SN65DSI84: drm bridge attach not called 5.15 linux kernel on imx8qxp
Part Number: SN65DSI84
Other Parts Discussed in Thread: SN65DSI83
I am struglling to display from mipi-dsi to dual lvds using sn65dsi84.
It's ok to i2cdetect and device's registry value.
However, the drm_bridge_attach function is not called after the device probe.
I think the problem with the device driver is the cause.
<device tree>
    panel_lvds: panel-lvds {
        compatible = "panel-lvds";
        /* Physical dimensions of active area */
        width-mm = <338>;
        height-mm = <270>;
        data-mapping = "vesa-24";
        status = "okay";
        panel-timing {
            /* the hactive and porches in the datasheet are for a single LVDS channel */
            /* since we use dual LVDS channel, Horizontal paramter and clock must double*/
            clock-frequency = <53982240>;
            hactive = <640>;
            hsync-len = <10>;
            hfront-porch = <97>;
            hback-porch = <97>;
            vactive = <1024>;
            vsync-len = <10>;
            vfront-porch = <16>;
            vback-porch = <16>;
        ports {
            #address-cells = <1>;
            #size-cells = <0>;
            port@0 {
                reg = <0>;
                dual-lvds-odd-pixels;
                panel_in_a: endpoint {
                    remote-endpoint = <&bridge_out_a>;
            port@1 {
                reg = <1>;
                dual-lvds-even-pixels;
                panel_in_b: endpoint {
                    remote-endpoint = <&bridge_out_b>;
&i2c0_mipi_lvds1 {
	#size-cells = <0>;
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_i2c0_mipi_lvds1>;
	clock-frequency = <100000>;
	status = "okay";
    bridge@2c {
		compatible = "ti,sn65dsi84";
		reg = <0x2c>;
        pinctrl-0 = <&pinctrl_mipi_dsi_rst>;
		enable-gpios = <&lsio_gpio1 9 GPIO_ACTIVE_HIGH>;
		interrupt-parent = <&lsio_gpio1>;
		interrupts = <10 IRQ_TYPE_EDGE_FALLING>;
		irq-gpios = <&lsio_gpio1 10 IRQ_TYPE_EDGE_FALLING>;
		status = "okay";
		ports {
			#size-cells = <0>;
			port@0 {
				reg = <0>;
				bridge_in: endpoint {
					remote-endpoint = <&dsi_out_port>;
					data-lanes = <1 2 3 4>;
            port@2 {
                reg = <2>;
                bridge_out_a: endpoint {
                    remote-endpoint = <&panel_in_a>;
            port@3 {
                reg = <3>;
                bridge_out_b: endpoint {
                    remote-endpoint = <&panel_in_b>;
&mipi1_dphy {
        status = "okay";
&mipi1_dsi_host {
	status = "okay";
	ports {
		port@1 {
			reg = <1>;
            dsi_out_port: endpoint {
                remote-endpoint = <&bridge_in>;
<sn65dsi83.c>
// SPDX-License-Identifier: GPL-2.0
 * TI SN65DSI83,84,85 driver
 * Currently supported:
 * - SN65DSI83
 *   = 1x Single-link DSI ~ 1x Single-link LVDS
 *   - Supported
 *   - Single-link LVDS mode tested
 * - SN65DSI84
 *   = 1x Single-link DSI ~ 2x Single-link or 1x Dual-link LVDS
 *   - Supported
