Part Number: TLK10232
Other Parts Discussed in Thread: DS110DF111
<converting from email>
I am trying to use the TLK10232 to convert 10KR to SFP. I based my design around some forum posts which indicated that you should be able to connect the High Speed Side A to High Speed Side B by way of an internal switch. I have 2 eval boards connected together and I am using the GUI to try to configure the parts.
This is my current eval board setup:
The goal is to be able to ping from one laptop to another. If I remove the eval boards and just use the fiber, I can ping. Adding the eval boards back in, I am unable to ping.
So far, I can get a link light between the switch and the eval board (on the SFP side) but I cannot get data across the 10KR (coax side).
If I can get this working, I can avoid respinning my actual design.
