Part Number: LAUNCHXL-CC3235SF
Other Parts Discussed in Thread: CC3235SF
I am facing the difficulty to integrate the AWS Iot core mqtt with my controller using secured keys, I am trying pass my CA certificate.
I have tried this from direct example of cc3235sf(mqtt_client_over_tls_1_3_CC3235SF_LAUNCHXL_freertos_ticlang) and I didn't use any AWS plugins.
Could you please help me here how to achieve the Mqtt connection with AWS IoT Core.
Vamsi
/***AmazonRootCA1.pem***/ -----BEGIN CERTIFICATE----- MIIDQTCCAimgAwIBAgITBmyfz5m/jAo54vB4ikPmljZbyjANBgkqhkiG9w0BAQsF ADA5MQswCQYDVQQGEwJVUzEPMA0GA1UEChMGQW1hem9uMRkwFwYDVQQDExBBbWF6 b24gUm9vdCBDQSAxMB4XDTE1MDUyNjAwMDAwMFoXDTM4MDExNzAwMDAwMFowOTEL MAkGA1UEBhMCVVMxDzANBgNVBAoTBkFtYXpvbjEZMBcGA1UEAxMQQW1hem9uIFJv b3QgQ0EgMTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBALJ4gHHKeNXj ca9HgFB0fW7Y14h29Jlo91ghYPl0hAEvrAIthtOgQ3pOsqTQNroBvo3bSMgHFzZM 9O6II8c+6zf1tRn4SWiw3te5djgdYZ6k/oI2peVKVuRF4fn9tBb6dNqcmzU5L/qw IFAGbHrQgLKm+a/sRxmPUDgH3KKHOVj4utWp+UhnMJbulHheb4mjUcAwhmahRWa6 VOujw5H5SNz/0egwLX0tdHA114gk957EWW67c4cX8jJGKLhD+rcdqsq08p8kDi1L 93FcXmn/6pUCyziKrlA4b9v7LWIbxcceVOF34GfID5yHI9Y/QCB/IIDEgEw+OyQm jgSubJrIqg0CAwEAAaNCMEAwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMC AYYwHQYDVR0OBBYEFIQYzIU07LwMlJQuCFmcx7IQTgoIMA0GCSqGSIb3DQEBCwUA A4IBAQCY8jdaQZChGsV2USggNiMOruYou6r4lK5IpDB/G/wkjUu0yKGX9rbxenDI U5PMCCjjmCXPI6T53iHTfIUJrU6adTrCC2qJeHZERxhlbI1Bjjt/msv0tadQ1wUs N+gDS63pYaACbvXy8MWy7Vu33PqUXHeeE6V/Uq2V8viTO96LXFvKWlJbYK8U90vv o/ufQJVtMVT8QtPHRh8jrdkPSHCa2XV4cdFyQzR1bldZwgJcJmApzyMZFo6IQ6XU 5MsI+yMRQ+hDKXJioaldXgjUkK642M4UwtBV8ob2xJNDd2ZhwLnoQdeXeGADbkpy rqXRfboQnoZsG4q5WTP468SQvvG5 -----END CERTIFICATE-----
I am sharing the RootCA1 file
can you remove the /***AmazonRootCA1.pem***/ and retest?
Generally, the error -8576 coming out from mbedtls_x509_crt_parse() can happen only during parsing of that rootCA certificate.
this error denotes an 'unsupported key encryption algorithm' which can happen only if there is another header like the '-----BEGIN CERTIFICATE-----' next to denote the encryption key type (if the certificate is passphrase protected). This could be for example 'Proc-Type: 4,ENCRYPTED' header but since you do not have it, I don't see how this error could happen.
Shlomi
Sorry my mistake I have just put this(/***AmazonRootCA1.pem***/) in chat but in actually .pem file the string is not present.
And the key file is started with '-----BEGIN CERTIFICATE-----', please let me know if anything I need to do.
if after the -----BEGIN CERTIFICATE----- there is no other header denoting the certificate is protected by a passphrase, I do not have a logic explanation why you get this error.
According to the code, this error appears only in case it is password protected.
closing this thread and moving to the new thread you opened (https://e2e.ti.com/support/wireless-connectivity/wi-fi-group/wifi/f/wi-fi-forum/1422877/launchxl-cc3235sf-aws-iot-core-integrations-with-sdk-7_10)
Shlomi
