SN65HVD1781: Output Typ of A-B (PIN6, PIN7)
Part Number: SN65HVD1781
Hello Team,
what kind ouf output structure has the transeiver. My customer asks if it is push pull for a and b channel.
I found this appnote:
https://www.ti.com/lit/wp/slla545/slla545.pdf
Does this transceiver has the same circuit tree?
thanks
Jan
  • Yes; all RS-485 drivers have push/pull outputs (with reverse-current and overvoltage protection).
  • Hi Jan,
    Yes, that should be correct. The RS485/RS422 differential outputs are basically H-bridge drivers. They will be able to handle slight overvoltage and protect against back biasing using low forward voltage Schottky diodes. (As Clemens has stated).
    I think the older technology used BJTs, newer devices use FETs.
    -Bobby