 *   - Dual-link LVDS mode tested
 *   - 2x Single-link LVDS mode unsupported
 *     (should be easy to add by someone who has the HW)
 * - SN65DSI85
 *   = 2x Single-link or 1x Dual-link DSI ~ 2x Single-link or 1x Dual-link LVDS
 *   - Unsupported
 * Copyright (C) 2021 Marek Vasut <marex@denx.de>
 * Based on previous work of:
 * Valentin Raevsky <valentin@compulab.co.il>
 * Philippe Schenker <philippe.schenker@toradex.com>
#include <linux/bits.h>
#include <linux/clk.h>
#include <linux/gpio/consumer.h>
#include <linux/i2c.h>
#include <linux/module.h>
#include <linux/of_device.h>
#include <linux/of_graph.h>
#include <linux/regmap.h>
#include <drm/drm_atomic_helper.h>
#include <drm/drm_bridge.h>
#include <drm/drm_mipi_dsi.h>
#include <drm/drm_of.h>
#include <drm/drm_panel.h>
#include <drm/drm_print.h>
#include <drm/drm_probe_helper.h>
/* ID registers */
#define REG_ID(n)				(0x00 + (n))
/* Reset and clock registers */
#define REG_RC_RESET				0x09
#define  REG_RC_RESET_SOFT_RESET		BIT(0)
#define REG_RC_LVDS_PLL				0x0a
#define  REG_RC_LVDS_PLL_PLL_EN_STAT		BIT(7)
#define  REG_RC_LVDS_PLL_LVDS_CLK_RANGE(n)	(((n) & 0x7) << 1)
#define  REG_RC_LVDS_PLL_HS_CLK_SRC_DPHY	BIT(0)
#define REG_RC_DSI_CLK				0x0b
#define  REG_RC_DSI_CLK_DSI_CLK_DIVIDER(n)	(((n) & 0x1f) << 3)
#define  REG_RC_DSI_CLK_REFCLK_MULTIPLIER(n)	((n) & 0x3)
#define REG_RC_PLL_EN				0x0d
#define  REG_RC_PLL_EN_PLL_EN			BIT(0)
/* DSI registers */
#define REG_DSI_LANE				0x10
#define  REG_DSI_LANE_LEFT_RIGHT_PIXELS		BIT(7)	/* DSI85-only */
#define  REG_DSI_LANE_DSI_CHANNEL_MODE_DUAL	0	/* DSI85-only */
#define  REG_DSI_LANE_DSI_CHANNEL_MODE_2SINGLE	BIT(6)	/* DSI85-only */
#define  REG_DSI_LANE_DSI_CHANNEL_MODE_SINGLE	BIT(5)
#define  REG_DSI_LANE_CHA_DSI_LANES(n)		(((n) & 0x3) << 3)
#define  REG_DSI_LANE_CHB_DSI_LANES(n)		(((n) & 0x3) << 1)
#define  REG_DSI_LANE_SOT_ERR_TOL_DIS		BIT(0)
#define REG_DSI_EQ				0x11
#define  REG_DSI_EQ_CHA_DSI_DATA_EQ(n)		(((n) & 0x3) << 6)
#define  REG_DSI_EQ_CHA_DSI_CLK_EQ(n)		(((n) & 0x3) << 2)
#define REG_DSI_CLK				0x12
#define  REG_DSI_CLK_CHA_DSI_CLK_RANGE(n)	((n) & 0xff)
/* LVDS registers */
#define REG_LVDS_FMT				0x18
#define  REG_LVDS_FMT_DE_NEG_POLARITY		BIT(7)
#define  REG_LVDS_FMT_HS_NEG_POLARITY		BIT(6)
#define  REG_LVDS_FMT_VS_NEG_POLARITY		BIT(5)
#define  REG_LVDS_FMT_LVDS_LINK_CFG		BIT(4)	/* 0:AB 1:A-only */
#define  REG_LVDS_FMT_CHA_24BPP_MODE		BIT(3)
#define  REG_LVDS_FMT_CHB_24BPP_MODE		BIT(2)
#define  REG_LVDS_FMT_CHA_24BPP_FORMAT1		BIT(1)
#define  REG_LVDS_FMT_CHB_24BPP_FORMAT1		BIT(0)
#define REG_LVDS_VCOM				0x19
#define  REG_LVDS_VCOM_CHA_LVDS_VOCM		BIT(6)
#define  REG_LVDS_VCOM_CHB_LVDS_VOCM		BIT(4)
#define  REG_LVDS_VCOM_CHA_LVDS_VOD_SWING(n)	(((n) & 0x3) << 2)
#define  REG_LVDS_VCOM_CHB_LVDS_VOD_SWING(n)	((n) & 0x3)
#define REG_LVDS_LANE				0x1a
#define  REG_LVDS_LANE_EVEN_ODD_SWAP		BIT(6)
#define  REG_LVDS_LANE_CHA_REVERSE_LVDS		BIT(5)
#define  REG_LVDS_LANE_CHB_REVERSE_LVDS		BIT(4)
