DS280DF810: DS280DF810 Support Data Rate
Part Number: DS280DF810
Other Parts Discussed in Thread: DS250DF810
Hello!
I'm considering to use the DS280DF810 as a repeater for high-speed differential signals (25Gbps).
Can the DS280DF810 pass PRBS-31 pseudo-random signals?
Can I use the DS280DF810 to pass signals at three speeds: 25Gbps/16Gbps/8Gbps?
There are two similar parts, the DS280DF810 and the DS250DF810. Is it okay to choose either one?
Best regards
Hiroshi Katagiri
  • Hi Hiroshi-san,
    Thanks for your interest in DS280DF810.  Are you able to share any information on your application?  Looking at your data rates, this does not seem to be a typical Ethernet application.
    Regarding your questions:
    Yes, the DS280DF810 can pass PRBS31 signals.
    The DS280DF810 can retimer 25 Gbps, but can only support 16 Gbps and 8 Gbps in RAW mode (CDR bypass).  In RAW mode, the DS280DF810 acts similar to a limiting redriver, and the only equalization is CTLE.
    For 25 Gbps, either DS280DF810 or DS250DF810 is alright.
    Drew
  • Drew-san
    Thank you for your reply.
    For this application, we are considering using a proprietary protocol between two FPGAs.
    I have two questions.
    1.
    Is the reason for being limited to the redriver
    because the input data rate is not within the Full/Half/Quarter range?
    2.
    When using 16Gbps and 8Gbps, will it go into RAW mode without any settings?
    Or do I need to program it according to the SNLU182 documentation?
    Best regards
    Hiroshi Katagiri
  • Hiroshi-san
    Due to the US Labor Day holiday, the response to your question may be delayed. We will look into your question when we return tomorrow, Sept 3rd. Sorry for the wait and any inconvenience it may cause.
    David
  • Hi Hiroshi-san,
    1.
    Yes, this is correct.
    2.
    You will need to program according to SNLU182.  Default behavior is that TX is muted when signal is detected and CDR is unlocked.  You want to change behavior so that TX is set to RAW when signal is detected and CDR is unlocked.  Please see section "7.42 Raw mode(CDR Bypassed)".
    Drew
  • Drew-san
    Thank you for your reply. I understand it.
