Part Number: TCAN1043-Q1
Pin no: 11 of TCAN1043-Q1 is found to be NC. How do we handle this pin . Is it ok to float or is it be pulled low or high ? In case if we keep it floating due to some reasons would it create any issues ?
Hi Sikesh,
The NC pin can be left floating or pulled to ground. The datasheet section 9.2 'Typical Application' (page 34) shows the pin left floating. On the TI TCAN1043-Q1 EVM, the pin is default floating with an optional pull-down resistor: TCAN1043HG-Q1 Evaluation Module
Regards, Amy