#define  REG_LVDS_LANE_CHA_LVDS_TERM		BIT(1)
#define  REG_LVDS_LANE_CHB_LVDS_TERM		BIT(0)
#define REG_LVDS_CM				0x1b
#define  REG_LVDS_CM_CHA_LVDS_CM_ADJUST(n)	(((n) & 0x3) << 4)
#define  REG_LVDS_CM_CHB_LVDS_CM_ADJUST(n)	((n) & 0x3)
/* Video registers */
#define REG_VID_CHA_ACTIVE_LINE_LENGTH_LOW	0x20
#define REG_VID_CHA_ACTIVE_LINE_LENGTH_HIGH	0x21
#define REG_VID_CHA_VERTICAL_DISPLAY_SIZE_LOW	0x24
#define REG_VID_CHA_VERTICAL_DISPLAY_SIZE_HIGH	0x25
#define REG_VID_CHA_SYNC_DELAY_LOW		0x28
#define REG_VID_CHA_SYNC_DELAY_HIGH		0x29
#define REG_VID_CHA_HSYNC_PULSE_WIDTH_LOW	0x2c
#define REG_VID_CHA_HSYNC_PULSE_WIDTH_HIGH	0x2d
#define REG_VID_CHA_VSYNC_PULSE_WIDTH_LOW	0x30
#define REG_VID_CHA_VSYNC_PULSE_WIDTH_HIGH	0x31
#define REG_VID_CHA_HORIZONTAL_BACK_PORCH	0x34
#define REG_VID_CHA_VERTICAL_BACK_PORCH		0x36
#define REG_VID_CHA_HORIZONTAL_FRONT_PORCH	0x38
#define REG_VID_CHA_VERTICAL_FRONT_PORCH	0x3a
#define REG_VID_CHA_TEST_PATTERN		0x3c
/* IRQ registers */
#define REG_IRQ_GLOBAL				0xe0
#define  REG_IRQ_GLOBAL_IRQ_EN			BIT(0)
#define REG_IRQ_EN				0xe1
#define  REG_IRQ_EN_CHA_SYNCH_ERR_EN		BIT(7)
#define  REG_IRQ_EN_CHA_CRC_ERR_EN		BIT(6)
#define  REG_IRQ_EN_CHA_UNC_ECC_ERR_EN		BIT(5)
#define  REG_IRQ_EN_CHA_COR_ECC_ERR_EN		BIT(4)
#define  REG_IRQ_EN_CHA_LLP_ERR_EN		BIT(3)
#define  REG_IRQ_EN_CHA_SOT_BIT_ERR_EN		BIT(2)
#define  REG_IRQ_EN_CHA_PLL_UNLOCK_EN		BIT(0)
#define REG_IRQ_STAT				0xe5
#define  REG_IRQ_STAT_CHA_SYNCH_ERR		BIT(7)
#define  REG_IRQ_STAT_CHA_CRC_ERR		BIT(6)
#define  REG_IRQ_STAT_CHA_UNC_ECC_ERR		BIT(5)
#define  REG_IRQ_STAT_CHA_COR_ECC_ERR		BIT(4)
#define  REG_IRQ_STAT_CHA_LLP_ERR		BIT(3)
#define  REG_IRQ_STAT_CHA_SOT_BIT_ERR		BIT(2)
#define  REG_IRQ_STAT_CHA_PLL_UNLOCK		BIT(0)
enum sn65dsi83_model {
	MODEL_SN65DSI83,
	MODEL_SN65DSI84,
struct sn65dsi83 {
	struct drm_bridge		bridge;
	struct device			*dev;
	struct regmap			*regmap;
	struct device_node		*host_node;
	struct mipi_dsi_device		*dsi;
	struct drm_bridge		*panel_bridge;
	struct gpio_desc		*enable_gpio;
	int				dsi_lanes;
	bool				lvds_dual_link;
	bool				lvds_dual_link_even_odd_swap;
static const struct regmap_range sn65dsi83_readable_ranges[] = {
	regmap_reg_range(REG_ID(0), REG_ID(8)),
	regmap_reg_range(REG_RC_LVDS_PLL, REG_RC_DSI_CLK),
	regmap_reg_range(REG_RC_PLL_EN, REG_RC_PLL_EN),
	regmap_reg_range(REG_DSI_LANE, REG_DSI_CLK),
	regmap_reg_range(REG_LVDS_FMT, REG_LVDS_CM),
	regmap_reg_range(REG_VID_CHA_ACTIVE_LINE_LENGTH_LOW,
			 REG_VID_CHA_ACTIVE_LINE_LENGTH_HIGH),
	regmap_reg_range(REG_VID_CHA_VERTICAL_DISPLAY_SIZE_LOW,
			 REG_VID_CHA_VERTICAL_DISPLAY_SIZE_HIGH),
	regmap_reg_range(REG_VID_CHA_SYNC_DELAY_LOW,
			 REG_VID_CHA_SYNC_DELAY_HIGH),
	regmap_reg_range(REG_VID_CHA_HSYNC_PULSE_WIDTH_LOW,
			 REG_VID_CHA_HSYNC_PULSE_WIDTH_HIGH),
	regmap_reg_range(REG_VID_CHA_VSYNC_PULSE_WIDTH_LOW,
			 REG_VID_CHA_VSYNC_PULSE_WIDTH_HIGH),
	regmap_reg_range(REG_VID_CHA_HORIZONTAL_BACK_PORCH,
			 REG_VID_CHA_HORIZONTAL_BACK_PORCH),
	regmap_reg_range(REG_VID_CHA_VERTICAL_BACK_PORCH,
