TCAN1145-Q1: TCAN1145 review schematic
Part Number: TCAN1145-Q1
Hi, Support Team
our client use TCAN1145-Q1 as below chart, have any concern?
if any suggestion, Please advise me.
Lawrence
  • Jasper,
    An engineer has been notified of this post and will respond accordingly. Thanks for your patience.
    Eric Hackett
  • Hi Lawrence,
    This schematic looks good. I don’t have any major changes to recommend. See my notes below.
    • Decoupling capacitors included and valued appropriately.
      • Current estimate for Vsup pin is undervalued. Max Isup current is 1.5mA in normal mode. Consider revising design if necessary for current needs of trace.
    • Split capacitor included and valued appropriately.
    • Bus capacitors included and valued appropriately - ensure placement close to connector and along signal path.
    • TVS diode not included - no issue. Perhaps on other schematic sheet near connector?.
    • Termination resistors included correctly and valued appropriately for end node.
    • CMC placed nominally between transceiver and termination.
      • Consider optional bypass 0-ohm resistors in case CMC is not needed.
    • All pull-up / series resistances are acceptable.
    Let me know if there are any questions or concerns regarding the design.
    Eric Schott
