Part Number: DS90UB941AS-Q1EVM
Other Parts Discussed in Thread: DS90UB949-Q1, ALP
Hello, could you kindly advise the parts required to convert 15 pin MIPI DSI output from Raspberry Pi to Samtec MIPI DSI connector on this eval board. I cannot find a cable or adapter that has this Samtec connector which accepts flex cable 15 pin. What is the common name for this Samtec connector?
If not, could your provide advice on what sort of video source and the respective cables needed to input a video signal to this eval board.
Thank you.
