TCAN3404-Q1: STB & SHDN pin
Part Number: TCAN3404-Q1
Hi Team,
Below is our schematic.
And we want to check the pin of STB and SHDN. If we want to let CAN work, pull low to GND these two pins, is it correct?
Roy
  • Roy,
    That is correct, the schematic shows SHDN floating, which would be at a logic low due to the internal pull down, and STB is controlled by the MCU. If the MCU drives the STB low, then the device will be in Normal mode.
    Eric Hackett
