TCAN1044AV-Q1: split terminal resistor
Part Number: TCAN1044AV-Q1
Hi team,
Please help answer the design guidelines for TCAN1044AVDRQ1 non-end-node split-termination resistors.
1. Under what circumstances does the non-terminal node need to populate a split terminal resistor, and what is the impact if it is not populated?
2. Under what circumstances does the non-terminal node need to populate a split terminal resistor, and if so, what is the impact?
Peter
