Apploader driver for TUSB3210 does not work under windows 7 32bit.
Hi, everyone.
    I designed a circuit using TUSB3210. When I try it under Win XP 32 bit following "Using the Apploader driver.pdf" step by step, everything works right and device been recognized as "Human Interface Device" with VID_0451&PID_0040.
      But when I do the same thing with exact same steps under windows 7 32bit, failed with following message:
a. The VID AND PID is right.
b. I try to install driver.
c.  but failed,
      BTW, I've tried this under several PC with different version of windows 7 32bit. Anyone know what happened ?  and how could I make it works right
under windows 7 ?  Thank you.
                    Could you please try downloading our latest Apploader version from http://www.ti.com/litv/zip/sllc160a ? old version of the Apploader have not support for Win7, but this last version install the driver without problems in Windows7 following the instruction.
                    Unlike XP, Windows 7 warning you if you attempt to install a unsigned driver (FIG1), please select the “Install driver software anyway” option and continue whit the installation.
     Fig1
    Roberto.
  • To Roberto Diaz:
          The apploader version I used before is exactly the same with your given link.
    Actually, my currently using apploader was downloaded from that link several days ago.
         BTW, I download for your given link and insall, again, failed.
         Hope for your help.
                                          Alex CHEN
  • Alex,
                    I have tried to install the driver on several Win7 PCs and It’s installing without problems, could you please provide us the exactly files that you are using (C:\Apploader)? I want to reproduce this issue using the same scenario.
    Roberto.
  • Roberto,
            Yesterday, i tried on my home PC( old DELL system of year 2004) with windows 7 32bit, it works right.
    Today, I will try on other PC with windows 7 32bit.
            I really do not know why my portal and one of my workmate's porttal with windows 7 32bit, failed.
    Confusing...     I will try to upload the C:\apploader files a little later.
          Alex
  • What I do on my portal is exactly same with on my home PC.
    I've send apploader's contents to Elias email box, he will forward to you.
    Thank you, roberto.
  • Just now, i tried on another PC (intel mainboard, 2010),   works right.
    until now,  2 PC: success, 2 laptop: failed.  all with windows 7 32 bit.
    Anyway, it can work with my pc now, ....
    Some days later, i will try to fully reinstall the OS of my portal, and try again.