			 REG_VID_CHA_VERTICAL_BACK_PORCH),
	regmap_reg_range(REG_VID_CHA_HORIZONTAL_FRONT_PORCH,
			 REG_VID_CHA_HORIZONTAL_FRONT_PORCH),
	regmap_reg_range(REG_VID_CHA_VERTICAL_FRONT_PORCH,
			 REG_VID_CHA_VERTICAL_FRONT_PORCH),
	regmap_reg_range(REG_VID_CHA_TEST_PATTERN, REG_VID_CHA_TEST_PATTERN),
	regmap_reg_range(REG_IRQ_GLOBAL, REG_IRQ_EN),
	regmap_reg_range(REG_IRQ_STAT, REG_IRQ_STAT),
static const struct regmap_access_table sn65dsi83_readable_table = {
	.yes_ranges = sn65dsi83_readable_ranges,
	.n_yes_ranges = ARRAY_SIZE(sn65dsi83_readable_ranges),
static const struct regmap_range sn65dsi83_writeable_ranges[] = {
	regmap_reg_range(REG_RC_RESET, REG_RC_DSI_CLK),
static const struct regmap_access_table sn65dsi83_writeable_table = {
	.yes_ranges = sn65dsi83_writeable_ranges,
	.n_yes_ranges = ARRAY_SIZE(sn65dsi83_writeable_ranges),
static const struct regmap_range sn65dsi83_volatile_ranges[] = {
	regmap_reg_range(REG_RC_RESET, REG_RC_RESET),
	regmap_reg_range(REG_RC_LVDS_PLL, REG_RC_LVDS_PLL),
static const struct regmap_access_table sn65dsi83_volatile_table = {
	.yes_ranges = sn65dsi83_volatile_ranges,
	.n_yes_ranges = ARRAY_SIZE(sn65dsi83_volatile_ranges),
static const struct regmap_config sn65dsi83_regmap_config = {
	.reg_bits = 8,
	.val_bits = 8,
	.rd_table = &sn65dsi83_readable_table,
	.wr_table = &sn65dsi83_writeable_table,
	.volatile_table = &sn65dsi83_volatile_table,
	.cache_type = REGCACHE_RBTREE,
	.max_register = REG_IRQ_STAT,
static struct sn65dsi83 *bridge_to_sn65dsi83(struct drm_bridge *bridge)
	return container_of(bridge, struct sn65dsi83, bridge);
static int sn65dsi83_attach(struct drm_bridge *bridge,
			    enum drm_bridge_attach_flags flags)
	struct sn65dsi83 *ctx = bridge_to_sn65dsi83(bridge);
	struct device *dev = ctx->dev;
	struct mipi_dsi_host *host;
	int ret = 0;
	const struct mipi_dsi_device_info info = {
		.type = "sn65dsi83",
		.channel = 0,
		.node = NULL,
    printk("sn65dsi: attach");
	host = of_find_mipi_dsi_host_by_node(ctx->host_node);
	if (!host) {
		dev_err(dev, "failed to find dsi host\n");
		return -EPROBE_DEFER;
	dsi = mipi_dsi_device_register_full(host, &info);
	if (IS_ERR(dsi)) {
		return dev_err_probe(dev, PTR_ERR(dsi),
				     "failed to create dsi device\n");
	ctx->dsi = dsi;
	dsi->lanes = ctx->dsi_lanes;
	dsi->format = MIPI_DSI_FMT_RGB888;
//	dsi->mode_flags = MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST;
    dsi->mode_flags = MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_SYNC_PULSE;
	ret = mipi_dsi_attach(dsi);
	if (ret < 0) {
		dev_err(dev, "failed to attach dsi to host\n");
		goto err_dsi_attach;
	return drm_bridge_attach(bridge->encoder, ctx->panel_bridge,
				 &ctx->bridge, flags);
err_dsi_attach:
	mipi_dsi_device_unregister(dsi);
	return ret;
static void sn65dsi83_atomic_pre_enable(struct drm_bridge *bridge,
					struct drm_bridge_state *old_bridge_state)
	 * Reset the chip, pull EN line low for t_reset=10ms,
	 * then high for t_en=1ms.
