TCAN1463-Q1: TCAN1463-Q1:
Part Number: TCAN1463-Q1
Hi Team,
We are using  following CAN transceiver ICs  in my project, for meeting component multi-sourcing requirement. As of now project status is C_ sample phase.
1. TCAN1463-Q1 or
2. TJA1463ATK.
We are using Transceiver in  CAN FD mode.  Arbitration phase 500kbps & Data phase is 5 MBPS.
We are facing below problem whenever using TCAN1463-Q1 IC. (No issue in TJA1463ATK IC)
 Problem: When ever we are simulating the Sleep mode in ECU. ECU is continuously going to sleep and wake up modes due to CAN transceiver.
Observations:
  • Initially Transceiver will be moved to standby mode from Normal mode then moved in sleep mode.
  • During sleep mode transition  the TCAN1463 INH is going to high( after 8 to 10 msec) without any trigger & it will not allow MCU to sleep mode.
 My circuit:
Thanks& Regards,
Giridhar.
