DP83822HF: RMII Reference Clock in DP83822HF
Part Number: DP83822HF
Can you confirm the reference clock output pin in DP83822 while working in RMII master mode
  • Hi Vijesh!
    RX_D3 will automatically be the 50 MHz output clock if the PHY is strapped into RMII_Master. For this, RV_DV needs to be strapped into Mode 3 (5.76 PU, 2.49 PD)
    The screenshot you sent shows the RMII pins, but not the strapping resistors. Is there another portion of the schematic where the strap settings are shown?
    Alvaro
