I am designing a board that will drive the 1.28Gbps LVDS signal from DS92LV16TVHG using DS25BR100 and send it to DS92LV16TVHG on the other board. A 50cm Cat5e Ethernet cable is used between the two boards.
According to Figure 1 on page 7 of www.ti.com/.../ds25br100.pdf, a 1.28Gbps signal seems to be no problem. However, the end user has specified that each of the four pairs of Cat5e cable on this board should have an independent 1.28Gbps LVDS signal. Is it possible to pass 1.28Gbps LVDS signals through all four channels without a problem under these conditions? Personally, I am concerned about the possibility of the LVDS signal not being transmitted correctly due to crosstalk between pairs.
