We use LMH0303 for HD-SDI output in our project, 2 such instances onboard.
Measuring each of the 2 interfaces, the results we get are outside of Spec, in terms of amplitude, rise and fall time.
For channel 0, amplitude is 615 mV, rise/fall time is 450/452 pS, respectively.
For channel 1, amplitude is 704 mV, rise/fall time is 515/513 pS, respectively.
Video image looks ok, however it obviously does not correlate with the above mentioned values.
We have double-checked the circuit implementation and found it matching TI instructions (schematic diagram is attached).
The issue described seems very similar to the one addressed in this forum, however we couldn't find any solution summary:
We were able to tune the amplitude, changing Rref resistor, such that for channel 1, we got amplitude of 778mV, however no change whatsoever in rise/fall time.
Please advise about possible steps to fix this issue.
Thanks in advance,
