SN65HVD63: How to choose AC coupling capacitor
Part Number: SN65HVD63
Customer have asked me one question about the RXIN AC capacitor value.
I want to know why the capacitance is 220nF, Could it be 100nF,X7R,1608 package capacitor?
Thank you
Yishan Chen
  • Yishan,
    The device was designed/tested/validated around the 220nF cap. It also affects the passband filter. Please use the 220nF as recommended by the datasheet.
    -Bobby
  • Hi Bobby,
    Thank you for your answer.
    But customer is tested in 100nF, would it have some potential risks?
    Besides, could you tell me how this affects the pass band filter?
    Yishan Chen
  • But customer is tested in 100nF, would it have some potential risks?
    I did run a simulation using simple RC circuits. The difference in attenuation when driving through the cap into a 50 ohm load was only 1%. This was using the 2.176MHz carrier frequency. I don't necessarily think the carrier transmission is that heavily affected by changing the coupling capacitor.
    The data wave signal did see a bit more distortion when I used a lower data rate (9600bps).
    Unfortunately this device is quite old. I don't think we will be able to locate the files to find out what the internal receiver band pass filter looks like.
    -Bobby
