TUSB9261DEMO: TUSB9261DEMO design files
Part Number: TUSB9261DEMO
Other Parts Discussed in Thread: AM5728, TUSB9261
 i need the demo board design files
  • also can this Ic be used for Avionics
  • Hi Ramachandran,
    Please accept my E2E friend request, and I can send those design files over.
    As for Avionics use, what would the use case be?
    Ryan
  • we are using to store data into sata using am5728.but sata driver is only available in linux , so i thought of using rtos USB driver  to store data into sata  using usb to sata converter(TIUSB9261).but inside the TIUSB9261 is a arm cortexM3 which runs a specific firmware.I want to know if this firmware is avionic compatible(DO 178C  standard).
  • Hi Ramachandran,
    I just sent you over the design files.
    As for whether this firmware is Avionic compatible, as far as I am aware, this firmware was not developed with this standard in mind, and we have no tracked records of it being compliant. With that being said, we do offer the source code of this firmware, as we do not currently have the support to develop or make modifications to this firmware, so if needed, you can take a look at the source code yourself to determine if its compliant, or how it needs to be modified to be compliant. You can request the code here on the TUSB9261 webpage:
    Please let me know if you have any other questions.
    Ryan
