Other Parts Discussed in Thread: DS25BR100,
Hi TIer
My medical customer saw this parameter in the data sheet, the minimum input voltage needs to be 600mV.
But when customers need a redriver, the signal is very attenuated much less than 600mV.
So we're confused here about what this parameter really means.
Also How SDH and VTX should be understood ?
Thank you very much.
same question in DS25BR100
The datasheet mentioned similar, the input voltage threshold needs to be minimum 100mV, but the received eye figure closed amplitude is generally less than 100MV, so how should this VTH100mV be understood?
