DP83826I: The difference between the full-duplex and half-duplex default settings when auto-negotiation is enabled
Part Number: DP83826I
Hi Team,
This question about relationship between the full-duplex and half-duplex default settings and auto-negotiation.
I understand that if both link partners support auto-negotiation and both full-duplex and half-duplex at the same speed, full-duplex is prioritized.
I also understand that if the link partner does not support auto-negotiation, it will attempt to communicate in half-duplex.
If auto-negotiation is enabled, what is the difference between the full-duplex and half-duplex default settings?
Please let me know if there are any different points to note for each.
  • Hi Atsushi,
    Half-Duplex is when only one link partner can talk at a time, like the way humans speak, one talks while the other listens. Full-Duplex means both link partners can speak and listen at the same time.
    Did I understand and answer your question?
    Alvaro
  • Hi Alvaro-san,
    I'm sorry.
    My explanation was insufficient.
    I understand full-duplex and half-duplex communication methods.
    What I'd like to know is what the default settings full-duplex and half-duplex are for.
    If auto-negotiation is enabled, full-duplex and half-duplex should be set automatically.
    Does it mean that it tries to communicate with the default settings when auto-negotiation fails?
  • Hi Atsushi,
    Auto-negotiation will try to link at the fastest speed and duplex advertised between both PHYs at each end of the link. For 10/100 speeds, the advertisements can be found in Reg 0x4, for 1000 speed, the advertisements can be found in Register 0x9.
    For example:
    PHY1 <-Ethernet Cable-> PHY2
    PHY 1 advertises10/100/1000 Speeds at Full and Half duplex.
    PHY 2 advertises only 100 Half duplex
    Through the auto-negotiation process, the two PHYs will agree to link up and communicate at 100Mbps half duplex, since that is the only common setting.
    Please let me know if I didn't answer your question.
    Alvaro
  • Hi Alvaro-san,
    Thank you for your reply but my question is not solved.
    The default setting I'm referring to is the Full/Half Duplex setting of the Bootstraps option in Basic mode(Table 9-18).
    The customer is confused as to whether this bootstrap option should be set to full duplex or half duplex when auto-negotiation is enabled.
    If auto-negotiation is enabled, will this setting be ignored?
    That is, will it have no effect on communication no matter which setting they use here?
  • Hi Atsushi,
    Thank you for clarifying, now I clearly understand the question.
    No, this setting will not be ignored. This will control what gets advertised during auto-negotiation. The advertised capabilities can be found by reading Reg 0x4, the strap setting essentially controls which bits in Reg 0x4 get set high or low. I would recommend the customer strap this into "Full Duplex".
    Alvaro
  • Hi Alvaro-san,
    Thanks to your help, I have a better understanding.
    However, I still don't fully understand it.
    Is my understanding of the following correct?
    If that is wrong, please correct it.
    - When RX_D0/Strap0 is 1=Half duplex, That is default, only Bit[7, 5] of the ANAR Register (Offset = 4h) will be 1h.
    - When RX_D0/Strap0 is 0=Full duplex, only Bit[8, 6] of the ANAR Register (Offset = 4h) will be 1h.
    Ideally, we would like to advertise all communication modes, but how can we do this?
  • Hi Atsushi,
    Your understanding is correct. If you want to advertise all modes, please write Reg 0x4 = 0x1E1.
    Alvaro
  • Hi Alvaro-san,
    You said,
    Could you tell me the reason for this?
    I'm concerned that by strapping into "Full duplex", "Half duplex" will become unusable with auto-negotiation.
  • Hi Atsushi,
    I apologize for the confusion, I was mistaken.
    Setting Strap 0 (RXD0)
    • to Mode 0: Full Duplex - will enable all communication, Full and Half duplex.
    • to Mode 1: Half Duplex - will only allow Half Duplex communication
    No Register configuration is need to achieve auto-negotiation will both speeds and duplexes.
    Alvaro
