TUSB211A: How does device react to USB DCP
Part Number: TUSB211A
For the TUSB211A, if a DCP charger is connected, which shorts D+/D- with less than 200 ohms, how do CD and ENA_HS report?
My hope is that is reports as CD=LOW and ENA_HS=LOW, but I would like verification, if possible.
Matt
  • Hi Matt,
    The TUSB211A enables the CD pin when it sees either a USB connection with a pull-up resistor on DP or DM, and the ENA_HS pin when it sees a successful High-speed handshake. If with a DCP charger there is a pull-up on either of these lanes or the DCP charger has to enter HS to function, then these pins would read high. Otherwise, these pins should stay low. Personally, I don't have any experience with testing with this kind of setup, so I can't say for sure. I can see if someone on the team would have an idea of what to expect.
    Ryan
  • Ryan,
    Thanks for your response.  Typically, the DCP charger has D+ shorted to D- with a 200 Ohm or less resistor.  There is no pull-up on either D+ or D- externally in the charger.  My guess is that the TUSB211A would have CD and ENA_HS low in thise case, but that is just a guess or hope.
    If any of the development boards existed, I could test this out, but I have found none to buy.  The pico version doesn't bring out the CD pin, so it would be harder to test.  I am looking to obtain a part to dead bug, but that won't be immediately.
    Is there anyone in your team that has the development board they could plug in a standfard Type-A charger brick into to see what CD and ENA_HS do?
    Matt
  • Hi Matt,
    If this is the case then it sounds like there wouldn't be any USB data transfer or communication going on, just a dedicated charging port, in which case yes, the CD and ENA_HS pins should be low.
    I tested this out in our lab with a USB-A Charging Brick plugged into an outlet > EVM > IPhone, and saw charging on the iphone but no signs of activity on the CD or ENA_HS pin, so I believe the assumption is correct.
    I would recommend looking at the PICO still. Like you said, it doesnt break out the CD Pin, but there is an LED attached to the ENA_HS pin. If the ENA_HS pin/LED is not high, then that indicates that the redriver is not active. Regardless of whether the CD pin is high or not, if there ENA_HS pin is not high, the redriver will not enable.
    Please let me know if you have any other questions, or maybe want some help getting an EVM going.
    Ryan
  • Ryan,
    Thanks again for doing that test.  I will go ahead and purchase the PICO as a check.  I might be able to touch the CD pin during the test.
    I consider this resolved.
    Matt