	regcache_mark_dirty(ctx->regmap);
	gpiod_set_value(ctx->enable_gpio, 0);
	usleep_range(10000, 11000);
	gpiod_set_value(ctx->enable_gpio, 1);
	usleep_range(1000, 1100);
static u8 sn65dsi83_get_lvds_range(struct sn65dsi83 *ctx,
				   const struct drm_display_mode *mode)
	 * The encoding of the LVDS_CLK_RANGE is as follows:
	 * 000 - 25 MHz <= LVDS_CLK < 37.5 MHz
	 * 001 - 37.5 MHz <= LVDS_CLK < 62.5 MHz
	 * 010 - 62.5 MHz <= LVDS_CLK < 87.5 MHz
	 * 011 - 87.5 MHz <= LVDS_CLK < 112.5 MHz
	 * 100 - 112.5 MHz <= LVDS_CLK < 137.5 MHz
	 * 101 - 137.5 MHz <= LVDS_CLK <= 154 MHz
	 * which is a range of 12.5MHz..162.5MHz in 50MHz steps, except that
	 * the ends of the ranges are clamped to the supported range. Since
	 * sn65dsi83_mode_valid() already filters the valid modes and limits
	 * the clock to 25..154 MHz, the range calculation can be simplified
	 * as follows:
	int mode_clock = mode->clock;
	if (ctx->lvds_dual_link)
		mode_clock /= 2;
	return (mode_clock - 12500) / 25000;
static u8 sn65dsi83_get_dsi_range(struct sn65dsi83 *ctx,
	 * The encoding of the CHA_DSI_CLK_RANGE is as follows:
	 * 0x00 through 0x07 - Reserved
	 * 0x08 - 40 <= DSI_CLK < 45 MHz
	 * 0x09 - 45 <= DSI_CLK < 50 MHz
	 * 0x63 - 495 <= DSI_CLK < 500 MHz
	 * 0x64 - 500 MHz
	 * 0x65 through 0xFF - Reserved
	 * which is DSI clock in 5 MHz steps, clamped to 40..500 MHz.
	 * The DSI clock are calculated as:
	 *  DSI_CLK = mode clock * bpp / dsi_data_lanes / 2
	 * the 2 is there because the bus is DDR.
	return DIV_ROUND_UP(clamp((unsigned int)mode->clock *
			    mipi_dsi_pixel_format_to_bpp(ctx->dsi->format) /
			    ctx->dsi_lanes / 2, 40000U, 500000U), 5000U);
static u8 sn65dsi83_get_dsi_div(struct sn65dsi83 *ctx)
	/* The divider is (DSI_CLK / LVDS_CLK) - 1, which really is: */
	unsigned int dsi_div = mipi_dsi_pixel_format_to_bpp(ctx->dsi->format);
	dsi_div /= ctx->dsi_lanes;
	if (!ctx->lvds_dual_link)
		dsi_div /= 2;
	return dsi_div - 1;
static void sn65dsi83_atomic_enable(struct drm_bridge *bridge,
	struct drm_atomic_state *state = old_bridge_state->base.state;
	const struct drm_bridge_state *bridge_state;
	const struct drm_crtc_state *crtc_state;
	const struct drm_display_mode *mode;
	struct drm_connector *connector;
	struct drm_crtc *crtc;
	bool lvds_format_24bpp;
	bool lvds_format_jeida;
	unsigned int pval;
	__le16 le16val;
	u16 val;
	int ret;
	/* Get the LVDS format from the bridge state. */
	bridge_state = drm_atomic_get_new_bridge_state(state, bridge);
	switch (bridge_state->output_bus_cfg.format) {
	case MEDIA_BUS_FMT_RGB666_1X7X3_SPWG:
		lvds_format_24bpp = false;
		lvds_format_jeida = true;
		break;
	case MEDIA_BUS_FMT_RGB888_1X7X4_JEIDA:
		lvds_format_24bpp = true;
		break;
	case MEDIA_BUS_FMT_RGB888_1X7X4_SPWG:
		lvds_format_jeida = false;
		break;
	default:
		 * Some bridges still don't set the correct
		 * LVDS bus pixel format, use SPWG24 default
		 * format until those are fixed.
		dev_warn(ctx->dev,
			 "Unsupported LVDS bus format 0x%04x, please check output bridge driver. Falling back to SPWG24.\n",
			 bridge_state->output_bus_cfg.format);
		break;
	 * Retrieve the CRTC adjusted mode. This requires a little dance to go
	 * from the bridge to the encoder, to the connector and to the CRTC.
