Part Number: DP83869HM
Other Parts Discussed in Thread: DP83869
The module has a DP83869HM module connect to a StarTech SFP1000TXST 1000Base-T module and the link indication is not being turned on. I have test the SFP in other systems and it works correctly. Here are the DP83869 registers with no cable inserted:
EMAC3 DP83869HM(0x1) Direct Access Registers
Reg
0: 1140 1: 6169 2: 2000 3: a0f3 4: 0020 5: 4001 6: 0007 7: 2001
8: 0000 9: 1000 a: 0000 b: c: d: 0000 e: 0000 f: f000
10: 5048 11: 6b02 12: 0000 13: 0040 14: 29c7 15: 0000 16: 0000 17: 0040
18: 6150 19: 4044 1a: 0002 1b: 1c: 1d: 1e: 0012 1f: 0000
EMAC3 DP83869HM(0x1) Extended Access Registers
Reg
25: 0480 2c: 141f 2d: 0000 2e: 0221 31: 10b0 32: 00d0 33: 0000 37: 0003
39: 0000 3a: 0000 43: 07a0 4f: 0116 55: 0000 6e: 0218 86: 0077 d6: 0000
134: 1000 135: 0000 170: 0c0c 180: 0752 181: c850 182: 5326 183: a01e 184: e976
185: 19cf 190: 0000 191: 0000 192: 0000 193: 0000 194: 0000 195: 0000 196: 0000
197: 0000 198: 0000 199: 0000 1a4: 0000 1a5: 0000 1a6: 0000 1d5: f500 1df: 0041
1e0: 417a 1ec: 1ffd c00: 1140 c01: 6169 c02: 2000 c03: a0f3 c04: 0020 c05: 4001
c06: 0005 c07: 2001 c08: 0000 c10: 3348 c18: 01ff c19: 0005
Here are the registers with the cable inserted:
Reg
0: 1140 1: 6179 2: 2000 3: a0f3 4: 0020 5: d801 6: 000f 7: 2001
10: 5048 11: 6802 12: 0000 13: 0040 14: 29c7 15: 0000 16: 0000 17: 0040
Reg
39: 0000 3a: 0000 43: 07a0 4f: 0156 55: 0000 6e: 0218 86: 0077 d6: 0000
1e0: 417a 1ec: 1ffd c00: 1140 c01: 6179 c02: 2000 c03: a0f3 c04: 0020 c05: d801
c06: 000d c07: 2001 c08: 0000 c10: 3348 c18: 01ff c19: 000d
There are other 1000Base-T SFPs that work correctly.
Any insight why this SFP does not work and others word would greatly be appreciated.
Also, is there a list of copper SFPs that work with the DP83869HM?
