Part Number: DP83867CR
Other Parts Discussed in Thread: DP83869
HI team,
My customer is considering using the "DP83867CRRGZT" in conjunction with the LAN Port "7499151120" manufactured by Würth Elektronik for 1000BASE-T communication. The LAN port "7499151120" requires current mode, but I could not find any information in the DP83867CRRGZT data sheet on whether current mode is supported. Could you please answer the following questions regarding current mode?
Questions
- Could you please tell me if DP83867CRRGZT can be used in the above way? If not, I would like you to recommend an alternative PHY.
- Could you provide a typical circuit diagram example for current mode connection for reference?
- (My Question) Could you please provide me with an explanatory document regarding the PHY current mode itself?
RJ45 Connector
- Product Homepage https://www.we-online.com/de/components/products/WE-LAN-RJ45?sq=7499151120#7499151120
- Datasheet https://www.we-online.com/components/products/datasheet/7499151120.pdf
They selected the two-tiered type to reduce the mounting area.
Thank you for your help.
Taito Takemura
