Part Number: DS320PR1601
Other Parts Discussed in Thread: DS320PR810, DS160PR810
Could someone please provide an example .hex file of EEPROM for configuring DS320PR1601.
Thanks and Regards,
Shekha Shoukath
Thanks and Regards,
Shekha Shoukath
Hi Shekha,
The DS320PR1601 SigCon Architect GUI can be used to create any EEPROM file. This can be requested here: https://www.ti.com/secureresources/PCIE5-REDRIVERS-DESIGN
Upon initial load of the GUI, the EEPROM Page will be set to the 'Default' settings. A hex file of these settings can be generated using the "Write to EEPROM Hex" button.
Let me know if you have any issues using the GUI. I can provide an example file via private message if you have an issue.
David
I have accessed PCIe 5 Redriver designs, but in the zip file only dsn file of the same is given all other documents are regarding DS320PR810 and DS320PR412.
Programming guides are also regarding the same only.
Can I get the EEPROM programming guide for DS320PR1601.
Thanks and Regards,
Shekha Shoukath
Hi Shekha,
The DS320PR1601 EEPROM follows the same configuration architecture of the DS320PR810.
I would suggest using the DS320PR1601 SigCon Architect GUI to generate EEPROM files.
If you would like to learn a bit more about the structure of the EEPROM profiles, an application note under our Gen4 redriver secure folder discusses the EEPROM format, which is the same between this device and DS160PR810.
David
[redacted, contains secure resource information]
Thanks and Regards,
Shekha Shoukath
Hi Shekha,
This schematic file is under the secure resources folder for this device, so I have redacted some of the information posted in your reply - as this is a public forum. I've saved your question and can help you via E2E private message.
Please accept my friend request so that I can respond to your message privately.
David
The information has been communicated via private E2E message. Marking this post as resolved.
