Other Parts Discussed in Thread: DP83TC811
I configured the DP83TC811 to Test Mode 5 according to document snla276 for Transmitter Power Spectral Density
The result was a failure. Can I adjust the registers to fix it
Hi Kung,
You should also follow SNLA293: https://www.ti.com/lit/an/snla293/snla293.pdf?ts=1718399220027&ref_url=https%253A%252F%252Fwww.google.com%252F
Can you confirm you are also programming the correct registers mentioned in the section ' 3 Software Configuration' of the above document?
Are you using extended register writes?
Melissa
Hi Kung,
Thank you for attaching SNLA276, this document has the correct registers for test modes. Can you confirm you are also programming the initialization registers (using extended register writes) mentioned in section 3 of SNLA293? This is required to pass Compliance aswell.
Melissa
After modify the DP83TC811 register (Line Driver Control 0X0400) as below from 45.6 ohm(default) to 34.4 ohm,fail item change to PASS.
