Part Number: TLK2711-SP
Other Parts Discussed in Thread: TLK2501,
We're planning to use a TLK2501 (CML) to interface with an existing product that uses the TLK2711 part (VML). This existing product currently interfaces with another TLK2711 part through an AC coupled interface.
I understand that this AC coupling is used to enable interconnection from a device with a wide variety of receivers. Only to confirm in this specific case, could you please review the understanding stated below and in the picture to ensure it's correct for this interface:
For the transmission circuit for the TLK2711, only the series AC coupling capacitors are required.
For the transmission circuit for the TLK2501, termination resistors are required in both lines, along with the series AC coupling capacitors.
For the receiver circuit for the TLK2711, only the series AC coupling capacitor is required, as the devices already have integrated termination resistors.
For the transmission circuit for the TLK2501, both series AC coupling capacitors and termination resistors in both lines are required.
Thanks in advance for your support.
Best regards.
