Part Number: PCA9546A
Please VOH(min), VOL(max)(for I2C), which was not found in Datasheet
I²C uses open-drain signals, so the chip never outputs a high signal. The high-level voltage is determined only by the pull-up resistors.
VOL is specified as the test condition for IOL.
The connections to the four channels are done with passive switches. The voltage drop over the switch depends on RON and the current through the switch.