	connector = drm_atomic_get_new_connector_for_encoder(state,
							     bridge->encoder);
	crtc = drm_atomic_get_new_connector_state(state, connector)->crtc;
	crtc_state = drm_atomic_get_new_crtc_state(state, crtc);
	mode = &crtc_state->adjusted_mode;
	/* Clear reset, disable PLL */
	regmap_write(ctx->regmap, REG_RC_RESET, 0x00);
	regmap_write(ctx->regmap, REG_RC_PLL_EN, 0x00);
	/* Reference clock derived from DSI link clock. */
	regmap_write(ctx->regmap, REG_RC_LVDS_PLL,
		     REG_RC_LVDS_PLL_LVDS_CLK_RANGE(sn65dsi83_get_lvds_range(ctx, mode)) |
		     REG_RC_LVDS_PLL_HS_CLK_SRC_DPHY);
	regmap_write(ctx->regmap, REG_DSI_CLK,
		     REG_DSI_CLK_CHA_DSI_CLK_RANGE(sn65dsi83_get_dsi_range(ctx, mode)));
	regmap_write(ctx->regmap, REG_RC_DSI_CLK,
		     REG_RC_DSI_CLK_DSI_CLK_DIVIDER(sn65dsi83_get_dsi_div(ctx)));
	/* Set number of DSI lanes and LVDS link config. */
	regmap_write(ctx->regmap, REG_DSI_LANE,
		     REG_DSI_LANE_DSI_CHANNEL_MODE_SINGLE |
		     REG_DSI_LANE_CHA_DSI_LANES(~(ctx->dsi_lanes - 1)) |
		     /* CHB is DSI85-only, set to default on DSI83/DSI84 */
		     REG_DSI_LANE_CHB_DSI_LANES(3));
	/* No equalization. */
	regmap_write(ctx->regmap, REG_DSI_EQ, 0x00);
	/* Set up sync signal polarity. */
	val = (mode->flags & DRM_MODE_FLAG_NHSYNC ?
	       REG_LVDS_FMT_HS_NEG_POLARITY : 0) |
	      (mode->flags & DRM_MODE_FLAG_NVSYNC ?
	       REG_LVDS_FMT_VS_NEG_POLARITY : 0);
	/* Set up bits-per-pixel, 18bpp or 24bpp. */
	if (lvds_format_24bpp) {
		val |= REG_LVDS_FMT_CHA_24BPP_MODE;
			val |= REG_LVDS_FMT_CHB_24BPP_MODE;
	/* Set up LVDS format, JEIDA/Format 1 or SPWG/Format 2 */
	if (lvds_format_jeida) {
		val |= REG_LVDS_FMT_CHA_24BPP_FORMAT1;
			val |= REG_LVDS_FMT_CHB_24BPP_FORMAT1;
	/* Set up LVDS output config (DSI84,DSI85) */
		val |= REG_LVDS_FMT_LVDS_LINK_CFG;
	regmap_write(ctx->regmap, REG_LVDS_FMT, val);
	regmap_write(ctx->regmap, REG_LVDS_VCOM, 0x05);
	regmap_write(ctx->regmap, REG_LVDS_LANE,
		     (ctx->lvds_dual_link_even_odd_swap ?
		      REG_LVDS_LANE_EVEN_ODD_SWAP : 0) |
		     REG_LVDS_LANE_CHA_LVDS_TERM |
		     REG_LVDS_LANE_CHB_LVDS_TERM);
	regmap_write(ctx->regmap, REG_LVDS_CM, 0x00);
	le16val = cpu_to_le16(mode->hdisplay);
	regmap_bulk_write(ctx->regmap, REG_VID_CHA_ACTIVE_LINE_LENGTH_LOW,
			  &le16val, 2);
	le16val = cpu_to_le16(mode->vdisplay);
	regmap_bulk_write(ctx->regmap, REG_VID_CHA_VERTICAL_DISPLAY_SIZE_LOW,
			  &le16val, 2);
	/* 32 + 1 pixel clock to ensure proper operation */
	le16val = cpu_to_le16(32 + 1);
	regmap_bulk_write(ctx->regmap, REG_VID_CHA_SYNC_DELAY_LOW, &le16val, 2);
	le16val = cpu_to_le16(mode->hsync_end - mode->hsync_start);
	regmap_bulk_write(ctx->regmap, REG_VID_CHA_HSYNC_PULSE_WIDTH_LOW,
			  &le16val, 2);
	le16val = cpu_to_le16(mode->vsync_end - mode->vsync_start);
	regmap_bulk_write(ctx->regmap, REG_VID_CHA_VSYNC_PULSE_WIDTH_LOW,
			  &le16val, 2);
	regmap_write(ctx->regmap, REG_VID_CHA_HORIZONTAL_BACK_PORCH,
		     mode->htotal - mode->hsync_end);
	regmap_write(ctx->regmap, REG_VID_CHA_VERTICAL_BACK_PORCH,
		     mode->vtotal - mode->vsync_end);
	regmap_write(ctx->regmap, REG_VID_CHA_HORIZONTAL_FRONT_PORCH,
		     mode->hsync_start - mode->hdisplay);
	regmap_write(ctx->regmap, REG_VID_CHA_VERTICAL_FRONT_PORCH,
		     mode->vsync_start - mode->vdisplay);
	regmap_write(ctx->regmap, REG_VID_CHA_TEST_PATTERN, 0x00);
	/* Enable PLL */
	regmap_write(ctx->regmap, REG_RC_PLL_EN, REG_RC_PLL_EN_PLL_EN);
	usleep_range(3000, 4000);
