -> 0
    [  350.957980] ds90ub960 9-003d: 69 -> 0
    [  350.958363] ds90ub960 9-003d: 6a -> 0
    [  350.958553] ds90ub960 9-003d: 6b -> 0
    [  350.958739] ds90ub960 9-003d: 6c -> 0
    [  350.958930] ds90ub960 9-003d: 6d -> 78
    [  350.959109] ds90ub960 9-003d: 6e -> 88
    [  350.959285] ds90ub960 9-003d: 6f -> 88
    [  350.959459] ds90ub960 9-003d: 70 -> 2b
    [  350.959634] ds90ub960 9-003d: 71 -> 2c
    [  350.959826] ds90ub960 9-003d: 72 -> 0
    [  350.960003] ds90ub960 9-003d: 73 -> 3
    [  350.960178] ds90ub960 9-003d: 74 -> 20
    [  350.960352] ds90ub960 9-003d: 75 -> 6
    [  350.960525] ds90ub960 9-003d: 76 -> 40
    [  350.960699] ds90ub960 9-003d: 77 -> c5
    [  350.960874] ds90ub960 9-003d: 78 -> 0
    [  350.961048] ds90ub960 9-003d: 79 -> 1
    [  350.961233] ds90ub960 9-003d: 7a -> 0
    [  350.961414] ds90ub960 9-003d: 7b -> 0
    [  350.961592] ds90ub960 9-003d: 7c -> 20
    [  350.961773] ds90ub960 9-003d: 7d -> 0
    [  350.961952] ds90ub960 9-003d: 7e -> 0
    [  350.961955] ds90ub960 9-003d: Rx port0 specific debug reg
    [  350.962359] ds90ub960 9-003d: d0 -> 0
    [  350.962556] ds90ub960 9-003d: d1 -> 43
    [  350.962740] ds90ub960 9-003d: d2 -> 94
    [  350.962968] ds90ub960 9-003d: d3 -> 0
    [  350.963150] ds90ub960 9-003d: d4 -> 60
    [  350.963345] ds90ub960 9-003d: d5 -> e0
    [  350.963556] ds90ub960 9-003d: d6 -> 0
    [  350.963742] ds90ub960 9-003d: d7 -> 2
    [  350.963926] ds90ub960 9-003d: d8 -> 7
    [  350.964106] ds90ub960 9-003d: d9 -> 7f
    [  350.964278] ds90ub960 9-003d: da -> 0
    [  350.964624] ds90ub960 9-003d: db -> 0
    [  350.964802] ds90ub960 9-003d: dc -> 0
    [  350.964978] ds90ub960 9-003d: dd -> 0
    [  350.965154] ds90ub960 9-003d: de -> 0
    [  350.965157] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    [  350.965159] ds90ub960 9-003d: Rx port1 specific reg
    [  350.965473] ds90ub960 9-003d: 46 -> 20
    [  350.965657] ds90ub960 9-003d: 47 -> 0
    [  350.965836] ds90ub960 9-003d: 48 -> 0
    [  350.966419] ds90ub960 9-003d: 49 -> 0
    [  350.966612] ds90ub960 9-003d: 4a -> 0
    [  350.966988] ds90ub960 9-003d: 4b -> 12
    [  350.967169] ds90ub960 9-003d: 4c -> 12
    [  350.967343] ds90ub960 9-003d: 4d -> 43
    [  350.967525] ds90ub960 9-003d: 4e -> 4
    [  350.967705] ds90ub960 9-003d: 4f -> 64
    [  350.967879] ds90ub960 9-003d: 50 -> 0
    [  350.968226] ds90ub960 9-003d: 51 -> 0
    [  350.968416] ds90ub960 9-003d: 52 -> 0
    [  350.968592] ds90ub960 9-003d: 53 -> 3
    [  350.968766] ds90ub960 9-003d: 54 -> 0
    [  350.968942] ds90ub960 9-003d: 55 -> 0
    [  350.969132] ds90ub960 9-003d: 56 -> 0
    [  350.969316] ds90ub960 9-003d: 57 -> 0
    [  350.969492] ds90ub960 9-003d: 58 -> 5e
    [  350.969667] ds90ub960 9-003d: 59 -> 0
    [  350.969841] ds90ub960 9-003d: 5a -> 0
    [  350.970016] ds90ub960 9-003d: 5b -> 30
    [  350.970504] ds90ub960 9-003d: 5c -> 8a
    [  350.970714] ds90ub960 9-003d: 5d -> c0
    [  350.970910] ds90ub960 9-003d: 5e -> 20
    [  350.971093] ds90ub960 9-003d: 5f -> 0
    [  350.971280] ds90ub960 9-003d: 60 -> 0
    [  350.971471] ds90ub960 9-003d: 61 -> 0
    [  350.971650] ds90ub960 9-003d: 62 -> 0
    [  350.971826] ds90ub960 9-003d: 63 -> 0
    [  350.972000] ds90ub960 9-003d: 64 -> 0
    [  350.972174] ds90ub960 9-003d: 65 -> 96
    [  350.972351] ds90ub960 9-003d: 66 -> 9a
    [  350.972525] ds90ub960 9-003d: 67 -> 0
    [  350.972700] ds90ub960 9-003d: 68 -> 0
    [  350.972873] ds90ub960 9-003d: 69 -> 0
    [  350.973047] ds90ub960 9-003d: 6a -> 0
    [  350.973222] ds90ub960 9-003d: 6b -> 0
    [  350.973397] ds90ub960 9-003d: 6c -> 0
    [  350.973581] ds90ub960 9-003d: 6d -> 78
    [  350.973762] ds90ub960 9-003d: 6e -> 88
    [  350.973937] ds90ub960 9-003d: 6f -> 88
    [  350.974470] ds90ub960 9-003d: 70 -> 6b
    [  350.974654] ds90ub960 9-003d: 71 -> 6c
    [  350.974829] ds90ub960 9-003d: 72 -> 55
    [  350.975007] ds90ub960 9-003d: 73 -> 3
    [  350.975183] ds90ub960 9-003d: 74 -> 20
    [  350.975358] ds90ub960 9-003d: 75 -> 6
    [  350.975544] ds90ub960 9-003d: 76 -> 40
    [  350.975727] ds90ub960 9-003d: 77 -> c5
    [  350.975906] ds90ub960 9-003d: 78 -> 0
    [  350.976082] ds90ub960 9-003d: 79 -> 1
    [  350.976260] ds90ub960 9-003d: 7a -> 0
    [  350.976440] ds90ub960 9-003d: 7b -> 0
    [  350.976643] ds90ub960 9-003d: 7c -> 20
    [  350.976828] ds90ub960 9-003d: 7d -> 0
    [  350.977155] ds90ub960 9-003d: 7e -> 0
