Part Number: DP83822H
Hi Team,
Please support in reviewing the DP83822H 100 Mbps Ethernet PHY circuit schematics & provide review comments.
Attached the schematics PDF file below:
Axiado_FVT_DP83822H_Sch-02.pdf
Thanks & Regards,
Anush
Hi Team,
Thanks & Regards,
Anush
Hi Anush,
Please refer to this schematic checklist:
https://www.ti.com/lit/zip/snlr053
After reviewing "Pin Wise Checklist" sheet to return here, I will provide additional comments.
Thank you,
Evan
Hello Evan,
Thanks for providing the Schematics Design Checklist sheet. Let me go through the sheet & get back to you with the updated schematics.
Thanks & Regards,
Anush
Hi Evan,
We are planning to operate the Ethernet PHY in RMII mode. From the datasheet it is mentioned as the TX CLK & RX CLK pins will not be used in RMII mode.
But in the Master / Slave Signaling diagrams, the RX CLK signals is mentioned as optional. Kindly let us know if we need TX CLK & RX CLK signals for proper RMII operations.
Thanks & Regards,
Anush
Hi Anush,
TX CLK and RX CLK are not required for proper RMII operation.
Thank you,
Evan
