TCAN1044V-Q1: Supply Current Spec
Part Number: TCAN1044V-Q1
Hi team,
I have a questions about supply current spec in TCAN1044V-Q1 datasheet. Could you tell me why supply current without VIO is higher than with VIO?
Muwei Zheng
  • Muwei,
    This is because without VIO, VCC is the only rail supplying every function of the device. With VIO, VCC is biasing the CAN bus and supplying some of the digital logic, while VIO is acting as the internal pull-up for the logic pins, and also supplying some of the digital logic.
    Eric Hackett