    [  350.977158] ds90ub960 9-003d: Rx  port1 specific debug reg
    [  350.977494] ds90ub960 9-003d: d0 -> 0
    [  350.977680] ds90ub960 9-003d: d1 -> 43
    [  350.978358] ds90ub960 9-003d: d2 -> 94
    [  350.978550] ds90ub960 9-003d: d3 -> 0
    [  350.978784] ds90ub960 9-003d: d4 -> 60
    [  350.978971] ds90ub960 9-003d: d5 -> e0
    [  350.979157] ds90ub960 9-003d: d6 -> 0
    [  350.979569] ds90ub960 9-003d: d7 -> 2
    [  350.979755] ds90ub960 9-003d: d8 -> 7
    [  350.979931] ds90ub960 9-003d: d9 -> 7f
    [  350.980107] ds90ub960 9-003d: da -> 0
    [  350.980757] ds90ub960 9-003d: db -> 0
    [  350.980954] ds90ub960 9-003d: dc -> 0
    [  350.981347] ds90ub960 9-003d: dd -> 0
    [  350.981553] ds90ub960 9-003d: de -> 0
    [  350.981556] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
    [  350.981559] ds90ub960 9-003d: Tx port1 specific reg
    [  350.982350] ds90ub960 9-003d: 33 -> 63
    [  350.982584] ds90ub960 9-003d: 34 -> 31
    [  350.982769] ds90ub960 9-003d: 35 -> 11
    [  350.982960] ds90ub960 9-003d: 36 -> 0
    [  350.983141] ds90ub960 9-003d: 37 -> 10
    [  350.983325] ds90ub960 9-003d: 38 -> 0
    [  350.983509] ds90ub960 9-003d: 39 -> 0
    [  350.983511] ds90ub960 9-003d: -----------------------------------------------------------------------------------------
  • Regarding the clock, we have measured it using an oscilloscope it is a perfect 25MHz, I have seen other posts reporting the wrong frequency in the same reg, it seems to be because of a jitter in the internal clock.
  • Hi Kayas,
    I will review the provided data and get back to you.
    Can you make sure the 25MHz oscillator fulfills our specs as per data sheet Table 7-3
  • Kayas,
    I have reviewed the provided dumps. Everything looks good. However, there are minor findings:
    SER:
    0x07 = 0xFF -- What CLKOUT frequency to the imager are you configuring?
    0x0A = 0x10 -- It is recommended to change to 0x12
    0x52 = 0x47 -- CRC errors detected
    0x55 = 0x03 -- number of detected CRC errors
    DES:
    0x20 = 0xC3 -- Both RX port 0 & 1 are forwarded to CSI TX port 1.
    0x21 = 0x03 -- Round robin forwarding enabled for CSI TX port 0 & 1. Please disable forwarding for TX port 0 since it is not used.
    Can you check your Image sensor's blanking configurations? You may have large blanking which will increase the data rate. You know buffer error can only happens if the incoming data on RX ports of the DES is larger than what the TX can handel.
    Also, make sure your SoC input is configured to ≥ 1.6Gbps/lane.
  • Hi Hamzeh,
    Thanks for the analysis.
    SER:
    Clkout is not being used in our case and others are unrelated to this buffer issue.
    It cannot be large enough that it can cause this issue, as I said before I was able to stream a single camera at 120fps.
    We have made sure that it is within the specs.
    Weird behaviors are seen I can stream 60fps from both cameras for some time before getting into an error, I don't understand what can cause this.
    Kayas
  • Hello Kayas,
    Buffer error can only happen in the following two cases:
    1) When the data cannot be transmitted into the CSI output port faster than it is being received. So, it indicates an issue of aggregating the too much data from many sensors, or
    2) The received line length is larger than the buffer (16kb / port) can store.
    Can you check the following two settings:
    1) Your SoC input is configured to ≥ 1.6Gbps/lane
    2) Your Image sensor output is configured to 800Mbps/lane or less
  • Hi Hamzeh,
    The camera max data rate is 800Mbps.
    Yes, the input is configured to be more than 1.6 Gbps.
    The length of the received line length, from register 0x75, and 0x76 of DES is 1600 bytes which is less than 16kb.
    The output CSI clock is set to 1.6GHz which should be fast enough to send the data out.
    Kayas Ahmed
  • Hi Kayas,
    Is there any way to reduce the sensor lane speed down from 800Mbps/lane? Because the data format you are transmitting should only require around 380Mbps/lane (using 2 lanes). What I think it happening here is that the sensor is sending the whole frame very quickly with minimal LP11 time between lines, and then sitting idle for a long period of time before the next frame. Instead, it would be better to reduce the vertical blanking by slowing down the line rate while still maintaining the same pixels and frame rate.