	ret = regmap_read_poll_timeout(ctx->regmap, REG_RC_LVDS_PLL, pval,
				       pval & REG_RC_LVDS_PLL_PLL_EN_STAT,
				       1000, 100000);
	if (ret) {
		dev_err(ctx->dev, "failed to lock PLL, ret=%i\n", ret);
		/* On failure, disable PLL again and exit. */
		return;
	/* Trigger reset after CSR register update. */
	regmap_write(ctx->regmap, REG_RC_RESET, REG_RC_RESET_SOFT_RESET);
	/* Clear all errors that got asserted during initialization. */
	regmap_read(ctx->regmap, REG_IRQ_STAT, &pval);
	regmap_write(ctx->regmap, REG_IRQ_STAT, pval);
static void sn65dsi83_atomic_disable(struct drm_bridge *bridge,
static void sn65dsi83_atomic_post_disable(struct drm_bridge *bridge,
	/* Put the chip in reset, pull EN line low. */
static enum drm_mode_status
sn65dsi83_mode_valid(struct drm_bridge *bridge,
		     const struct drm_display_info *info,
	/* LVDS output clock range 25..154 MHz */
	if (mode->clock < 25000)
		return MODE_CLOCK_LOW;
	if (mode->clock > 154000)
		return MODE_CLOCK_HIGH;
	return MODE_OK;
#define MAX_INPUT_SEL_FORMATS	1
static u32 *
sn65dsi83_atomic_get_input_bus_fmts(struct drm_bridge *bridge,
				    struct drm_bridge_state *bridge_state,
				    struct drm_crtc_state *crtc_state,
				    struct drm_connector_state *conn_state,
				    u32 output_fmt,
				    unsigned int *num_input_fmts)
	u32 *input_fmts;
	*num_input_fmts = 0;
	input_fmts = kcalloc(MAX_INPUT_SEL_FORMATS, sizeof(*input_fmts),
			     GFP_KERNEL);
	if (!input_fmts)
		return NULL;
	/* This is the DSI-end bus format */
	input_fmts[0] = MEDIA_BUS_FMT_RGB888_1X24;
	*num_input_fmts = 1;
	return input_fmts;
static const struct drm_bridge_funcs sn65dsi83_funcs = {
	.attach			= sn65dsi83_attach,
	.atomic_pre_enable	= sn65dsi83_atomic_pre_enable,
	.atomic_enable		= sn65dsi83_atomic_enable,
	.atomic_disable		= sn65dsi83_atomic_disable,
	.atomic_post_disable	= sn65dsi83_atomic_post_disable,
	.mode_valid		= sn65dsi83_mode_valid,
	.atomic_duplicate_state = drm_atomic_helper_bridge_duplicate_state,
	.atomic_destroy_state = drm_atomic_helper_bridge_destroy_state,
	.atomic_reset = drm_atomic_helper_bridge_reset,
	.atomic_get_input_bus_fmts = sn65dsi83_atomic_get_input_bus_fmts,
static int sn65dsi83_parse_dt(struct sn65dsi83 *ctx, enum sn65dsi83_model model)
	struct device_node *endpoint;
	struct drm_panel *panel;
	int ret;
    printk("sn65dsi: parse_dt");
	endpoint = of_graph_get_endpoint_by_regs(dev->of_node, 0, 0);
    printk("sn65dsi: get_endpoint %s", endpoint->name);
	ctx->dsi_lanes = of_property_count_u32_elems(endpoint, "data-lanes");
    printk("sn65dsi: property data-lanes %d", ctx->dsi_lanes);
	ctx->host_node = of_graph_get_remote_port_parent(endpoint);
    printk("sn65dsi: get_remote %s", ctx->host_node->name);
	of_node_put(endpoint);
    printk("sn65dsi: of_node_put");
	if (ctx->dsi_lanes <= 0 || ctx->dsi_lanes > 4) {
		ret = -EINVAL;
        printk("sn65dsi: node_put dsi_lanes %d", ctx->dsi_lanes);
		goto err_put_node;
	if (!ctx->host_node) {
		ret = -ENODEV;
        printk("sn65dsi: node_put host_node");
		goto err_put_node;
	ctx->lvds_dual_link = false;
	ctx->lvds_dual_link_even_odd_swap = false;
	if (model != MODEL_SN65DSI83) {
		struct device_node *port2, *port3;
		int dual_link;
        printk("sn65dsi: MODEL_SN65DSI84");
		port2 = of_graph_get_port_by_id(dev->of_node, 2);
        printk("sn65dsi: get_port 2 %s", port2->full_name);
		port3 = of_graph_get_port_by_id(dev->of_node, 3);
