Part Number: LMH1219
Hi LMH1219 Team,
We have a query with regards to the IN0+ Reclocker Lock Data Rates for an incoming HD-SDI Stream.
We are currently considerting the integration of the LMH1219 Reclocker with some of our Research and Development. As part of our testing process, we are also evaluating the tolerance of the bit rate of the incoming HD-SDI data in order for a lock to be achived.
As per the excerpt from the LMH1219 datasheet, there are currently only typical values for the reclocker lock data rates, as highlighted in the image below.
For the highlighted SMPTE HD specs, do you have a MINIMUM or MAXIMUM value that can be provided?
Thank you!
