DP83848I: DP83848 fails after repeated plugging and unplugging
Part Number: DP83848I
The customer used the DP83848I to test and found that after repeatedly plugging and unplugging the network cable many times, the DP83848I failed to communicate. After powering on again, some machines could resume communication, but some could not.
1. An AB-BA cross experiment between different circuit boards found that the fault followed the DP83848I faulty part. Please help to check if there is any problem with the customer's schematic design. Thank you.