        printk("sn65dsi: get_port 3 %s", port3->full_name);
		dual_link = drm_of_lvds_get_dual_link_pixel_order(port2, port3);
        printk("sn65dsi: dual_link %d", dual_link);
		of_node_put(port2);
        printk("sn65dsi: of_node_put port2");
		of_node_put(port3);
        printk("sn65dsi: of_node_put port3");
		if (dual_link == DRM_LVDS_DUAL_LINK_ODD_EVEN_PIXELS) {
			ctx->lvds_dual_link = true;
			/* Odd pixels to LVDS Channel A, even pixels to B */
		} else if (dual_link == DRM_LVDS_DUAL_LINK_EVEN_ODD_PIXELS) {
			/* Even pixels to LVDS Channel A, odd pixels to B */
			ctx->lvds_dual_link_even_odd_swap = true;
    printk("sn65dsi: dual_link");
	ret = drm_of_find_panel_or_bridge(dev->of_node, 2, 0, &panel, &panel_bridge);
    printk("sn65dsi: find_panel ret %d", ret);
	if (ret < 0)
		goto err_put_node;
	if (panel) {
		panel_bridge = devm_drm_panel_bridge_add(dev, panel);
        printk("sn65dsi: panel_bridge_add");
		if (IS_ERR(panel_bridge)) {
			ret = PTR_ERR(panel_bridge);
			goto err_put_node;
	ctx->panel_bridge = panel_bridge;
	return 0;
err_put_node:
	of_node_put(ctx->host_node);
	return ret;
static int sn65dsi83_probe(struct i2c_client *client,
			   const struct i2c_device_id *id)
	struct device *dev = &client->dev;
	enum sn65dsi83_model model;
	struct sn65dsi83 *ctx;
	int ret;
	ctx = devm_kzalloc(dev, sizeof(*ctx), GFP_KERNEL);
	if (!ctx)
		return -ENOMEM;
    printk("sn65dsi: devm_kzalloc");
	ctx->dev = dev;
	if (dev->of_node) {
		model = (enum sn65dsi83_model)(uintptr_t)
			of_device_get_match_data(dev);
	} else {
		model = id->driver_data;
    printk("sn65dsi: model");
	ctx->enable_gpio = devm_gpiod_get(ctx->dev, "enable", GPIOD_OUT_HIGH);
	if (IS_ERR(ctx->enable_gpio))
		return PTR_ERR(ctx->enable_gpio);
	ret = sn65dsi83_parse_dt(ctx, model);
	if (ret)
		return ret;
    printk("sn65dsi: gpio");
	ctx->regmap = devm_regmap_init_i2c(client, &sn65dsi83_regmap_config);
	if (IS_ERR(ctx->regmap)) {
		ret = PTR_ERR(ctx->regmap);
		goto err_put_node;
    printk("sn65dsi: init_i2c");
	dev_set_drvdata(dev, ctx);
	i2c_set_clientdata(client, ctx);
    printk("sn65dsi: set_drvdata");
	ctx->bridge.funcs = &sn65dsi83_funcs;
	ctx->bridge.of_node = dev->of_node;
	drm_bridge_add(&ctx->bridge);
    printk("sn65dsi: bridge_add");
	return 0;
err_put_node:
	return ret;
static int sn65dsi83_remove(struct i2c_client *client)
	struct sn65dsi83 *ctx = i2c_get_clientdata(client);
	mipi_dsi_detach(ctx->dsi);
	mipi_dsi_device_unregister(ctx->dsi);
	drm_bridge_remove(&ctx->bridge);
	return 0;
static struct i2c_device_id sn65dsi83_id[] = {
	{ "ti,sn65dsi83", MODEL_SN65DSI83 },
	{ "ti,sn65dsi84", MODEL_SN65DSI84 },
MODULE_DEVICE_TABLE(i2c, sn65dsi83_id);
static const struct of_device_id sn65dsi83_match_table[] = {
	{ .compatible = "ti,sn65dsi83", .data = (void *)MODEL_SN65DSI83 },
	{ .compatible = "ti,sn65dsi84", .data = (void *)MODEL_SN65DSI84 },
MODULE_DEVICE_TABLE(of, sn65dsi83_match_table);
static struct i2c_driver sn65dsi83_driver = {
	.probe = sn65dsi83_probe,
	.remove = sn65dsi83_remove,
	.id_table = sn65dsi83_id,
	.driver = {
		.name = "sn65dsi83",
		.of_match_table = sn65dsi83_match_table,
module_i2c_driver(sn65dsi83_driver);
MODULE_AUTHOR("Marek Vasut <marex@denx.de>");
MODULE_DESCRIPTION("TI SN65DSI83 DSI to LVDS bridge driver");
MODULE_LICENSE("GPL v2");
Depending on the driver source above, it's printed "sn65dsi: bridge_add" but not printed "sn65dsi: attach".
Is there anything I missed?
